The issue is two part. When I close the lid, the laptop doesn’t suspend; I can see it still connected to my phone and sometimes the screen stays on. When I suspend using the power button or the menu, it suspends, but I can’t wake it. I have to force a shutdown.
inxi --admin --verbosity=7 --filter --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=c7ab94c3-0973-4ff5-969a-e338eb9dfd21 rw rootflags=subvol=@ quiet
cryptdevice=UUID=c0bcc196-2a38-44c7-a613-788ecc3139c4:luks-c0bcc196-2a38-44c7-a613-788ecc3139c4
root=/dev/mapper/luks-c0bcc196-2a38-44c7-a613-788ecc3139c4 splash apparmor=1
security=apparmor
resume=/dev/mapper/luks-066b312a-9d4e-4cea-a2d7-7a49ea25ca73
udev.log_priority=3
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: ASUSTeK product: ZenBook UX425UG_Q408UG v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX425UG v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: UX425UG.203 date: 02/05/2021
ID-1: BATT charge: 7.7 Wh (11.9%) condition: 64.6/63.1 Wh (102.3%)
volts: 12.0 min: 12.0 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: Discharging cycles: 1
RAM: total: 7.17 GiB used: 3.53 GiB (49.3%)
Info: 6-Core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 68 (104) stepping: 1
microcode: 8608103 cache: L2: 3 MiB bogomips: 50325
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 2517 3: 1396 4: 1397 5: 1459 6: 1398 7: 1397 8: 1398 9: 1397
10: 1397 11: 1397 12: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU117M [GeForce MX450] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 03:00.0
chip-ID: 10de:1f9c class-ID: 0302
Device-2: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:164c class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v6: <filter> virtual: stable-privacy scope: link
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Device-1: luks-c0bcc196-2a38-44c7-a613-788ecc3139c4 maj-min: 254:0
type: LUKS dm: dm-0 size: 229.37 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 229.37 GiB
Device-2: luks-066b312a-9d4e-4cea-a2d7-7a49ea25ca73 maj-min: 254:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
Local Storage: total: 238.47 GiB used: 15.08 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ256HAJD-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: FXV7101Q temp: 28.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 15.08 GiB (6.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c0bcc196-2a38-44c7-a613-788ecc3139c4 label: N/A
uuid: c7ab94c3-0973-4ff5-969a-e338eb9dfd21
used: 712 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 5FE9-2AC0
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/cache raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-066b312a-9d4e-4cea-a2d7-7a49ea25ca73 label: swap
uuid: 19bd7fa9-f89d-4b49-9e05-92c30cc599c8
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.1 C mobo: 0.0 C gpu: amdgpu temp: 35.0 C
Processes: 403 Uptime: 18m wakeups: 1012 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1201 pacman: 1182 lib: 302
flatpak: 19 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.08
