Hi,
After some time now my laptop (Lenovo Thinkpad t430) is not coming out of standby after closing the lid. The screen stays black and the keyboard is lighting up and also al the other leds. Strange thing is this is only happening when the laptop is running on battery. When the laptop is plugged in everything works perfectly.
I have already checked the journalctl but nothing there. I also tested this in Windows, and everything there worked. So it could not be a hardware problem.
inxi output
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=795ea06b-e993-4dba-8214-bdd87de72b9d rw quiet splash apparmor=1
Console: pty pts/0 wm: gnome-shell DM: GDM 40.1 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 2349AE1 v: ThinkPad T430
serial: PBM56ZV Chassis: type: 10 serial: PBM56ZV
Mobo: LENOVO model: 2349AE1 serial: 1ZSLY37X262 UEFI-[Legacy]: LENOVO
v: G1ETB2WW (2.72 ) date: 01/31/2017
ID-1: BAT0 charge: 47.4 Wh (68.6%) condition: 69.1/86.6 Wh (79.8%)
volts: 11.7 min: 11.1 model: SANYO 42T4799 type: Li-ion serial: 11800
status: Discharging
Info: Dual Core model: Intel Core i7-3520M socket: rPGA988B (U3E1)
note: check bits: 64 type: MT MCP arch: Ivy Bridge family: 6
model-id: 3A (58) stepping: 9 microcode: 21 cache: L1: 64 KiB L2: 4 MiB
L3: 4 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23153
Speed: 3399 MHz max: 3600 MHz base/boost: 2900/2900 volts: 0.9 V
ext-clock: 100 MHz Core speeds (MHz): 1: 3399 2: 3392 3: 1956 4: 3152
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony thinkpad t430s camera type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 04f2:b2da class-ID: 0e02
Display: server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.2.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: enp0s25 state: down mac: 28:d2:44:1d:88:48
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:4238 class-ID: 0280
IF: wlp3s0 state: up mac: 3c:a9:f4:4c:65:a8
IF-ID-1: docker0 state: down mac: 02:42:8b:b1:e0:30
IF-ID-2: vmnet1 state: unknown speed: N/A duplex: N/A
mac: 00:50:56:c0:00:01
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A
mac: 00:50:56:c0:00:08
Local Storage: total: 698.65 GiB used: 138.32 GiB (19.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250BX100SSD1
size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: 1507F00368D4 rev: MU01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: 1918E1FF5974 rev: 023 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 138.32 GiB (30.2%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17
System Temperatures: cpu: 46.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 2491
Processes: 243 Uptime: 1m wakeups: 2 Memory: 15.34 GiB
used: 1.85 GiB (12.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1572 pacman: 1528 lib: 400 flatpak: 39
snap: 5 Shell: Bash (sudo) v: 5.1.8 running-in: tilix inxi: 3.3.07
