Laptop freezes resuming after suspend-to-ram
Hello,
I've a Asus N752VX laptop and I'm using Manjaro KDE.
I have a strange problem with it: my laptop randomly freezes after suspend to ram. I close the lid and when I open the lid back, sometimes it freezes, no responses at all. Even trying REISUB, no response, I only have to force shutdown by pressing power button. The HDD light of the laptop remains lit. I thought it was a login manager problem, but changing from XFCE to KDE and switching from LightDM to SDDM gave no good news.
I use TLP, nouveau graphic driver. I've tried to blacklist it into TLP, using:
RUNTIME_PM_DRIVER_BLACKLIST="nouveau nvidia"
but I had no good results. I'm running 5.4.6-2-MANJARO kernel, but I think kernel is not influent, since the problem existed with all the versions I've tried before.
I've tried also to modify boot parameters, deactivating apparmor or mitigations, like this:
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=0 security='' udev.log_priority=3 mitigations=off"
but it seems nothing different happens.
This is my lshw:
fabio-pc
    description: Notebook
    product: N752VX (ASUS-NotebookSKU)
    vendor: ASUSTeK COMPUTER INC.
    version: 1.0
    serial: G7N0CY004046275
    width: 4294967295 bits
    capabilities: smbios-3.0 dmi-3.0 smp vsyscall32
    configuration: boot=normal chassis=notebook family=N sku=ASUS-NotebookSKU uuid=9F0CAADC-5DDF-4B14-B025-AB6763D76192
  *-core
       description: Motherboard
       product: N752VX
       physical id: 0
       version: 1.0
       serial: BSN12345678901234567
       slot: MIDDLE
     *-firmware
          description: BIOS
          vendor: American Megatrends Inc.
          physical id: 0
          version: N752VX.303
          date: 04/17/2019
          capacity: 5952KiB
          capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification uefi
     *-cache:0
          description: L1 cache
          physical id: 11
          slot: L1 Cache
          capacity: 128KiB
          capabilities: synchronous internal write-back data
          configuration: level=1
     *-cache:1
          physical id: 12
          slot: L1 Cache
          capacity: 128KiB
          capabilities: synchronous internal write-back instruction
     *-cache:2
          description: L2 cache
          physical id: 13
          slot: L2 Cache
          capacity: 1MiB
          capabilities: synchronous internal write-back unified
          configuration: level=2
     *-cache:3
          description: L3 cache
          physical id: 14
          slot: L3 Cache
          capacity: 6MiB
          configuration: level=3
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
          vendor: Intel Corp.
          physical id: 15
          bus info: cpu@0
          version: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz
          serial: To Be Filled By O.E.M.
          slot: U3E1
          capacity: 3500MHz
          width: 64 bits
          clock: 100MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp md_clear flush_l1d cpufreq
          configuration: cores=4 enabledcores=4 threads=8
     *-memory
          description: System Memory
          physical id: 16
          slot: System board or motherboard
        *-bank:0
             description: [empty]
             physical id: 0
             slot: ChannelA-DIMM0
        *-bank:1
             physical id: 1
             slot: ChannelA-DIMM1
        *-bank:2
             description: SODIMM DDR4 Synchronous 2133 MHz (0,5 ns)
             product: HMA41GS6AFR8N-TF
             vendor: SK Hynix
             physical id: 2
             serial: 14103623
             slot: ChannelB-DIMM0
             width: 64 bits
             clock: 2133MHz (0.5ns)
        *-bank:3
             physical id: 3
             slot: ChannelB-DIMM1
     *-pci
          description: Host bridge
          product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 07
          width: 32 bits
          clock: 33MHz
          configuration: driver=skl_uncore
          resources: irq:0
        *-pci:0
             description: PCI bridge
             product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16)
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 07
             width: 32 bits
             clock: 33MHz
             capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:122 ioport:e000(size=4096) memory:de000000-df0fffff ioport:c0000000(size=301989888)
           *-display
                description: 3D controller
                product: GM107M [GeForce GTX 950M]
                vendor: NVIDIA Corporation
                physical id: 0
                bus info: pci@0000:01:00.0
                version: a2
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress cap_list rom
                configuration: driver=nouveau latency=0
                resources: irq:140 memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:df000000-df07ffff
        *-display
             description: VGA compatible controller
             product: HD Graphics 530
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 06
             width: 64 bits
             clock: 33MHz
             capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:141 memory:dd000000-ddffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
        *-generic:0
             description: Signal processing controller
             product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
             physical id: 4
             bus info: pci@0000:00:04.0
             version: 07
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm bus_master cap_list
             configuration: driver=proc_thermal latency=0
             resources: irq:16 memory:df420000-df427fff
        *-usb
             description: USB controller
             product: 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:127 memory:df410000-df41ffff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 5.4.6-2-MANJARO xhci-hcd
                physical id: 0
                bus info: usb@1
                logical name: usb1
                version: 5.04
                capabilities: usb-2.00
                configuration: driver=hub slots=16 speed=480Mbit/s
              *-usb:0
                   description: Video
                   product: USB2.0 HD UVC WebCam
                   vendor: Chicony Electronics Co.,Ltd.
