Hi,
since a couple of weeks I’m experiencing some trouble with sending my laptop (Dell Precision with Nvidia GPU) into sleep mode. I have tried numerous tips and tricks everywhere to be found but to no avail. In about 30% of all cases the laptop goes into sleep mode with no hassle but most of the time it wake up again immediately and shows the lock screen. After many hours of searching through logs and trying many potential fixes, I noticed the the immediate wake only occurs if Chrome is running. After closing Chrome and waiting a couple of seconds the computer goes into sleep mode a 100% percent of the time. I have so far not found anything related to this specific problem so I would like to ask if someone else is experiencing similar problems?
Thanks for any help J.
Kernel: 6.6.99-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=9d124fda-f309-4f67-9c23-9f6ff0b2b51c rw quiet
cryptdevice=UUID=5e5690d6-7489-414d-9ffb-5003d997651a:luks-5e5690d6-7489-414d-9ffb-5003d997651a
root=/dev/mapper/luks-5e5690d6-7489-414d-9ffb-5003d997651a
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_x11 with: krunner
dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Precision 5570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 04NDTC v: A01 serial: <filter> part-nu: 0B1A
uuid: 4c4c4544-0051-4d10-8050-c6c04f4b4e33 UEFI: Dell v: 1.11.0
date: 02/14/2023
ID-1: BAT0 charge: 49.9 Wh (68.3%) condition: 73.1/84.3 Wh (86.8%)
volts: 11.4 min: 11.4 model: BYD DELL M59JH43 type: Li-poly serial: <filter>
status: discharging
System RAM: total: 32 GiB available: 31.02 GiB used: 21.16 GiB (68.2%)
igpu: 64 MiB
Device-1: DIMM A type: DDR5 detail: synchronous size: 16 GiB
speed: 4800 MT/s volts: curr: 1.1 width (bits): data: 64 total: 64
manufacturer: 80AD000080AD part-no: HMCG78MEBSA095N serial: <filter>
Device-2: DIMM B type: DDR5 detail: synchronous size: 16 GiB
Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:1c.0
children: 1: a5:00.0 class-ID: ff00 type: unassigned
Slot: 1 type: PCIe gen: 1 status: available length: long volts: 3.3
bus-ID: 00:1c.1
Slot: 2 type: PCIe gen: 2 status: available length: long volts: 3.3
bus-ID: 00:1c.2
Slot: 3 type: PCIe gen: 3 status: available length: long volts: 3.3
bus-ID: 00:1c.3
Slot: 4 type: PCIe gen: 4 status: available length: long volts: 3.3
bus-ID: 00:1c.4
Slot: 5 type: PCIe gen: 5 status: available length: long volts: 3.3
bus-ID: 00:1c.5
Slot: 6 type: PCIe gen: 6 status: available length: long volts: 3.3
bus-ID: 00:1c.6
Info: model: 12th Gen Intel Core i7-12800H socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
stepping: 3 microcode: 0x437
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4700:4800:3700 base/boost: 1881/4800
scaling: driver: intel_pstate governor: powersave volts: 0.8 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
17: 400 18: 400 19: 400 20: 400 bogomips: 112160
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Xe process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107GLM [RTX A2000 8GB Laptop GPU] vendor: Dell
driver: nvidia v: 575.64.03 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:25ba class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2 chip-ID: 0c45:6d1f
class-ID: 0e02
Display: unspecified server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 506x316mm (19.92x12.44")
s-diag: 597mm (23.49")
Monitor-1: eDP-1 model: Sharp 0x1515 built: 2021 res: mode: 1920x1200
hz: 60 scale: 100% (1) dpi: 145 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 336x210mm (13.23x8.27") diag: 396mm (15.6") ratio: 16:10
modes: 1920x1200
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
GT2) device-ID: 8086:46a6 memory: 30.3 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
RTX A2000 8GB Laptop GPU driver: nvidia v: 575.64.03 device-ID: 10de:25ba
surfaces: N/A
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.6.99-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: veth119acde state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-3: veth3cbff30 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: veth55474c9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethaf4a969 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: NetworkManager, nginx, systemd-timesyncd, wpa_supplicant
Device-1: luks-5e5690d6-7489-414d-9ffb-5003d997651a maj-min: 254:0
type: LUKS dm: dm-0 size: 953.57 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 953.57 GiB
Local Storage: total: 953.87 GiB used: 498.51 GiB (52.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 36308229 temp: 30.9 C
scheme: GPT
SMART: yes health: PASSED on: 42d 6h cycles: 230
read-units: 57,142,128 [29.2 TB] written-units: 48,096,757 [24.6 TB]
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 498.48 GiB (53.2%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-5e5690d6-7489-414d-9ffb-5003d997651a
label: N/A uuid: 9d124fda-f309-4f67-9c23-9f6ff0b2b51c
used: 36.3 MiB (12.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: C2B3-C53E
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6d1f class-ID: 0e02
Device-2: 3-9:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
System Temperatures: cpu: 46.0 C mobo: 29.0 C sodimm: 33.0 C
Fan Speeds (rpm): cpu: 0
Packages: 2926 pm: dpkg pkgs: 1463 libs: 379 pm: pacman pkgs: 1463 libs: 379
tools: pamac pm: flatpak pkgs: 0
1: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
2: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
3: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
4: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
5: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
6: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
7: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
8: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
9: https://mirror.23m.com/manjaro/stable/$repo/$arch
10: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
11: https://linorg.usp.br/manjaro/stable/$repo/$arch
12: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
14: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
15: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
16: https://mirror.koddos.net/manjaro/stable/$repo/$arch
17: https://free.nchc.org.tw/manjaro/stable/$repo/$arch
18: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
19: https://mirror.easyname.at/manjaro/stable/$repo/$arch
20: https://manjaro.mirror.ac.za/stable/$repo/$arch
