Hi as you can probably can read in the title I am having this little problem every time my laptop suspends when I resume it the fans dont work, what do I mean by not working is that my fan speeds are capped to the last detected value before suspension, it does not change the cpu can be at 50°c or at 80°c that the fan speed is still the same (some times even 0 rpm) I have to restart every time this happens to fix it and is really annoying having to restart every time I close the laptop or it goes to suspension by idling., anyone knows how to fix this? thanks in advice. Laptop Asus x453sa cpu intel celeron n3050
Hi!
Please post the output of inxi -Fazy
and the output of journalctl -p3 -b
, the latter before and after suspending.
here is the output
inxi -Fazy
Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=bca44b08-4307-4c8f-af31-7cda41407689 rw quiet apparmor=1
security=apparmor resume=UUID=ad9dc30e-9a5d-48a3-8ef4-f0084373d167
udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel, vala-panel, plank
wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X453SA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X453SA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X453SA.302 date: 04/19/2019
ID-1: BAT0 charge: 2.6 Wh condition: 16.4/31.7 Wh (52%) volts: 7.6/7.6
model: ASUSTeK X453-42 type: Li-ion serial: N/A status: Discharging
Info: Dual Core model: Intel Celeron N3050 bits: 64 type: MCP arch: Airmont
family: 6 model-id: 4C (76) stepping: 3 microcode: 368 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6402
Speed: 480 MHz min/max: 480/2160 MHz Core speeds (MHz): 1: 480 2: 2160
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full generic retpoline, IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b1
Device-2: Realtek USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus ID: 1-4:2 chip ID: 0bda:57de serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 20.2.2
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:2284
Sound Server: ALSA v: k5.9.8-2-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8136
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:b723
IF: wlp3s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 370.45 GiB (79.5%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1J scheme: GPT
ID-1: / raw size: 24.12 GiB size: 23.61 GiB (97.91%) used: 22.12 GiB (93.7%)
fs: ext4 dev: /dev/sda8
ID-2: /home raw size: 25.22 GiB size: 24.70 GiB (97.93%)
used: 18.73 GiB (75.8%) fs: ext4 dev: /dev/sda9
ID-1: swap-1 type: partition size: 4.00 GiB used: 2.6 MiB (0.1%)
priority: -2 dev: /dev/sda7
System Temperatures: cpu: 6280.4 C mobo: 60.0 C
Fan Speeds (RPM): cpu: 2800
Processes: 207 Uptime: 2h 22m Memory: 3.63 GiB used: 777.5 MiB (20.9%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1599
pacman: 1593 lib: 453 flatpak: 0 snap: 6 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.08
before suspend (after a clean restart)
journalctl -p3 -b
-- Logs begin at Thu 2020-06-18 14:41:27 CDT, end at Sat 2020-11-21 11:47:59 CST. --
nov 21 11:46:30 luis-x453sa cntlm[916]: Username cntlm in -U is invalid
nov 21 11:46:37 luis-x453sa wpa_supplicant[906]: bgscan simple: Failed to enable signal strength monitoring
after suspension
journalctl -p3 -b
-- Logs begin at Thu 2020-06-18 14:41:27 CDT, end at Sat 2020-11-21 11:36:09 CST. --
nov 21 09:18:25 luis-x453sa cntlm[814]: Username cntlm in -U is invalid
nov 21 09:18:45 luis-x453sa systemd[1]: Failed to start Network Manager Wait Online.
nov 21 09:19:17 luis-x453sa wpa_supplicant[861]: bgscan simple: Failed to enable signal strength monitoring
nov 21 10:17:08 luis-x453sa systemd-coredump[2246]: Process 1172 (panel-26-appmen) of user 1000 dumped core.
Stack trace of thread 1172:
#0 0x00007f9c6163ac7b n/a (libgtk-3.so.0 + 0x1fac7b)
#1 0x00007f9c610a08df n/a (libgio-2.0.so.0 + 0x6c8df)
#2 0x00007f9c6100998a g_signal_emit_valist (libgobject-2.0.so.0 + 0x2f98a)
#3 0x00007f9c61009b00 g_signal_emit (libgobject-2.0.so.0 + 0x2fb00)
#4 0x00007f9c61c2275b n/a (libappmenu-xfce.so + 0x1a75b)
#5 0x00007f9c61c2350d n/a (libappmenu-xfce.so + 0x1b50d)
#6 0x00007f9c610d50f4 n/a (libgio-2.0.so.0 + 0xa10f4)
#7 0x00007f9c610d9639 n/a (libgio-2.0.so.0 + 0xa5639)
#8 0x00007f9c6113c20d n/a (libgio-2.0.so.0 + 0x10820d)
#9 0x00007f9c610d50f4 n/a (libgio-2.0.so.0 + 0xa10f4)
#10 0x00007f9c610d9639 n/a (libgio-2.0.so.0 + 0xa5639)
#11 0x00007f9c6112e340 n/a (libgio-2.0.so.0 + 0xfa340)
