(Laptop) Booting into Manjaro hangs when external monitor is connected
Greetings to all people in this forum!
So recently I decided to go the Manjaro route on my laptop as well.
I’ve been using Manjaro on both my desktops for nearly 2 years now and I really like it.
Never had any serious issues that I was not able to swiftly fix.
However, I am facing issues booting into Manjaro when I power on the laptop with an external monitor plugged in.
The booting process freezes after the GRUB menu with a single (non-flashing) dash on the top left of a black screen.
I cannot switch to tty, the booting process seems frozen.
If I boot into Manjaro without the external monitor and then plug it in, everything works fine.
It is the boot process that does not work.
In contrast, Windows boot fine with the external monitor plugged in.
Therefore, this is not a hardware problem (at least pertaining to the monitor, the cables, or the laptop itself).
How would I go about trying to tackle this?
Please provide with your system information, with your external monitor plugged.
Sorry for taking long to reply, I was away for a couple days.
Laptop is a Lenovo Legion 5.
I am using GNOME
uname -r
5.12.19-1-MANJARO
cat /etc/lsb-release
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=21.1.0
DISTRIB_CODENAME=Pahvo
DISTRIB_DESCRIPTION="Manjaro Linux"
lscpu
Architecture:            x86_64
  CPU op-mode(s):        32-bit, 64-bit
  Address sizes:         48 bits physical, 48 bits virtual
  Byte Order:            Little Endian
CPU(s):                  12
  On-line CPU(s) list:   0-11
Vendor ID:               AuthenticAMD
  Model name:            AMD Ryzen 5 4600H with Radeon Graphics
    CPU family:          23
    Model:               96
    Thread(s) per core:  2
    Core(s) per socket:  6
    Socket(s):           1
    Stepping:            1
    Frequency boost:     enabled
    CPU max MHz:         3000,0000
    CPU min MHz:         1400,0000
    BogoMIPS:            5990.04
    Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr ss
                         e sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_t
                         sc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe po
                         pcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalign
                         sse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc
                          mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 sme
                         p bmi2 cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_
                         llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd arat
                         npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfth
                         reshold avic v_vmsave_vmload vgif umip rdpid overflow_recov succor smca
Virtualization features:
  Virtualization:        AMD-V
Caches (sum of all):
  L1d:                   192 KiB (6 instances)
  L1i:                   192 KiB (6 instances)
  L2:                    3 MiB (6 instances)
  L3:                    8 MiB (2 instances)
NUMA:
  NUMA node(s):          1
  NUMA node0 CPU(s):     0-11
  Itlb multihit:         Not affected
  L1tf:                  Not affected
  Mds:                   Not affected
  Meltdown:              Not affected
  Spec store bypass:     Mitigation; Speculative Store Bypass disabled via prctl and seccomp
  Spectre v1:            Mitigation; usercopy/swapgs barriers and __user pointer sanitization
  Spectre v2:            Mitigation; Full AMD retpoline, IBPB conditional, IBRS_FW, STIBP conditional, RSB filling
  Srbds:                 Not affected
  Tsx async abort:       Not affected
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a809
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
04:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
05:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Zeppelin/Raven/Raven2 PCIe Dummy Function (rev c7)
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
These outputs are with the external monitor connected, as per your suggestion.
Please provide
inxi -Fazy
Here you go
inxi -Fazy
  Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
  root=UUID=bd60bfe4-216c-47a3-b221-f41f0a61e28b rw quiet splash apparmor=1
  Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
  serial: <filter> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
  v: EUCN28WW date: 10/20/2020
  ID-1: BAT0 charge: 59.4 Wh (100.0%) condition: 59.4/60.0 Wh (99.0%)
  volts: 17.5 min: 15.4 model: Celxpert L19C4PC0 type: Li-poly
  serial: <filter> status: Full cycles: 45
  Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600103 cache: L2: 3 MiB
  bogomips: 71880
  Speed: 3994 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz):
  1: 3994 2: 3988 3: 1397 4: 1396 5: 1773 6: 2257 7: 1774 8: 1774 9: 1397
  10: 1397 11: 1397 12: 1403
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f95 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
  chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: nvidia resolution: <missing: xdpyinfo>
  OpenGL: renderer: NVIDIA GeForce GTX 1650 Ti/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
  Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 10de:10fa class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
  driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  vendor: Lenovo driver: r8169 v: kernel port: 1000 bus-ID: 03:00.0
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 1000
  bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 162.72 GiB (34.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2
  lanes: 4 type: SSD serial: <filter> rev: AL2QFXV7 temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
  used: 64.37 GiB (45.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
  used: 25.6 MiB (2.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 179.69 GiB size: 175.87 GiB (97.87%)
  used: 98.26 GiB (55.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-1: swap-1 type: partition size: 3.31 GiB used: 62 MiB (1.8%) priority: -2
  dev: /dev/nvme0n1p4 maj-min: 259:4
  System Temperatures: cpu: 48.4 C mobo: N/A gpu: nvidia temp: 40 C
  Processes: 376 Uptime: 4h 3m wakeups: 1 Memory: 7.63 GiB
  used: 4.82 GiB (63.2%) Init: systemd v: 248 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1310 lib: 302 flatpak: 0
  Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
I see nothing unusual. We may need to get more basic.
Reboot with you external monitor plugged – so you reproduce the issue.
Then reboot without it – so you can actually boot – and retrieve the system logs of the previous boot.
journalctl -b -1 > ~/journalctl.log
Here is the first part of the log.
cat part1.log
-- Journal begins at Sun 2021-08-01 22:15:33 EEST, ends at Tue 2021-08-24 10:38:01 EEST. --
Αυγ 24 10:36:08 creamsoda kernel: Linux version 5.12.19-1-MANJARO (builduser@LEGION) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Tue Jul 20 20:57:37 UTC 2021
Αυγ 24 10:36:08 creamsoda kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=bd60bfe4-216c-47a3-b221-f41f0a61e28b rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
Αυγ 24 10:36:08 creamsoda kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Αυγ 24 10:36:08 creamsoda kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Αυγ 24 10:36:08 creamsoda kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Αυγ 24 10:36:08 creamsoda kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Αυγ 24 10:36:08 creamsoda kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
Αυγ 24 10:36:08 creamsoda kernel: BIOS-provided physical RAM map:
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000029fff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x000000000002a000-0x000000000002ffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000000030000-0x0000000000087fff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000000088000-0x00000000000bffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009afffff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000009b00000-0x0000000009dfffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000009e00000-0x0000000009efffff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000009f00000-0x0000000009f0cfff] ACPI NVS
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000009f0d000-0x000000009ab68fff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x000000009ab69000-0x000000009bd68fff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x000000009bd69000-0x00000000a9f7efff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000a9f7f000-0x00000000aaf7efff] type 20
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000aaf7f000-0x00000000acf7efff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000acf7f000-0x00000000adf7efff] ACPI NVS
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000adf7f000-0x00000000adffefff] ACPI data
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000adfff000-0x00000000adffffff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000ae000000-0x00000000aeffffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000fde00000-0x00000000fdefffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000fff1ffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x0000000100000000-0x000000024f33ffff] usable
Αυγ 24 10:36:08 creamsoda kernel: BIOS-e820: [mem 0x000000024f340000-0x00000002701fffff] reserved
Αυγ 24 10:36:08 creamsoda kernel: NX (Execute Disable) protection: active
Αυγ 24 10:36:08 creamsoda kernel: efi: EFI v2.70 by INSYDE Corp.
