Laptop display stopped working
Laptop display stopped working today (external HDMI display works fine). Manufacturer splash screen is visible when I turn the pc on, and grub and tty3 open fine on laptop display, so the problem must be software related. Laptop display doesn’t appear as an option in display settings. I’m not sure what other diagnostic can I do, trying to search for this problem only returns the opposite (external display not working), but if necessary I can add any info you need.
Thanks!
post the output of the following commands first to get an impression
echo $XDG_SESSION_TYPE && glxinfo | grep server
  Kernel: 6.6.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=5cb9ddc0-fe46-4128-9394-f72ebae4d6ab rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
    wm: kwin_x11 tools: avail: xfce4-screensaver vt: 2 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
  Mobo: HP model: 86D6 v: 96.45 serial: <superuser required>
    part-nu: 9RH22EA#A2Q uuid: <superuser required> UEFI: AMI v: F.13
    date: 03/03/2022
  ID-1: BAT0 charge: 41.4 Wh (100.0%) condition: 41.4/41.4 Wh (100.0%)
    volts: 12.4 min: 11.6 model: Hewlett-Packard Primary type: Li-ion serial: N/A
    status: full cycles: 372
  System RAM: total: 16 GiB available: 13.52 GiB used: 1.44 GiB (10.7%)
  Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: HP26D4S9S8HJ-8 serial: <filter>
  Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
    unbuffered (unregistered) size: 8 GiB speed: spec: 2667 MT/s
    actual: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Kingston part-no: HP26D4S9S8HJ-8
    serial: <filter>
  Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
    built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
    stepping: 1 microcode: 0x8108109
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1556 high: 2300 min/max: 1400/2300 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1204 2: 2300
    3: 1230 4: 1400 5: 1263 6: 1400 7: 2251 8: 1400 bogomips: 36751
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
    driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
    off: HDMI-A-2 empty: none bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
  Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 79.0 C
  Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 0408:5365
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
    model: Samsung LF24T35 serial: <filter> built: 2022 res: 1920x1080 hz: 60
    dpi: 92 gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled
    model: ChiMei InnoLux 0x1515 built: 2019 res: 1920x1080 dpi: 142 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti with
    Max-Q Design/PCIe/SSE2 memory: 5.86 GiB
  API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1660 Ti with Max-Q Design driver: nvidia v: 550.90.07
    device-ID: 10de:2191 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Vega 10 Graphics (RADV RAVEN) driver: mesa radv
    v: 24.1.1-manjaro1.1 device-ID: 1002:15d8 surfaces: xcb,xlib
  Device-1: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.34-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
    chip-ID: 10ec:c822 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:b00c
  Local Storage: total: 476.94 GiB used: 243.18 GiB (51.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    lanes: 4 tech: SSD serial: <filter> fw-rev: AGHA4101 temp: 42.9 C
    scheme: GPT
  ID-1: / raw-size: 139.7 GiB size: 136.45 GiB (97.67%) used: 67.85 GiB (49.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 5cb9ddc0-fe46-4128-9394-f72ebae4d6ab
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 2F13-CD8F
  ID-3: /home raw-size: 322.06 GiB size: 315.94 GiB (98.10%)
    used: 175.33 GiB (55.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: f0bd9345-5f36-470d-a6de-de7c4b471b75
  ID-1: swap-1 type: partition size: 14.88 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 6e90721d-fc40-4f12-9f72-516d35f0867e
  Hub-1: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: A4Tech F3 V-Track Gaming Mouse type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 09da:9066 class-ID: 0301
  Device-2: 3-4:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
    interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Hub-2: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-3: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-1:2 info: Quanta HP TrueVision HD Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
  Hub-4: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 77.5 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  GPU: device: nvidia screen: :0.0 temp: 51 C device: amdgpu temp: 77.0 C
  Processes: 278 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.39 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1809 pm: pacman pkgs: 1745 libs: 488 tools: pamac pm: flatpak
    pkgs: 64 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.35
x11
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
may you check something first. open systemsettings → display and check that you can choose the internal display
and check if it is activated, if not activate
It’s there, not activated (the exact wording in system settings is “Enabled”) but when I enable it and click apply it just becomes disabled again
may you boot from a live-iso to check that the display works in a live-session to proove there’s no hardware-failure.
Have you tried the solution from this similar thread? I had the same issue after update and solution from this thread worked: Laptop Screen Goes Black