                   physical id: 4
                   bus info: usb@1:4
                   version: 69.54
                   serial: 0x0001
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
              *-usb:1
                   description: Mouse
                   product: 2.4G Mouse
                   vendor: SHARKOON Technologies GmbH
                   physical id: 5
                   bus info: usb@1:5
                   version: 2.00
                   capabilities: usb-1.10
                   configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
              *-usb:2
                   description: Bluetooth wireless interface
                   vendor: Intel Corp.
                   physical id: 9
                   bus info: usb@1:9
                   version: 0.01
                   capabilities: bluetooth usb-2.01
                   configuration: driver=btusb maxpower=100mA speed=12Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 5.04
                capabilities: usb-3.00
                configuration: driver=hub slots=8 speed=5000Mbit/s
        *-generic:1
             product: 100 Series/C230 Series Chipset Family Thermal Subsystem
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=intel_pch_thermal latency=0
             resources: irq:18 memory:df438000-df438fff
        *-generic:2
             product: 100 Series/C230 Series Chipset Family Serial IO I2C Controller #0
             physical id: 15
             bus info: pci@0000:00:15.0
             version: 31
             width: 64 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=intel-lpss latency=0
             resources: irq:16 memory:df437000-df437fff
        *-generic:3
             product: 100 Series/C230 Series Chipset Family Serial IO I2C Controller #1
             physical id: 15.1
             bus info: pci@0000:00:15.1
             version: 31
             width: 64 bits
             clock: 33MHz
             resources: irq:17 memory:df436000-df436fff
        *-communication
             description: Communication controller
             product: 100 Series/C230 Series Chipset Family MEI Controller #1
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 31
             width: 64 bits
             clock: 33MHz
             configuration: driver=mei_me latency=0
             resources: irq:137 memory:df435000-df435fff
        *-storage
             description: SATA controller
             product: HM170/QM170 Chipset SATA Controller [AHCI Mode]
             physical id: 17
             bus info: pci@0000:00:17.0
             version: 31
             width: 32 bits
             clock: 66MHz
             capabilities: storage msi pm ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=0
             resources: irq:128 memory:df430000-df431fff memory:df434000-df4340ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:df433000-df4337ff
        *-pci:1
             product: 100 Series/C230 Series Chipset Family PCI Express Root Port #3
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: f1
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             resources: irq:123 memory:df300000-df3fffff
           *-network
                description: Wireless interface
                product: Wireless 7265
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: wlp2s0
                version: 59
                serial: a4:02:b9:2c:77:52
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=iwlwifi driverversion=5.4.6-2-MANJARO firmware=29.1654887522.0 ip=192.168.5.4 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                resources: irq:139 memory:df300000-df301fff
        *-pci:2
             product: 100 Series/C230 Series Chipset Family PCI Express Root Port #4
             physical id: 1c.3
             bus info: pci@0000:00:1c.3
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:124 ioport:d000(size=4096) memory:df200000-df2fffff
           *-generic
                description: Unassigned class
                product: RTL8411B PCI Express Card Reader
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:03:00.0
                version: 01
                width: 32 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list rom
                configuration: driver=rtsx_pci latency=0
                resources: irq:126 memory:df215000-df215fff memory:df200000-df20ffff
           *-network
                description: Ethernet interface
                product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
                physical id: 0.1
                bus info: pci@0000:03:00.1
                logical name: enp3s0f1
                version: 12
                serial: 70:8b:cd:0d:4d:d1
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl8411-2_0.0.1 07/08/13 latency=0 link=no multicast=yes port=MII
                resources: irq:19 ioport:d000(size=256) memory:df214000-df214fff memory:df210000-df213fff
        *-pci:3
             product: 100 Series/C230 Series Chipset Family PCI Express Root Port #5
             physical id: 1c.4
             bus info: pci@0000:00:1c.4
             version: f1
             width: 32 bits
             clock: 33MHz
             resources: irq:125 memory:df100000-df1fffff
           *-usb
                product: ASM1142 USB 3.1 Host Controller
                vendor: ASMedia Technology Inc.