Αυγ 24 10:36:08 creamsoda kernel: efi: ACPI=0xadffe000 ACPI 2.0=0xadffe014 TPMFinalLog=0xadefc000 SMBIOS=0xab70d000 SMBIOS 3.0=0xab70b000 ESRT=0x959b5298 MEMATTR=0x95103018
Αυγ 24 10:36:08 creamsoda kernel: SMBIOS 3.2.0 present.
Αυγ 24 10:36:08 creamsoda kernel: DMI: LENOVO 82B5/LNVNB161216, BIOS EUCN28WW 10/20/2020
Αυγ 24 10:36:08 creamsoda kernel: tsc: Fast TSC calibration using PIT
Αυγ 24 10:36:08 creamsoda kernel: tsc: Detected 2994.466 MHz processor
Αυγ 24 10:36:08 creamsoda kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Αυγ 24 10:36:08 creamsoda kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Αυγ 24 10:36:08 creamsoda kernel: last_pfn = 0x24f340 max_arch_pfn = 0x400000000
Αυγ 24 10:36:08 creamsoda kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Αυγ 24 10:36:08 creamsoda kernel: last_pfn = 0xae000 max_arch_pfn = 0x400000000
Αυγ 24 10:36:08 creamsoda kernel: esrt: Reserving ESRT space from 0x00000000959b5298 to 0x00000000959b52f8.
Αυγ 24 10:36:08 creamsoda kernel: e820: update [mem 0x959b5000-0x959b5fff] usable ==> reserved
Αυγ 24 10:36:08 creamsoda kernel: check: Scanning 1 areas for low memory corruption
Αυγ 24 10:36:08 creamsoda kernel: Using GB pages for direct mapping
Αυγ 24 10:36:08 creamsoda kernel: Secure boot disabled
Αυγ 24 10:36:08 creamsoda kernel: RAMDISK: [mem 0x36d75000-0x376b1fff]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Early table checksum verification disabled
Αυγ 24 10:36:08 creamsoda kernel: ACPI: RSDP 0x00000000ADFFE014 000024 (v02 LENOVO)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: XSDT 0x00000000ADFD0188 000104 (v01 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: FACP 0x00000000ADFED000 00010C (v05 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: DSDT 0x00000000ADFDA000 00F8C1 (v01 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: FACS 0x00000000ADEF9000 000040
Αυγ 24 10:36:08 creamsoda kernel: ACPI: UEFI 0x00000000ADF7E000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFFC000 000C5D (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFF4000 007216 (v02 LENOVO CB-01    00000001 MSFT 04000000)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFF3000 000228 (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFF2000 00047E (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: TPM2 0x00000000ADFF1000 000034 (v04 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: POAT 0x00000000ADFF0000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: ASF! 0x00000000ADFEF000 0000A5 (v32 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: BOOT 0x00000000ADFEE000 000028 (v01 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: HPET 0x00000000ADFEC000 000038 (v01 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: APIC 0x00000000ADFEB000 000138 (v03 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: MCFG 0x00000000ADFEA000 00003C (v01 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFD9000 000080 (v01 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFD8000 000D0C (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFD7000 00005C (v02 LENOVO CB-01    00000001 INTL 20160527)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFD6000 00005C (v02 LENOVO CB-01    00000001 INTL 20160527)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFD5000 0000F8 (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFD2000 002B80 (v01 LENOVO CB-01    00000001 AMD  00000001)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: CRAT 0x00000000ADFD1000 000BA8 (v01 LENOVO CB-01    00000001 AMD  00000001)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: CDIT 0x00000000ADFFD000 000029 (v01 LENOVO CB-01    00000001 AMD  00000001)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFCF000 00028D (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFCB000 0030C8 (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: FPDT 0x00000000ADFCA000 000044 (v01 LENOVO CB-01    00000001      01000013)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: BGRT 0x00000000ADFC9000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: WSMT 0x00000000ADFC8000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFC7000 00007D (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: SSDT 0x00000000ADFC6000 000517 (v01 LENOVO CB-01    00000001 INTL 20130117)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving FACP table memory at [mem 0xadfed000-0xadfed10b]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving DSDT table memory at [mem 0xadfda000-0xadfe98c0]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving FACS table memory at [mem 0xadef9000-0xadef903f]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving UEFI table memory at [mem 0xadf7e000-0xadf7e235]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadffc000-0xadffcc5c]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadff4000-0xadffb215]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadff3000-0xadff3227]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadff2000-0xadff247d]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving TPM2 table memory at [mem 0xadff1000-0xadff1033]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving POAT table memory at [mem 0xadff0000-0xadff0054]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving ASF! table memory at [mem 0xadfef000-0xadfef0a4]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving BOOT table memory at [mem 0xadfee000-0xadfee027]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving HPET table memory at [mem 0xadfec000-0xadfec037]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving APIC table memory at [mem 0xadfeb000-0xadfeb137]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving MCFG table memory at [mem 0xadfea000-0xadfea03b]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfd9000-0xadfd907f]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfd8000-0xadfd8d0b]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfd7000-0xadfd705b]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfd6000-0xadfd605b]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfd5000-0xadfd50f7]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfd2000-0xadfd4b7f]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving CRAT table memory at [mem 0xadfd1000-0xadfd1ba7]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving CDIT table memory at [mem 0xadffd000-0xadffd028]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfcf000-0xadfcf28c]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfcb000-0xadfce0c7]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving FPDT table memory at [mem 0xadfca000-0xadfca043]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving BGRT table memory at [mem 0xadfc9000-0xadfc9037]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving WSMT table memory at [mem 0xadfc8000-0xadfc8027]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfc7000-0xadfc707c]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Reserving SSDT table memory at [mem 0xadfc6000-0xadfc6516]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Local APIC address 0xfee00000
Αυγ 24 10:36:08 creamsoda kernel: No NUMA configuration found
Αυγ 24 10:36:08 creamsoda kernel: Faking a node at [mem 0x0000000000000000-0x000000024f33ffff]
Αυγ 24 10:36:08 creamsoda kernel: NODE_DATA(0) allocated [mem 0x24f33c000-0x24f33ffff]
Αυγ 24 10:36:08 creamsoda kernel: Zone ranges:
Αυγ 24 10:36:08 creamsoda kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Αυγ 24 10:36:08 creamsoda kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Αυγ 24 10:36:08 creamsoda kernel:   Normal   [mem 0x0000000100000000-0x000000024f33ffff]
Αυγ 24 10:36:08 creamsoda kernel:   Device   empty
Αυγ 24 10:36:08 creamsoda kernel: Movable zone start for each node
Αυγ 24 10:36:08 creamsoda kernel: Early memory node ranges
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x0000000000001000-0x0000000000029fff]
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x0000000000030000-0x0000000000087fff]
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x0000000000100000-0x0000000009afffff]
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x0000000009e00000-0x0000000009efffff]
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x0000000009f0d000-0x000000009ab68fff]
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x000000009bd69000-0x00000000a9f7efff]
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x00000000adfff000-0x00000000adffffff]
Αυγ 24 10:36:08 creamsoda kernel:   node   0: [mem 0x0000000100000000-0x000000024f33ffff]
Αυγ 24 10:36:08 creamsoda kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000024f33ffff]
Αυγ 24 10:36:08 creamsoda kernel: On node 0 totalpages: 2063668
Αυγ 24 10:36:08 creamsoda kernel:   DMA zone: 64 pages used for memmap
Αυγ 24 10:36:08 creamsoda kernel:   DMA zone: 1135 pages reserved
Αυγ 24 10:36:08 creamsoda kernel:   DMA zone: 3969 pages, LIFO batch:0
Αυγ 24 10:36:08 creamsoda kernel:   DMA32 zone: 10730 pages used for memmap
Αυγ 24 10:36:08 creamsoda kernel:   DMA32 zone: 686707 pages, LIFO batch:63
Αυγ 24 10:36:08 creamsoda kernel:   Normal zone: 21453 pages used for memmap
Αυγ 24 10:36:08 creamsoda kernel:   Normal zone: 1372992 pages, LIFO batch:63
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone DMA: 6 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone DMA: 120 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone DMA32: 768 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone DMA32: 13 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone DMA32: 4608 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone DMA32: 16512 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone Normal: 8192 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: On node 0, zone Normal: 3264 pages in unavailable ranges
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PM-Timer IO Port: 0x408
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Αυγ 24 10:36:08 creamsoda kernel: IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
Αυγ 24 10:36:08 creamsoda kernel: IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
Αυγ 24 10:36:08 creamsoda kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: IRQ0 used by override.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: IRQ9 used by override.
Αυγ 24 10:36:08 creamsoda kernel: Using ACPI (MADT) for SMP configuration information
Αυγ 24 10:36:08 creamsoda kernel: ACPI: HPET id: 0x10228210 base: 0xfed00000
Αυγ 24 10:36:08 creamsoda kernel: e820: update [mem 0x940c3000-0x946b1fff] usable ==> reserved
Αυγ 24 10:36:08 creamsoda kernel: smpboot: Allowing 16 CPUs, 4 hotplug CPUs
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x0002a000-0x0002ffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x00088000-0x000bffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x000c0000-0x000fffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x09b00000-0x09dfffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x09f00000-0x09f0cfff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x940c3000-0x946b1fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x959b5000-0x959b5fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0x9ab69000-0x9bd68fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xa9f7f000-0xaaf7efff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xaaf7f000-0xacf7efff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xacf7f000-0xadf7efff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xadf7f000-0xadffefff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xae000000-0xaeffffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xaf000000-0xf7ffffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfddfffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfde00000-0xfdefffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfdf00000-0xfebfffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfed7ffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfed81000-0xfedfffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xfff1ffff]
Αυγ 24 10:36:08 creamsoda kernel: PM: hibernation: Registered nosave memory: [mem 0xfff20000-0xffffffff]
Αυγ 24 10:36:08 creamsoda kernel: [mem 0xaf000000-0xf7ffffff] available for PCI devices
Αυγ 24 10:36:08 creamsoda kernel: Booting paravirtualized kernel on bare hardware
Αυγ 24 10:36:08 creamsoda kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Αυγ 24 10:36:08 creamsoda kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
Αυγ 24 10:36:08 creamsoda kernel: percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
Αυγ 24 10:36:08 creamsoda kernel: pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
Αυγ 24 10:36:08 creamsoda kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
Αυγ 24 10:36:08 creamsoda kernel: Built 1 zonelists, mobility grouping on.  Total pages: 2030286
Αυγ 24 10:36:08 creamsoda kernel: Policy zone: Normal
Αυγ 24 10:36:08 creamsoda kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=bd60bfe4-216c-47a3-b221-f41f0a61e28b rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
Αυγ 24 10:36:08 creamsoda kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
Αυγ 24 10:36:08 creamsoda kernel: Memory: 7855996K/8254672K available (14344K kernel code, 2066K rwdata, 9068K rodata, 1660K init, 4272K bss, 398416K reserved, 0K cma-reserved)
Αυγ 24 10:36:08 creamsoda kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x560 with crng_init=0
Αυγ 24 10:36:08 creamsoda kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
Αυγ 24 10:36:08 creamsoda kernel: ftrace: allocating 42192 entries in 165 pages
Αυγ 24 10:36:08 creamsoda kernel: ftrace: allocated 165 pages with 4 groups
Αυγ 24 10:36:08 creamsoda kernel: rcu: Preemptible hierarchical RCU implementation.
Αυγ 24 10:36:08 creamsoda kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
Αυγ 24 10:36:08 creamsoda kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
Αυγ 24 10:36:08 creamsoda kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Αυγ 24 10:36:08 creamsoda kernel:         Trampoline variant of Tasks RCU enabled.
Αυγ 24 10:36:08 creamsoda kernel:         Rude variant of Tasks RCU enabled.
Αυγ 24 10:36:08 creamsoda kernel:         Tracing variant of Tasks RCU enabled.
Αυγ 24 10:36:08 creamsoda kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Αυγ 24 10:36:08 creamsoda kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
Αυγ 24 10:36:08 creamsoda kernel: NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
Αυγ 24 10:36:08 creamsoda kernel: Console: colour dummy device 80x25
Αυγ 24 10:36:08 creamsoda kernel: printk: console [tty0] enabled
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Core revision 20210105
Αυγ 24 10:36:08 creamsoda kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
Αυγ 24 10:36:08 creamsoda kernel: APIC: Switch to symmetric I/O mode setup
Αυγ 24 10:36:08 creamsoda kernel: Switched APIC routing to physical flat.