21: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
22: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
23: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
24: https://mirror.fcix.net/manjaro/stable/$repo/$arch
25: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
26: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
27: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
29: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
30: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
31: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
32: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
33: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
35: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
36: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
37: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
39: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
40: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
41: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
42: https://mirrors.manjaro.org/repo/stable/$repo/$arch
43: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
44: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
46: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
47: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
48: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
49: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
50: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
51: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
53: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
54: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
55: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
56: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
57: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
58: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
59: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
60: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
61: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
62: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
63: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
64: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
65: https://manjaro.ynh.ovh/stable/$repo/$arch
66: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
67: https://mirrors2.manjaro.org/stable/$repo/$arch
68: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
69: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
70: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
71: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
72: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
73: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
74: https://manjaro.grena.ge/stable/$repo/$arch
75: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
76: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
77: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
78: https://muug.ca/mirror/manjaro/stable/$repo/$arch
79: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
80: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
81: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
82: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
83: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
84: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
85: https://mirror.dc.uz/manjaro/stable/$repo/$arch
86: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
87: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
88: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
89: https://manjaro.kurdy.org/stable/$repo/$arch
90: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
91: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
92: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
93: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
94: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
95: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
96: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
97: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
98: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
99: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
100: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
101: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
102: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
103: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
104: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
105: https://mirror.zetup.net/manjaro/stable/$repo/$arch
106: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
107: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
108: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
109: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
110: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
111: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
112: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
113: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
114: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
115: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
116: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
117: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
118: https://mirror.init7.net/manjaro/stable/$repo/$arch
119: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 495
1: cpu: 25.3% command: chrome pid: 1403098 mem: 701.0 MiB (2.2%)
2: cpu: 11.5% command: java pid: 1136756 mem: 8736.6 MiB (27.5%)
3: cpu: 5.6% command: chrome pid: 1402971 mem: 406.9 MiB (1.2%)
4: cpu: 5.4% command: chrome pid: 1403200 mem: 215.9 MiB (0.6%)
5: cpu: 4.2% command: konsole pid: 1403957 mem: 150.7 MiB (0.4%)
Memory top: 5 of 495
1: mem: 8736.6 MiB (27.5%) command: java pid: 1136756 cpu: 11.5%
2: mem: 1719.5 MiB (5.4%) command: java pid: 1175269 cpu: 0.3%
3: mem: 1695.6 MiB (5.3%) command: ng pid: 1174925 cpu: 0.3%
4: mem: 1269.2 MiB (3.9%) command: mbdaemon pid: 960 cpu: 0.6%
5: mem: 1130.0 MiB (3.5%) command: plasmashell pid: 1403 cpu: 2.4%
Processes: 495 Power: uptime: 7d 1h 51m states: freeze,mem,disk
suspend: s2idle wakeups: 42 fails: 100 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.39 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 257
Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Sudo (sudo) v: 1.9.17p1
default: Bash v: 5.3.0 running-in: konsole inxi: 3.3.38