                physical id: 0
                bus info: pci@0000:04:00.0
                version: 00
                width: 64 bits
                clock: 33MHz
                capabilities: msi msix pm pciexpress xhci bus_master cap_list
                resources: irq:16 memory:df100000-df107fff
              *-usbhost:0
                   physical id: 0
                   bus info: usb@3
                   logical name: usb3
                   version: 5.04
                   configuration: driver=hub slots=2 speed=480Mbit/s
              *-usbhost:1
                   physical id: 1
                   bus info: usb@4
                   logical name: usb4
                   version: 5.04
                   capabilities: usb-3.10
                   configuration: driver=hub slots=2 speed=10000Mbit/s
        *-isa
             description: ISA bridge
             product: HM170 Chipset LPC/eSPI Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 31
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master
             configuration: latency=0
        *-memory UNCLAIMED
             description: Memory controller
             product: 100 Series/C230 Series Chipset Family Power Management Controller
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 31
             width: 32 bits
             clock: 33MHz (30.3ns)
             capabilities: bus_master
             resources: memory:df42c000-df42ffff
        *-multimedia
             description: Audio device
             product: 100 Series/C230 Series Chipset Family HD Audio Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 31
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_hda_intel latency=32
             resources: irq:142 memory:df428000-df42bfff memory:df400000-df40ffff
        *-serial
             description: SMBus
             product: 100 Series/C230 Series Chipset Family SMBus
             physical id: 1f.4
             bus info: pci@0000:00:1f.4
             version: 31
             width: 64 bits
             clock: 33MHz
             configuration: driver=i801_smbus latency=0
             resources: irq:16 memory:df432000-df4320ff ioport:f040(size=32)
lspci:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 07)
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem (rev 31)
00:15.0 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Serial IO I2C Controller #0 (rev 31)
00:15.1 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Serial IO I2C Controller #1 (rev 31)
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
00:17.0 SATA controller: Intel Corporation HM170/QM170 Chipset SATA Controller [AHCI Mode] (rev 31)
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #3 (rev f1)
00:1c.3 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #4 (rev f1)
00:1c.4 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 (rev f1)
00:1f.0 ISA bridge: Intel Corporation HM170 Chipset LPC/eSPI Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 950M] (rev a2)
02:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
03:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
04:00.0 USB controller: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller
Running df -lh:
File system           Dim. Usati Dispon. Uso% Montato su
dev                   3,9G     0    3,9G   0% /dev
run                   3,9G  1,5M    3,9G   1% /run
/dev/sda2             466G  140G    327G  30% /
tmpfs                 3,9G  149M    3,7G   4% /dev/shm
tmpfs                 3,9G     0    3,9G   0% /sys/fs/cgroup
tmpfs                 3,9G   36K    3,9G   1% /tmp
/dev/loop4             96M   96M       0 100% /var/lib/snapd/snap/kdenlive/22
/dev/loop0            157M  157M       0 100% /var/lib/snapd/snap/gnome-3-28-1804/110
/dev/loop2            261M  261M       0 100% /var/lib/snapd/snap/kde-frameworks-5-core18/32
/dev/loop1             45M   45M       0 100% /var/lib/snapd/snap/gtk-common-themes/1353
/dev/loop5             55M   55M       0 100% /var/lib/snapd/snap/core18/1650
/dev/loop3            123M  123M       0 100% /var/lib/snapd/snap/overleaf/3
/dev/loop7            675M  675M       0 100% /var/lib/snapd/snap/android-studio/81
/dev/loop6            174M  174M       0 100% /var/lib/snapd/snap/skype/109
/dev/loop8             86M   86M       0 100% /var/lib/snapd/snap/shotcut/59
/dev/loop9            182M  182M       0 100% /var/lib/snapd/snap/spotify/36
/dev/loop10            90M   90M       0 100% /var/lib/snapd/snap/core/8268
/dev/loop11           207M  207M       0 100% /var/lib/snapd/snap/gitkraken/148
/dev/loop12            64M   64M       0 100% /var/lib/snapd/snap/handbrake-jz/142
/dev/loop13           149M  149M       0 100% /var/lib/snapd/snap/chromium/986
/dev/loop14           149M  149M       0 100% /var/lib/snapd/snap/chromium/971
/dev/loop15            45M   45M       0 100% /var/lib/snapd/snap/gtk-common-themes/1440
/dev/loop16            55M   55M       0 100% /var/lib/snapd/snap/core18/1288
tmpfs                 786M   36K    786M   1% /run/user/1000
/home/fabio/.Private  466G  140G    327G  30% /home/fabio
Could you help me to figure out this problem?