Αυγ 24 10:36:08 creamsoda kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Αυγ 24 10:36:08 creamsoda kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b29d96a191, max_idle_ns: 440795283357 ns
Αυγ 24 10:36:08 creamsoda kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5991.47 BogoMIPS (lpj=9981553)
Αυγ 24 10:36:08 creamsoda kernel: pid_max: default: 32768 minimum: 301
Αυγ 24 10:36:08 creamsoda kernel: LSM: Security Framework initializing
Αυγ 24 10:36:08 creamsoda kernel: Yama: becoming mindful.
Αυγ 24 10:36:08 creamsoda kernel: AppArmor: AppArmor initialized
Αυγ 24 10:36:08 creamsoda kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Αυγ 24 10:36:08 creamsoda kernel: LVT offset 1 assigned for vector 0xf9
Αυγ 24 10:36:08 creamsoda kernel: LVT offset 2 assigned for vector 0xf4
Αυγ 24 10:36:08 creamsoda kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
Αυγ 24 10:36:08 creamsoda kernel: Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
Αυγ 24 10:36:08 creamsoda kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Αυγ 24 10:36:08 creamsoda kernel: Spectre V2 : Mitigation: Full AMD retpoline
Αυγ 24 10:36:08 creamsoda kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Αυγ 24 10:36:08 creamsoda kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
Αυγ 24 10:36:08 creamsoda kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Αυγ 24 10:36:08 creamsoda kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
Αυγ 24 10:36:08 creamsoda kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Αυγ 24 10:36:08 creamsoda kernel: Freeing SMP alternatives memory: 36K
Αυγ 24 10:36:08 creamsoda kernel: smpboot: CPU0: AMD Ryzen 5 4600H with Radeon Graphics (family: 0x17, model: 0x60, stepping: 0x1)
Αυγ 24 10:36:08 creamsoda kernel: Performance Events: Fam17h+ core perfctr, AMD PMU driver.
Αυγ 24 10:36:08 creamsoda kernel: ... version:                0
Αυγ 24 10:36:08 creamsoda kernel: ... bit width:              48
Αυγ 24 10:36:08 creamsoda kernel: ... generic registers:      6
Αυγ 24 10:36:08 creamsoda kernel: ... value mask:             0000ffffffffffff
Αυγ 24 10:36:08 creamsoda kernel: ... max period:             00007fffffffffff
Αυγ 24 10:36:08 creamsoda kernel: ... fixed-purpose events:   0
Αυγ 24 10:36:08 creamsoda kernel: ... event mask:             000000000000003f
Αυγ 24 10:36:08 creamsoda kernel: rcu: Hierarchical SRCU implementation.
Αυγ 24 10:36:08 creamsoda kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Αυγ 24 10:36:08 creamsoda kernel: smp: Bringing up secondary CPUs ...
Αυγ 24 10:36:08 creamsoda kernel: x86: Booting SMP configuration:
Αυγ 24 10:36:08 creamsoda kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
Αυγ 24 10:36:08 creamsoda kernel: TSC synchronization [CPU#0 -> CPU#6]:
Αυγ 24 10:36:08 creamsoda kernel: Measured 4860 cycles TSC warp between CPUs, turning off TSC clock.
Αυγ 24 10:36:08 creamsoda kernel: tsc: Marking TSC unstable due to check_tsc_sync_source failed
Αυγ 24 10:36:08 creamsoda kernel:   #7  #8  #9 #10 #11
Αυγ 24 10:36:08 creamsoda kernel: smp: Brought up 1 node, 12 CPUs
Αυγ 24 10:36:08 creamsoda kernel: smpboot: Max logical packages: 2
Αυγ 24 10:36:08 creamsoda kernel: smpboot: Total of 12 processors activated (71895.64 BogoMIPS)
Αυγ 24 10:36:08 creamsoda kernel: devtmpfs: initialized
Αυγ 24 10:36:08 creamsoda kernel: x86/mm: Memory block size: 128MB
Αυγ 24 10:36:08 creamsoda kernel: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f0cfff] (53248 bytes)
Αυγ 24 10:36:08 creamsoda kernel: PM: Registering ACPI NVS region [mem 0xacf7f000-0xadf7efff] (16777216 bytes)
Αυγ 24 10:36:08 creamsoda kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Αυγ 24 10:36:08 creamsoda kernel: futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: pinctrl core: initialized pinctrl subsystem
Αυγ 24 10:36:08 creamsoda kernel: PM: RTC time: 07:36:07, date: 2021-08-24
Αυγ 24 10:36:08 creamsoda kernel: NET: Registered protocol family 16
Αυγ 24 10:36:08 creamsoda kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
Αυγ 24 10:36:08 creamsoda kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Αυγ 24 10:36:08 creamsoda kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Αυγ 24 10:36:08 creamsoda kernel: audit: initializing netlink subsys (disabled)
Αυγ 24 10:36:08 creamsoda kernel: audit: type=2000 audit(1629790567.146:1): state=initialized audit_enabled=0 res=1
Αυγ 24 10:36:08 creamsoda kernel: thermal_sys: Registered thermal governor 'fair_share'
Αυγ 24 10:36:08 creamsoda kernel: thermal_sys: Registered thermal governor 'bang_bang'
Αυγ 24 10:36:08 creamsoda kernel: thermal_sys: Registered thermal governor 'step_wise'
Αυγ 24 10:36:08 creamsoda kernel: thermal_sys: Registered thermal governor 'user_space'
Αυγ 24 10:36:08 creamsoda kernel: thermal_sys: Registered thermal governor 'power_allocator'
Αυγ 24 10:36:08 creamsoda kernel: cpuidle: using governor ladder
Αυγ 24 10:36:08 creamsoda kernel: cpuidle: using governor menu
Αυγ 24 10:36:08 creamsoda kernel: Simple Boot Flag at 0x44 set to 0x1
Αυγ 24 10:36:08 creamsoda kernel: ACPI: bus type PCI registered
Αυγ 24 10:36:08 creamsoda kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Αυγ 24 10:36:08 creamsoda kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
Αυγ 24 10:36:08 creamsoda kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
Αυγ 24 10:36:08 creamsoda kernel: PCI: Using configuration type 1 for base access
Αυγ 24 10:36:08 creamsoda kernel: Kprobes globally optimized
Αυγ 24 10:36:08 creamsoda kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Αυγ 24 10:36:08 creamsoda kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Added _OSI(Module Device)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Added _OSI(Processor Device)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Added _OSI(Processor Aggregator Device)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Added _OSI(Linux-Dell-Video)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: 14 ACPI AML tables successfully acquired and loaded
Αυγ 24 10:36:08 creamsoda kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Αυγ 24 10:36:08 creamsoda kernel: ACPI: EC: EC started
Αυγ 24 10:36:08 creamsoda kernel: ACPI: EC: interrupt blocked
Αυγ 24 10:36:08 creamsoda kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Interpreter enabled
Αυγ 24 10:36:08 creamsoda kernel: ACPI: (supports S0 S3 S4 S5)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Using IOAPIC for interrupt routing
Αυγ 24 10:36:08 creamsoda kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Αυγ 24 10:36:08 creamsoda kernel: ACPI: Enabled 4 GPEs in block 00 to 1F
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PM: Power Resource [PG00] (on)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PM: Power Resource [P0S0] (on)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PM: Power Resource [P3S0] (on)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PM: Power Resource [P0S1] (on)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PM: Power Resource [P3S1] (on)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000cddff])
Αυγ 24 10:36:08 creamsoda kernel: PCI host bridge to bus 0000:00
