In Energy Saving (KDE System Settings) in On Battery tab I have checked “While asleep hibernate after a period of inactivity” (in other tabs it’s unchecked). It works pretty good, but it hibernates when on AC too. If I uncheck the box, it will stop going into hibernation after suspend both when on AC and when on Battery.
inxi
inxi -Fazy ✔
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6be97e9b-f558-4a59-a8d9-8d54ccfea8b7 rw pcie_port_pm=off
intel_iommu=off acpi_enforce_resources=lax
resume=UUID=3d0743ba-42b1-4c48-92a0-92533c0a018a udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: N550JV v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: N550JV v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: N550JV.208 date: 11/19/2013
ID-1: BAT0 charge: 35.8 Wh (94.0%) condition: 38.1/60.5 Wh (63.1%)
volts: 15.0 min: 15.0 model: ASUSTeK N550-40 type: Li-ion serial: N/A
status: charging cycles: 600
Info: model: Intel Core i7-4700HQ bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1893 high: 2605 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1682 2: 2492 3: 1396
4: 1627 5: 1923 6: 2605 7: 1556 8: 1864 bogomips: 38335
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: ASUSTeK driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:0fe4 class-ID: 0302
Device-3: IMC Networks USB2.0 UVC HD Webcam type: USB driver: uvcvideo
bus-ID: 3-7:3 chip-ID: 13d3:5188 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 120 s-size: 406x228mm (15.98x8.98")
s-diag: 466mm (18.33")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15c3 built: 2014 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 168c:0032 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-1: IMC Networks Bluetooth USB Host Controller type: USB driver: btusb
v: 0.8 bus-ID: 3-5:6 chip-ID: 13d3:3402 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 922.21 GiB used: 30.98 GiB (3.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST750LM022 HN-M750MBB
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0002 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SHSS37A240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00.r scheme: GPT
ID-1: / raw-size: 40 GiB size: 39.2 GiB (98.00%) used: 16.89 GiB (43.1%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sdb7 maj-min: 8:23
ID-3: /home raw-size: 42.15 GiB size: 41.32 GiB (98.03%) used: 14.1 GiB
(34.1%) fs: ext4 dev: /dev/sdb6 maj-min: 8:22
Kernel: swappiness: 0 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 7 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb8 maj-min: 8:24
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2300
Processes: 267 Uptime: 2h 4m wakeups: 2 Memory: 15.08 GiB used: 3.02 GiB
(20.0%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 1505 pm: pacman pkgs: 1495 libs: 428
tools: octopi,pamac,yay pm: flatpak pkgs: 10 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