Thank you in advance.
Fabio
I would still test alternate kernels including the real time kernels and kernel 5.5.
Also try disabling your compositor and your network prior to suspending.
Thank you for your reply, @tbg.
Compositor is disabled, nothing changes with kernel 5.5. I've created this script into /lib/systemd/system-sleep/ :
#!/bin/bash
if [ "${1}" == "pre" ]; then
  # Do the thing you want before suspend here, e.g.:
        ifconfig wlp2s0 down;ifconfig enp3s0f1 down; systemctl stop NetworkManager; sync;
elif [ "${1}" == "post" ]; then
  # Do the thing you want after resume here, e.g.:
        ifconfig wlp2s0 up;ifconfig enp3s0f1 up; systemctl start NetworkManager;
fi
but still no results.
I've managed to catch dmesg log with a successful suspend and with an unsuccesful one, but I don't know where is the problem.
Succesful suspend:
[  361.217048] wlp2s0: deauthenticating from 74:36:6d:37:fe:0f by local choice (Reason: 3=DEAUTH_LEAVING)
[  361.241807] PM: suspend entry (deep)
[  361.245935] Filesystems sync: 0.004 seconds
[  361.246556] Freezing user space processes ... (elapsed 0.001 seconds) done.
[  361.248218] OOM killer disabled.
[  361.248219] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[  361.249340] printk: Suspending console(s) (use no_console_suspend to debug)
[  361.264730] sd 3:0:0:0: [sdb] Synchronizing SCSI cache
[  361.264793] sd 3:0:0:0: [sdb] Stopping disk
[  361.271011] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[  361.271065] sd 0:0:0:0: [sda] Stopping disk
[  361.548757] ACPI: EC: interrupt blocked
[  361.629989] ACPI: Preparing to enter system sleep state S3
[  361.646639] ACPI: EC: event blocked
[  361.646641] ACPI: EC: EC stopped
[  361.646642] PM: Saving platform NVS memory
[  361.646809] Disabling non-boot CPUs ...
[  361.648572] smpboot: CPU 1 is now offline
[  361.652756] smpboot: CPU 2 is now offline
[  361.656686] smpboot: CPU 3 is now offline
[  361.660794] smpboot: CPU 4 is now offline
[  361.665373] smpboot: CPU 5 is now offline
[  361.669490] smpboot: CPU 6 is now offline
[  361.673219] smpboot: CPU 7 is now offline
[  361.678172] ACPI: Low-level resume complete
[  361.678236] ACPI: EC: EC started
[  361.678236] PM: Restoring platform NVS memory
[  361.680712] Enabling non-boot CPUs ...