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0xb0000000-0xf7ffffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.1: [1022:1633] type 01 class 0x060400
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.2: [1022:1634] type 01 class 0x060400
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.1: [1022:1634] type 01 class 0x060400
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.2: [1022:1634] type 01 class 0x060400
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.1: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.2: [1022:1635] type 01 class 0x060400
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.2: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.0: [1022:1448] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.1: [1022:1449] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.2: [1022:144a] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.3: [1022:144b] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.4: [1022:144c] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.5: [1022:144d] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.6: [1022:144e] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:18.7: [1022:144f] type 00 class 0x060000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: [10de:1f95] type 00 class 0x030000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: reg 0x10: [mem 0xc2000000-0xc2ffffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: reg 0x14: [mem 0xb0000000-0xbfffffff 64bit pref]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: reg 0x1c: [mem 0xc0000000-0xc1ffffff 64bit pref]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: reg 0x24: [io  0x2000-0x207f]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: BAR 3: assigned to efifb
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x8 link at 0000:00:01.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.1: [10de:10fa] type 00 class 0x040300
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.1: reg 0x10: [mem 0xc3000000-0xc3003fff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.1: PCI bridge to [bus 01]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.1:   bridge window [io  0x2000-0x2fff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.1:   bridge window [mem 0xc2000000-0xc30fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.1:   bridge window [mem 0xb0000000-0xc1ffffff 64bit pref]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:02:00.0: [144d:a809] type 00 class 0x010802
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:02:00.0: reg 0x10: [mem 0xc3800000-0xc3803fff 64bit]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.2: PCI bridge to [bus 02]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:01.2:   bridge window [mem 0xc3800000-0xc38fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:03:00.0: reg 0x10: [io  0x1000-0x10ff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:03:00.0: reg 0x18: [mem 0xc3704000-0xc3704fff 64bit]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:03:00.0: reg 0x20: [mem 0xc3700000-0xc3703fff 64bit]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:03:00.0: supports D1 D2
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.1: PCI bridge to [bus 03]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.1:   bridge window [io  0x1000-0x1fff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.1:   bridge window [mem 0xc3700000-0xc37fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:04:00.0: [8086:2723] type 00 class 0x028000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:04:00.0: reg 0x10: [mem 0xc3600000-0xc3603fff 64bit]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.2: PCI bridge to [bus 04]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:02.2:   bridge window [mem 0xc3600000-0xc36fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.0: [1022:145a] type 00 class 0x130000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.0: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.2: [1022:15df] type 00 class 0x108000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.2: reg 0x18: [mem 0xc3400000-0xc34fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.2: reg 0x24: [mem 0xc3548000-0xc3549fff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.2: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.3: [1022:1639] type 00 class 0x0c0330
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.3: reg 0x10: [mem 0xc3300000-0xc33fffff 64bit]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.3: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.3: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.4: [1022:1639] type 00 class 0x0c0330
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.4: reg 0x10: [mem 0xc3200000-0xc32fffff 64bit]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.4: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.4: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.5: [1022:15e2] type 00 class 0x048000
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.5: reg 0x10: [mem 0xc3500000-0xc353ffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.5: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.5: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.6: [1022:15e3] type 00 class 0x040300
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.6: reg 0x10: [mem 0xc3540000-0xc3547fff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.6: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.6: PME# supported from D0 D3hot D3cold
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.1: PCI bridge to [bus 05]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.1:   bridge window [mem 0xc3200000-0xc35fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:06:00.0: [1022:7901] type 00 class 0x010601
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:06:00.0: reg 0x24: [mem 0xc3101000-0xc31017ff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:06:00.0: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:06:00.1: [1022:7901] type 00 class 0x010601
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:06:00.1: reg 0x24: [mem 0xc3100000-0xc31007ff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:06:00.1: enabling Extended Tags
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.2: PCI bridge to [bus 06]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:00:08.2:   bridge window [mem 0xc3100000-0xc31fffff]
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 5 6 10 11) *0, disabled.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: EC: interrupt unblocked
Αυγ 24 10:36:08 creamsoda kernel: ACPI: EC: event unblocked
Αυγ 24 10:36:08 creamsoda kernel: ACPI: EC: GPE=0x3
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
Αυγ 24 10:36:08 creamsoda kernel: iommu: Default domain type: Translated
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: vgaarb: setting as boot VGA device
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: vgaarb: bridge control possible
Αυγ 24 10:36:08 creamsoda kernel: vgaarb: loaded
Αυγ 24 10:36:08 creamsoda kernel: SCSI subsystem initialized