#12 0x00007f9c610d50f4 n/a (libgio-2.0.so.0 + 0xa10f4)
#13 0x00007f9c610d5129 n/a (libgio-2.0.so.0 + 0xa1129)
#14 0x00007f9c60ee2914 g_main_context_dispatch (libglib-2.0.so.0 + 0x52914)
#15 0x00007f9c60f367d1 n/a (libglib-2.0.so.0 + 0xa67d1)
#16 0x00007f9c60ee1e63 g_main_loop_run (libglib-2.0.so.0 + 0x51e63)
#17 0x00007f9c616214ff gtk_main (libgtk-3.so.0 + 0x1e14ff)
#18 0x0000562b07f4032d main (wrapper-2.0 + 0x332d)
#19 0x00007f9c60cef152 __libc_start_main (libc.so.6 + 0x28152)
#20 0x0000562b07f4047e _start (wrapper-2.0 + 0x347e)
Stack trace of thread 1178:
#0 0x00007f9c60dbc46f __poll (libc.so.6 + 0xf546f)
#1 0x00007f9c60f3675f n/a (libglib-2.0.so.0 + 0xa675f)
#2 0x00007f9c60ee1121 g_main_context_iteration (libglib-2.0.so.0 + 0x51121)
#3 0x00007f9c60ee1172 n/a (libglib-2.0.so.0 + 0x51172)
#4 0x00007f9c60f0fce1 n/a (libglib-2.0.so.0 + 0x7fce1)
#5 0x00007f9c605ab3e9 start_thread (libpthread.so.0 + 0x93e9)
#6 0x00007f9c60dc7293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 1179:
#2 0x00007f9c60ee1e63 g_main_loop_run (libglib-2.0.so.0 + 0x51e63)
#3 0x00007f9c61135fe8 n/a (libgio-2.0.so.0 + 0x101fe8)
Stack trace of thread 1196:
#3 0x00007f9c5e5d2c0e n/a (libdconfsettings.so + 0x5c0e)
Stack trace of thread 2244:
#0 0x00007f9c60dc1d5d syscall (libc.so.6 + 0xfad5d)
#1 0x00007f9c60f2f8bb g_cond_wait_until (libglib-2.0.so.0 + 0x9f8bb)
#2 0x00007f9c60eb2813 n/a (libglib-2.0.so.0 + 0x22813)
#3 0x00007f9c60eb29a4 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x229a4)
#4 0x00007f9c60f12c3a n/a (libglib-2.0.so.0 + 0x82c3a)
#5 0x00007f9c60f0fce1 n/a (libglib-2.0.so.0 + 0x7fce1)
#6 0x00007f9c605ab3e9 start_thread (libpthread.so.0 + 0x93e9)
#7 0x00007f9c60dc7293 __clone (libc.so.6 + 0x100293)
nov 21 11:05:32 luis-x453sa kernel: rtlwifi: AP off, try to reconnect now
nov 21 11:19:43 luis-x453sa wpa_supplicant[861]: bgscan simple: Failed to enable signal strength monitoring
nov 21 11:20:29 luis-x453sa kernel: rtlwifi: AP off, try to reconnect now
nov 21 11:35:23 luis-x453sa lightdm[2984]: gkr-pam: unable to locate daemon control file
nov 21 11:35:28 luis-x453sa wpa_supplicant[861]: bgscan simple: Failed to enable signal strength monitoring
nov 21 11:35:40 luis-x453sa wpa_supplicant[861]: bgscan simple: Failed to enable signal strength monitoring
lines 38-71/71 (END)
That CPU temperate is definitely interesting… can you run sensors
and ls -l /sys/class/hwmon/
sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +50.0°C (high = +90.0°C, crit = +90.0°C)
Core 2: +55.0°C (high = +90.0°C, crit = +90.0°C)
soc_dts1-virtual-0
Adapter: Virtual device
temp1: +52.0°C
BAT0-acpi-0
Adapter: ACPI interface
in0: 7.60 V
acpitz-acpi-0
temp1: +60.0°C (crit = +95.0°C)
temp2: +60.0°C (crit = +94.0°C)
asus-isa-0000
cpu_fan: 2900 RPM
temp1: +6280.4°C
soc_dts0-virtual-0
temp1: +51.0°C
total 0
lrwxrwxrwx 1 root root 0 nov 23 11:23 hwmon0 -> ../../devices/virtual/thermal/thermal_zone0/hwmon0
lrwxrwxrwx 1 root root 0 nov 23 16:24 hwmon1 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/ACPI0003:00/power_supply/AC0/hwmon1
lrwxrwxrwx 1 root root 0 nov 23 16:24 hwmon2 -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0A:00/power_supply/BAT0/hwmon2
lrwxrwxrwx 1 root root 0 nov 23 16:24 hwmon3 -> ../../devices/virtual/thermal/thermal_zone4/hwmon3
lrwxrwxrwx 1 root root 0 nov 23 16:24 hwmon4 -> ../../devices/virtual/thermal/thermal_zone5/hwmon4
lrwxrwxrwx 1 root root 0 nov 23 16:24 hwmon5 -> ../../devices/platform/asus-nb-wmi/hwmon/hwmon5
lrwxrwxrwx 1 root root 0 nov 23 16:24 hwmon6 -> ../../devices/platform/coretemp.0/hwmon/hwmon6
Can you check if the output of sensors
shows 0 RPM when the fans don’t spin after resuming from suspend? What’s the output of cat /sys/devices/platform/asus-nb-wmi/hwmon/hwmon*/temp1_input
? Do the fans start spinning if you run echo 2 | sudo tee /sys/devices/platform/asus-nb-wmi/hwmon/hwmon*/pwm1_enable
? What happens if you write 0
instead of 2
the output is this, is not 0 but still does not change the rpm even at 80°c
sensors
asus-isa-0000
cpu_fan: 2800 RPM
temp1: +6280.4°C
soc_dts1-virtual-0
temp1: +59.0°C
BAT0-acpi-0
in0: 7.60 V
acpitz-acpi-0
temp1: +26.8°C (crit = +95.0°C)
coretemp-isa-0000
Core 0: +59.0°C (high = +90.0°C, crit = +90.0°C)
Core 2: +63.0°C (high = +90.0°C, crit = +90.0°C)
soc_dts0-virtual-0
temp1: +58.0°C
6280350
neither with 0 or 2 happens nothing (with 0 shows an error saying that its not a valid value or something)