[  361.680750] x86: Booting SMP configuration:
[  361.680751] smpboot: Booting Node 0 Processor 1 APIC 0x2
[  361.682827] CPU1 is up
[  361.682847] smpboot: Booting Node 0 Processor 2 APIC 0x4
[  361.685032] CPU2 is up
[  361.685052] smpboot: Booting Node 0 Processor 3 APIC 0x6
[  361.687254] CPU3 is up
[  361.687273] smpboot: Booting Node 0 Processor 4 APIC 0x1
[  361.687972] CPU4 is up
[  361.687995] smpboot: Booting Node 0 Processor 5 APIC 0x3
[  361.688566] CPU5 is up
[  361.688585] smpboot: Booting Node 0 Processor 6 APIC 0x5
[  361.689268] CPU6 is up
[  361.689286] smpboot: Booting Node 0 Processor 7 APIC 0x7
[  361.689978] CPU7 is up
[  361.692272] ACPI: Waking up from system sleep state S3
[  361.707150] ACPI: EC: interrupt unblocked
[  361.754643] ACPI: EC: event unblocked
[  361.755458] usb usb3: root hub lost power or was reset
[  361.755463] usb usb4: root hub lost power or was reset
[  361.755767] sd 3:0:0:0: [sdb] Starting disk
[  361.755775] sd 0:0:0:0: [sda] Starting disk
[  361.772982] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[  361.853497] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
[  361.855136] iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
[  362.040656] usb 1-4: reset high-speed USB device number 2 using xhci_hcd
[  362.090272] ata3: SATA link down (SStatus 4 SControl 300)
[  362.090303] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[  362.090330] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[  362.091223] ata1.00: supports DRM functions and may not be fully accessible
[  362.092783] ata1.00: supports DRM functions and may not be fully accessible
[  362.093302] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[  362.093384] ata1.00: configured for UDMA/133
[  362.098768] ata2.00: configured for UDMA/133
[  362.103464] ahci 0000:00:17.0: port does not support device sleep
[  362.104086] ata4.00: configured for UDMA/133
[  362.304099] usb 1-9: reset full-speed USB device number 4 using xhci_hcd
[  362.455856] OOM killer enabled.
[  362.455858] Restarting tasks ...
[  362.456330] nouveau 0000:01:00.0: Enabling HDA controller
[  362.458672] done.
[  362.468511] Bluetooth: hci0: read Intel version: 370810011003110e00
[  362.468516] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
[  362.472285] PM: suspend exit
[  362.484363] Generic FE-GE Realtek PHY r8169-301:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-301:00, irq=IGNORE)
[  362.581035] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 619444 [ IBUS ]
[  362.584480] r8169 0000:03:00.1 enp3s0f1: Link is Down
[  362.722082] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[  362.739124] Bluetooth: hci0: Intel firmware patch completed and activated
[  367.312071] wlp2s0: authenticate with 74:36:6d:37:fe:0e
[  367.317932] wlp2s0: send auth to 74:36:6d:37:fe:0e (try 1/3)
[  367.319646] wlp2s0: authenticated
[  367.323671] wlp2s0: associate with 74:36:6d:37:fe:0e (try 1/3)
[  367.324761] wlp2s0: RX AssocResp from 74:36:6d:37:fe:0e (capab=0x11 status=0 aid=4)
[  367.325939] wlp2s0: associated
[  367.331970] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[  367.372787] wlp2s0: Limiting TX power to 17 (23 - 6) dBm as advertised by 74:36:6d:37:fe:0e
Unsuccesful one:
gen 18 11:24:35 fabio-pc systemd-logind[881]: Lid closed.