Αυγ 24 10:36:08 creamsoda kernel: libata version 3.00 loaded.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: bus type USB registered
Αυγ 24 10:36:08 creamsoda kernel: usbcore: registered new interface driver usbfs
Αυγ 24 10:36:08 creamsoda kernel: usbcore: registered new interface driver hub
Αυγ 24 10:36:08 creamsoda kernel: usbcore: registered new device driver usb
Αυγ 24 10:36:08 creamsoda kernel: pps_core: LinuxPPS API ver. 1 registered
Αυγ 24 10:36:08 creamsoda kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Αυγ 24 10:36:08 creamsoda kernel: PTP clock support registered
Αυγ 24 10:36:08 creamsoda kernel: EDAC MC: Ver: 3.0.0
Αυγ 24 10:36:08 creamsoda kernel: Registered efivars operations
Αυγ 24 10:36:08 creamsoda kernel: NetLabel: Initializing
Αυγ 24 10:36:08 creamsoda kernel: NetLabel:  domain hash size = 128
Αυγ 24 10:36:08 creamsoda kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Αυγ 24 10:36:08 creamsoda kernel: NetLabel:  unlabeled traffic allowed by default
Αυγ 24 10:36:08 creamsoda kernel: PCI: Using ACPI for IRQ routing
Αυγ 24 10:36:08 creamsoda kernel: PCI: pci_cache_line_size set to 64 bytes
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x0002a000-0x0002ffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x00088000-0x0008ffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x09b00000-0x0bffffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x940c3000-0x97ffffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x959b5000-0x97ffffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x9ab69000-0x9bffffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0xa9f7f000-0xabffffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0xae000000-0xafffffff]
Αυγ 24 10:36:08 creamsoda kernel: e820: reserve RAM buffer [mem 0x24f340000-0x24fffffff]
Αυγ 24 10:36:08 creamsoda kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
Αυγ 24 10:36:08 creamsoda kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
Αυγ 24 10:36:08 creamsoda kernel: clocksource: Switched to clocksource hpet
Αυγ 24 10:36:08 creamsoda kernel: VFS: Disk quotas dquot_6.6.0
Αυγ 24 10:36:08 creamsoda kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Αυγ 24 10:36:08 creamsoda kernel: AppArmor: AppArmor Filesystem Enabled
Αυγ 24 10:36:08 creamsoda kernel: pnp: PnP ACPI init
Αυγ 24 10:36:08 creamsoda kernel: system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:00: [mem 0xfde00000-0xfdefffff] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
Αυγ 24 10:36:08 creamsoda kernel: pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
Αυγ 24 10:36:08 creamsoda kernel: pnp 00:02: Plug and Play ACPI device, IDs FUJ7401 PNP0303 (active)
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x0400-0x04cf] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x04d0-0x04d1] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x04d6] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x0c00-0x0c01] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x0c14] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x0c50-0x0c52] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x0c6c] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x0c6f] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: [io  0x0cd0-0x0cdb] has been reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
Αυγ 24 10:36:08 creamsoda kernel: system 00:04: [mem 0x000e0000-0x000fffff] could not be reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:04: [mem 0xff000000-0xffffffff] could not be reserved
Αυγ 24 10:36:08 creamsoda kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c01 (active)
Αυγ 24 10:36:08 creamsoda kernel: pnp: PnP ACPI: found 5 devices
Αυγ 24 10:36:08 creamsoda kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Αυγ 24 10:36:08 creamsoda kernel: NET: Registered protocol family 2
Αυγ 24 10:36:08 creamsoda kernel: IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: TCP: Hash tables configured (established 65536 bind 65536)
Αυγ 24 10:36:08 creamsoda kernel: MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
Αυγ 24 10:36:08 creamsoda kernel: NET: Registered protocol family 44
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: BAR 6: assigned [mem 0xc3080000-0xc30fffff pref]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 18 [mem 0xb0000000-0xf7ffffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfed3ffff window]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:01: resource 0 [io  0x2000-0x2fff]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:01: resource 1 [mem 0xc2000000-0xc30fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:01: resource 2 [mem 0xb0000000-0xc1ffffff 64bit pref]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:02: resource 1 [mem 0xc3800000-0xc38fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:03: resource 0 [io  0x1000-0x1fff]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:03: resource 1 [mem 0xc3700000-0xc37fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:04: resource 1 [mem 0xc3600000-0xc36fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:05: resource 1 [mem 0xc3200000-0xc35fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci_bus 0000:06: resource 1 [mem 0xc3100000-0xc31fffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.3: quirk_usb_early_handoff+0x0/0x740 took 153046 usecs
Αυγ 24 10:36:08 creamsoda kernel: pci 0000:05:00.4: quirk_usb_early_handoff+0x0/0x740 took 43400 usecs
Αυγ 24 10:36:08 creamsoda kernel: PCI: CLS 64 bytes, default 64
Αυγ 24 10:36:08 creamsoda kernel: Trying to unpack rootfs image as initramfs...
Αυγ 24 10:36:08 creamsoda kernel: Freeing initrd memory: 9460K
Αυγ 24 10:36:08 creamsoda kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Αυγ 24 10:36:08 creamsoda kernel: software IO TLB: mapped [mem 0x00000000a4ffc000-0x00000000a8ffc000] (64MB)
Αυγ 24 10:36:08 creamsoda kernel: amd_uncore: 4  amd_df counters detected
Αυγ 24 10:36:08 creamsoda kernel: amd_uncore: 6  amd_l3 counters detected
Αυγ 24 10:36:08 creamsoda kernel: LVT offset 0 assigned for vector 0x400
Αυγ 24 10:36:08 creamsoda kernel: perf: AMD IBS detected (0x000003ff)
Αυγ 24 10:36:08 creamsoda kernel: check: Scanning for low memory corruption every 60 seconds
Αυγ 24 10:36:08 creamsoda kernel: Initialise system trusted keyrings
Αυγ 24 10:36:08 creamsoda kernel: Key type blacklist registered
Αυγ 24 10:36:08 creamsoda kernel: workingset: timestamp_bits=41 max_order=21 bucket_order=0
Αυγ 24 10:36:08 creamsoda kernel: zbud: loaded
Αυγ 24 10:36:08 creamsoda kernel: Key type asymmetric registered
Αυγ 24 10:36:08 creamsoda kernel: Asymmetric key parser 'x509' registered
Αυγ 24 10:36:08 creamsoda kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
Αυγ 24 10:36:08 creamsoda kernel: io scheduler mq-deadline registered
Αυγ 24 10:36:08 creamsoda kernel: io scheduler kyber registered
Αυγ 24 10:36:08 creamsoda kernel: io scheduler bfq registered
Αυγ 24 10:36:08 creamsoda kernel: pcieport 0000:00:01.1: PME: Signaling with IRQ 25
Αυγ 24 10:36:08 creamsoda kernel: pcieport 0000:00:01.2: PME: Signaling with IRQ 26
Αυγ 24 10:36:08 creamsoda kernel: pcieport 0000:00:02.1: PME: Signaling with IRQ 27