gen 18 11:24:35 fabio-pc org_kde_powerdevil[3316]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 1)))
gen 18 11:24:35 fabio-pc org_kde_powerdevil[3316]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("SkipFade", QVariant(bool, true))("Type", QVariant(uint>
gen 18 11:24:35 fabio-pc org_kde_powerdevil[3316]: powerdevil: Starting Login1 suspend job
gen 18 11:24:35 fabio-pc ksmserver[3253]: lock called
gen 18 11:24:35 fabio-pc kded5[3202]: bluedevil: About to suspend
gen 18 11:24:35 fabio-pc org_kde_powerdevil[3316]: powerdevil: Pausing all media players before sleep
gen 18 11:24:35 fabio-pc NetworkManager[885]: <info>  [1579343075.6922] manager: sleep: sleep requested (sleeping: no  enabled: yes)
gen 18 11:24:35 fabio-pc NetworkManager[885]: <info>  [1579343075.6923] device (enp3s0f1): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
gen 18 11:24:35 fabio-pc ksmserver[3253]: Lock window Id:  27262988
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 27262988
gen 18 11:24:35 fabio-pc NetworkManager[885]: <info>  [1579343075.7105] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
gen 18 11:24:35 fabio-pc NetworkManager[885]: <info>  [1579343075.7108] manager: NetworkManager state is now ASLEEP
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 69206020
gen 18 11:24:35 fabio-pc kscreenlocker_greet[13521]: Qt: Session management error: networkIdsList argument is NULL
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 69206024
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 69206032
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 69206037
gen 18 11:24:35 fabio-pc kscreenlocker_greet[13521]: kf5.kpackage: No metadata file in the package, expected it at: "/usr/share/wallpapers/Path/contents/images/"
gen 18 11:24:35 fabio-pc kscreenlocker_greet[13521]: kf5.kconfig.core: couldn't lock local file
gen 18 11:24:35 fabio-pc kscreenlocker_greet[13521]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:76:9: Unable to assign [undefined] to QStringList
gen 18 11:24:35 fabio-pc kscreenlocker_greet[13521]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75:9: Unable to assign [undefined] to int
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 69206039
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 69206041
gen 18 11:24:35 fabio-pc ksmserver[3253]: MapNotify: 69206039
gen 18 11:24:35 fabio-pc ksmserver[3253]: CreateNotify: 69206043
gen 18 11:24:35 fabio-pc ksmserver[3253]: MapNotify: 27262988
gen 18 11:24:35 fabio-pc kded5[3202]: ktp-kded-module: "screen-saver-away" presence change request: "away" ""
gen 18 11:24:35 fabio-pc kded5[3202]: ktp-kded-module: plugin queue activation: "away" ""
gen 18 11:24:35 fabio-pc systemd[1]: Starting TLP suspend/resume...
gen 18 11:24:35 fabio-pc kscreenlocker_greet[13521]: UdevQt: unable to create udev monitor connection
gen 18 11:24:36 fabio-pc ksmserver[3253]: CreateNotify: 69206056
gen 18 11:24:36 fabio-pc systemd[1]: Started TLP suspend/resume.
gen 18 11:24:36 fabio-pc kscreenlocker_greet[13521]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
gen 18 11:24:36 fabio-pc systemd[1]: Reached target Sleep.
gen 18 11:24:36 fabio-pc systemd[1]: Starting Suspend...
gen 18 11:24:36 fabio-pc kernel: wlp2s0: deauthenticating from 74:36:6d:37:fe:0e by local choice (Reason: 3=DEAUTH_LEAVING)
gen 18 11:24:36 fabio-pc wpa_supplicant[1656]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=74:36:6d:37:fe:0e reason=3 locally_generated=1
gen 18 11:24:36 fabio-pc NetworkManager[885]: <warn>  [1579343076.0441] sup-iface[0x55f246bf2220,wlp2s0]: connection disconnected (reason -3)
gen 18 11:24:36 fabio-pc avahi-daemon[878]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
gen 18 11:24:36 fabio-pc avahi-daemon[878]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::f53a:5ddb:c8d7:7cfd.
gen 18 11:24:36 fabio-pc avahi-daemon[878]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
gen 18 11:24:36 fabio-pc wpa_supplicant[1656]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/1
gen 18 11:24:36 fabio-pc avahi-daemon[878]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.8.
gen 18 11:24:36 fabio-pc avahi-daemon[878]: Withdrawing address record for fe80::f53a:5ddb:c8d7:7cfd on wlp2s0.
gen 18 11:24:36 fabio-pc avahi-daemon[878]: Withdrawing address record for 192.168.1.8 on wlp2s0.
gen 18 11:24:36 fabio-pc systemd-sleep[13671]: Suspending system...
I'm trying my best but I don't have any clue.
Which kernels exactly have you tested. I would be sure you have tested 4.14, 4.19, and at least one of the real time kernels.
This could also be a symptom of a bios that is faulty. Is your bios up to date?
I've tried:
5.5rc6
5.4.12-1
5.4.10_rt5-1
4.19.96-1
4.14.165-1
4.4.210-1
I've upgraded my BIOS firmware, but nothing changes.