Αυγ 24 10:36:08 creamsoda kernel: pcieport 0000:00:02.2: PME: Signaling with IRQ 28
Αυγ 24 10:36:08 creamsoda kernel: pcieport 0000:00:08.1: PME: Signaling with IRQ 29
Αυγ 24 10:36:08 creamsoda kernel: pcieport 0000:00:08.2: PME: Signaling with IRQ 30
Αυγ 24 10:36:08 creamsoda kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Αυγ 24 10:36:08 creamsoda kernel: efifb: probing for efifb
Αυγ 24 10:36:08 creamsoda kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Αυγ 24 10:36:08 creamsoda kernel: efifb: framebuffer at 0xc1000000, using 3072k, total 3072k
Αυγ 24 10:36:08 creamsoda kernel: efifb: mode is 1024x768x32, linelength=4096, pages=1
Αυγ 24 10:36:08 creamsoda kernel: efifb: scrolling: redraw
Αυγ 24 10:36:08 creamsoda kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Αυγ 24 10:36:08 creamsoda kernel: fbcon: Deferring console take-over
Αυγ 24 10:36:08 creamsoda kernel: fb0: EFI VGA frame buffer device
Αυγ 24 10:36:08 creamsoda kernel: ACPI: AC: AC Adapter [ADP0] (off-line)
Αυγ 24 10:36:08 creamsoda kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
Αυγ 24 10:36:08 creamsoda kernel: ACPI: button: Lid Switch [LID0]
Αυγ 24 10:36:08 creamsoda kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
Αυγ 24 10:36:08 creamsoda kernel: ACPI: button: Power Button [PWRB]
Αυγ 24 10:36:08 creamsoda kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Αυγ 24 10:36:08 creamsoda kernel: ACPI: button: Power Button [PWRF]
Αυγ 24 10:36:08 creamsoda kernel: Monitor-Mwait will be used to enter C-1 state
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C000: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: FW issue: working around C-state latencies out of order
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C001: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C002: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C003: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C004: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C005: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C006: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C007: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C008: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C009: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C00A: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PLTF.C00B: Found 3 idle states
Αυγ 24 10:36:08 creamsoda kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Αυγ 24 10:36:08 creamsoda kernel: Non-volatile memory driver v1.3
Αυγ 24 10:36:08 creamsoda kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
Αυγ 24 10:36:08 creamsoda kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
Αυγ 24 10:36:08 creamsoda kernel: nvme nvme0: pci function 0000:02:00.0
Αυγ 24 10:36:08 creamsoda kernel: ahci 0000:06:00.0: version 3.0
Αυγ 24 10:36:08 creamsoda kernel: ahci 0000:06:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
Αυγ 24 10:36:08 creamsoda kernel: ahci 0000:06:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
Αυγ 24 10:36:08 creamsoda kernel: scsi host0: ahci
Αυγ 24 10:36:08 creamsoda kernel: ata1: SATA max UDMA/133 abar m2048@0xc3101000 port 0xc3101100 irq 32
Αυγ 24 10:36:08 creamsoda kernel: ahci 0000:06:00.1: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
Αυγ 24 10:36:08 creamsoda kernel: ahci 0000:06:00.1: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
Αυγ 24 10:36:08 creamsoda kernel: scsi host1: ahci
Αυγ 24 10:36:08 creamsoda kernel: ata2: SATA max UDMA/133 abar m2048@0xc3100000 port 0xc3100100 irq 36
Αυγ 24 10:36:08 creamsoda kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Αυγ 24 10:36:08 creamsoda kernel: ehci-pci: EHCI PCI platform driver
Αυγ 24 10:36:08 creamsoda kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Αυγ 24 10:36:08 creamsoda kernel: ohci-pci: OHCI PCI platform driver
Αυγ 24 10:36:08 creamsoda kernel: uhci_hcd: USB Universal Host Controller Interface driver
Αυγ 24 10:36:08 creamsoda kernel: usbcore: registered new interface driver usbserial_generic
Αυγ 24 10:36:08 creamsoda kernel: usbserial: USB Serial support registered for generic
Αυγ 24 10:36:08 creamsoda kernel: rtc_cmos 00:01: RTC can wake from S4
Αυγ 24 10:36:08 creamsoda kernel: rtc_cmos 00:01: registered as rtc0
Αυγ 24 10:36:08 creamsoda kernel: rtc_cmos 00:01: setting system clock to 2021-08-24T07:36:07 UTC (1629790567)
Αυγ 24 10:36:08 creamsoda kernel: rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
Αυγ 24 10:36:08 creamsoda kernel: ledtrig-cpu: registered to indicate activity on CPUs
Αυγ 24 10:36:08 creamsoda kernel: hid: raw HID events driver (C) Jiri Kosina
Αυγ 24 10:36:08 creamsoda kernel: ashmem: initialized
Αυγ 24 10:36:08 creamsoda kernel: drop_monitor: Initializing network drop monitor service
Αυγ 24 10:36:08 creamsoda kernel: Initializing XFRM netlink socket
Αυγ 24 10:36:08 creamsoda kernel: NET: Registered protocol family 10
Αυγ 24 10:36:08 creamsoda kernel: Segment Routing with IPv6
Αυγ 24 10:36:08 creamsoda kernel: RPL Segment Routing with IPv6
Αυγ 24 10:36:08 creamsoda kernel: NET: Registered protocol family 17
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU0: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU1: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU2: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU3: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU4: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU5: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU6: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU7: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU8: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU9: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU10: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: CPU11: patch_level=0x08600103
Αυγ 24 10:36:08 creamsoda kernel: microcode: Microcode Update Driver: v2.2.
Αυγ 24 10:36:08 creamsoda kernel: resctrl: L3 allocation detected
Αυγ 24 10:36:08 creamsoda kernel: resctrl: L3DATA allocation detected
Αυγ 24 10:36:08 creamsoda kernel: resctrl: L3CODE allocation detected
Αυγ 24 10:36:08 creamsoda kernel: resctrl: MB allocation detected
Αυγ 24 10:36:08 creamsoda kernel: resctrl: L3 monitoring detected
Αυγ 24 10:36:08 creamsoda kernel: IPI shorthand broadcast: enabled
Αυγ 24 10:36:08 creamsoda kernel: registered taskstats version 1
Αυγ 24 10:36:08 creamsoda kernel: Loading compiled-in X.509 certificates
Αυγ 24 10:36:08 creamsoda kernel: nvme nvme0: Shutdown timeout set to 8 seconds
Αυγ 24 10:36:08 creamsoda kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 9e164286bf6f0919a4733921a1d08c252456b366'
Αυγ 24 10:36:08 creamsoda kernel: zswap: loaded using pool zstd/z3fold
Αυγ 24 10:36:08 creamsoda kernel: Key type ._fscrypt registered
Αυγ 24 10:36:08 creamsoda kernel: Key type .fscrypt registered
Αυγ 24 10:36:08 creamsoda kernel: Key type fscrypt-provisioning registered
Αυγ 24 10:36:08 creamsoda kernel: AppArmor: AppArmor sha1 policy hashing enabled
Αυγ 24 10:36:08 creamsoda kernel: PM:   Magic number: 1:139:623
Αυγ 24 10:36:08 creamsoda kernel: acpi AMDI0020:03: hash matches
Αυγ 24 10:36:08 creamsoda kernel: RAS: Correctable Errors collector initialized.