Perhaps you may need to add a kernel boot parameter. If you post your full system specs maybe someone can offer suggestions.
inxi -Fxxxzac12  --no-host
My system specs:
System:    Kernel: 5.5.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.5-x86_64 root=UUID=c4401888-4dbc-45e6-b628-a592b6e29284 rw apparmor=1
           security=apparmor audit=0
           Desktop: KDE Plasma 5.17.5 tk: Qt 5.14.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: N752VX v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: N752VX v: 1.0 serial: <filter> UEFI: American Megatrends v: N752VX.303 date: 04/17/2019
Battery:   ID-1: BAT0 charge: 38.1 Wh condition: 38.1/48.2 Wh (79%) volts: 14.4/14.4 model: ASUSTeK ASUS Battery type: Li-ion
           serial: <filter> status: Not charging cycles: 159
CPU:       Topology: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S family: 6 model-id: 5E (94)
           stepping: 3 microcode: D6 L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41621
           Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 801 8: 800
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
           Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics:  Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:191b
           Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
           chip ID: 10de:139a
           Display: x11 server: X.Org 1.20.7 driver: modesetting,nouveau alternate: fbdev,intel,nv,vesa compositor: kwin_x11
           resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2) v: 4.6 Mesa 19.3.2 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:a170
           Sound Server: ALSA v: k5.5.0-1-MANJARO
Network:   Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:095a
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
           bus ID: 03:00.1 chip ID: 10ec:8168
           IF: enp3s0f1 state: down mac: <filter>
Drives:    Local Storage: total: 912.89 GiB used: 302.20 GiB (33.1%)
           ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD4 size: 465.76 GiB block size: physical: 4096 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 023 scheme: GPT
           ID-2: /dev/sdb vendor: TCSunBow model: X3 480GB size: 447.13 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 6A0 scheme: GPT
Partition: ID-1: / raw size: 465.57 GiB size: 465.56 GiB (100.00%) used: 151.10 GiB (32.5%) fs: f2fs dev: /dev/sda2
Sensors:   System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 37 C
           Fan Speeds (RPM): cpu: 1700
Info:      Processes: 261 Uptime: 2m Memory: 7.67 GiB used: 1.03 GiB (13.4%) Init: systemd v: 242 Compilers: gcc: 9.2.0
           clang: 9.0.1 Shell: bash v: 5.0.11 running in: guake inxi: 3.0.37
Any progress on this? I've seem to have the same problem and can't find any solutions for it. Always have to hard reboot my computer after waking from sleep
As I do not have your computer model it is impossible for me to troubleshoot this for you. As I stated earlier if testing different kernels does not fix this then testing different kernel boot parameters may help.
Bumping a 2 month old post without adding any extra information is rather pointless. Please post the fixes you have attempted. Even if they did not work, the information could be useful for others with similar hardware.
Empty bumps are frowned upon on technical support threads. Please post some information that will be useful to others if you insist on resurrecting an old thread.
Think I found a solution that works for me. I ended up disabling the tlp.service. Has been working great since then.
inxi -b
System:    Host: UX310 Kernel: 5.4.24-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.18.3 Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: UX310UQK v: 1.0 serial: <root required>
           Mobo: ASUSTeK model: UX310UQK v: 1.0 serial: <root required> UEFI: American Megatrends v: UX310UQK.311
           date: 04/18/2019
Battery:   ID-1: BAT0 charge: 36.1 Wh condition: 36.1/48.0 Wh (75%)
CPU:       Dual Core: Intel Core i5-7200U type: MT MCP speed: 800 MHz min/max: 400/3100 MHz
Graphics:  Device-1: Intel HD Graphics 620 driver: i915 v: kernel
           Device-2: NVIDIA GM108M [GeForce 940MX] driver: nvidia v: 440.64
           Display: x11 server: X.Org 1.20.7 driver: modesetting unloaded: nvidia resolution: 3200x1800~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.6 Mesa 19.3.5
Network:   Device-1: Intel Wireless 8260 driver: iwlwifi
Drives:    Local Storage: total: 238.47 GiB used: 56.90 GiB (23.9%)
Thank you for posting what you discovered. Sadly TLP has been causing a lot of problems lately.
With a laptop tlp is quite important to have, and you should really install it again. The proper way to troubleshoot this is to methodically work though the tlp settings changing one thing at a time.
USB and wifi/bluetooth settings are often the culprits when it comes to suspend issues with tlp configuration. If you find out anything further please post your findings.