Αυγ 24 10:36:08 creamsoda kernel: Unstable clock detected, switching default tracing clock to "global"
                                     If you want to keep using the local clock, then add:
                                       "trace_clock=local"
                                     on the kernel command line
Αυγ 24 10:36:08 creamsoda kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Αυγ 24 10:36:08 creamsoda kernel: ACPI: battery: Slot [BAT0] (battery present)
Αυγ 24 10:36:08 creamsoda kernel: nvme nvme0: 12/0/0 default/read/poll queues
Αυγ 24 10:36:08 creamsoda kernel:  nvme0n1: p1 p2 p3 p4 p5 p6
Αυγ 24 10:36:08 creamsoda kernel: ata1: SATA link down (SStatus 0 SControl 300)
Αυγ 24 10:36:08 creamsoda kernel: ata2: SATA link down (SStatus 0 SControl 300)
Αυγ 24 10:36:08 creamsoda kernel: Freeing unused decrypted memory: 2036K
Αυγ 24 10:36:08 creamsoda kernel: Freeing unused kernel image (initmem) memory: 1660K
Αυγ 24 10:36:08 creamsoda kernel: Write protecting the kernel read-only data: 26624k
Αυγ 24 10:36:08 creamsoda kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
Αυγ 24 10:36:08 creamsoda kernel: Freeing unused kernel image (rodata/data gap) memory: 1172K
Αυγ 24 10:36:08 creamsoda kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Αυγ 24 10:36:08 creamsoda kernel: rodata_test: all tests were successful
Αυγ 24 10:36:08 creamsoda kernel: Run /init as init process
Αυγ 24 10:36:08 creamsoda kernel:   with arguments:
Αυγ 24 10:36:08 creamsoda kernel:     /init
Αυγ 24 10:36:08 creamsoda kernel:     splash
Αυγ 24 10:36:08 creamsoda kernel:   with environment:
Αυγ 24 10:36:08 creamsoda kernel:     HOME=/
Αυγ 24 10:36:08 creamsoda kernel:     TERM=linux
Αυγ 24 10:36:08 creamsoda kernel:     BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.3: xHCI Host Controller
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 1
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
Αυγ 24 10:36:08 creamsoda kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.12
Αυγ 24 10:36:08 creamsoda kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Αυγ 24 10:36:08 creamsoda kernel: usb usb1: Product: xHCI Host Controller
Αυγ 24 10:36:08 creamsoda kernel: usb usb1: Manufacturer: Linux 5.12.19-1-MANJARO xhci-hcd
Αυγ 24 10:36:08 creamsoda kernel: usb usb1: SerialNumber: 0000:05:00.3
Αυγ 24 10:36:08 creamsoda kernel: hub 1-0:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 1-0:1.0: 4 ports detected
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 2
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
Αυγ 24 10:36:08 creamsoda kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Αυγ 24 10:36:08 creamsoda kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.12
Αυγ 24 10:36:08 creamsoda kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Αυγ 24 10:36:08 creamsoda kernel: usb usb2: Product: xHCI Host Controller
Αυγ 24 10:36:08 creamsoda kernel: usb usb2: Manufacturer: Linux 5.12.19-1-MANJARO xhci-hcd
Αυγ 24 10:36:08 creamsoda kernel: usb usb2: SerialNumber: 0000:05:00.3
Αυγ 24 10:36:08 creamsoda kernel: hub 2-0:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 2-0:1.0: 2 ports detected
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.4: xHCI Host Controller
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 3
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
Αυγ 24 10:36:08 creamsoda kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.12
Αυγ 24 10:36:08 creamsoda kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Αυγ 24 10:36:08 creamsoda kernel: usb usb3: Product: xHCI Host Controller
Αυγ 24 10:36:08 creamsoda kernel: usb usb3: Manufacturer: Linux 5.12.19-1-MANJARO xhci-hcd
Αυγ 24 10:36:08 creamsoda kernel: usb usb3: SerialNumber: 0000:05:00.4
Αυγ 24 10:36:08 creamsoda kernel: i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
Αυγ 24 10:36:08 creamsoda kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Αυγ 24 10:36:08 creamsoda kernel: hub 3-0:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 3-0:1.0: 4 ports detected
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 4
Αυγ 24 10:36:08 creamsoda kernel: xhci_hcd 0000:05:00.4: Host supports USB 3.1 Enhanced SuperSpeed
Αυγ 24 10:36:08 creamsoda kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Αυγ 24 10:36:08 creamsoda kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.12
Αυγ 24 10:36:08 creamsoda kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Αυγ 24 10:36:08 creamsoda kernel: usb usb4: Product: xHCI Host Controller
Αυγ 24 10:36:08 creamsoda kernel: usb usb4: Manufacturer: Linux 5.12.19-1-MANJARO xhci-hcd
Αυγ 24 10:36:08 creamsoda kernel: usb usb4: SerialNumber: 0000:05:00.4
Αυγ 24 10:36:08 creamsoda kernel: hub 4-0:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 4-0:1.0: 2 ports detected
Αυγ 24 10:36:08 creamsoda kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Αυγ 24 10:36:08 creamsoda kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
Αυγ 24 10:36:08 creamsoda kernel: random: fast init done
Αυγ 24 10:36:08 creamsoda kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
Αυγ 24 10:36:08 creamsoda kernel: usb 1-1: new high-speed USB device number 2 using xhci_hcd
Αυγ 24 10:36:08 creamsoda kernel: usb 3-1: new high-speed USB device number 2 using xhci_hcd
Αυγ 24 10:36:08 creamsoda systemd[1]: systemd 248.7-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
Αυγ 24 10:36:08 creamsoda systemd[1]: Detected architecture x86-64.
Αυγ 24 10:36:08 creamsoda systemd[1]: Hostname set to <creamsoda>.
Αυγ 24 10:36:08 creamsoda kernel: usb 3-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=23.07
Αυγ 24 10:36:08 creamsoda kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Αυγ 24 10:36:08 creamsoda kernel: usb 3-1: Product: USB2.1 Hub
Αυγ 24 10:36:08 creamsoda kernel: usb 3-1: Manufacturer: GenesysLogic
Αυγ 24 10:36:08 creamsoda kernel: usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
Αυγ 24 10:36:08 creamsoda kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Αυγ 24 10:36:08 creamsoda kernel: usb 1-1: Product: USB2.0 Hub
Αυγ 24 10:36:08 creamsoda kernel: usb 1-1: Manufacturer: GenesysLogic
Αυγ 24 10:36:08 creamsoda kernel: hub 1-1:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 1-1:1.0: 4 ports detected
Αυγ 24 10:36:08 creamsoda kernel: hub 3-1:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 3-1:1.0: 2 ports detected
Αυγ 24 10:36:08 creamsoda kernel: random: lvmconfig: uninitialized urandom read (4 bytes read)
Αυγ 24 10:36:08 creamsoda kernel: usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
Αυγ 24 10:36:08 creamsoda kernel: usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
Αυγ 24 10:36:08 creamsoda kernel: usb 2-1: New USB device found, idVendor=05e3, idProduct=0612, bcdDevice=92.24
Αυγ 24 10:36:08 creamsoda kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Αυγ 24 10:36:08 creamsoda kernel: usb 2-1: Product: USB3.0 Hub
Αυγ 24 10:36:08 creamsoda kernel: usb 2-1: Manufacturer: GenesysLogic
Αυγ 24 10:36:08 creamsoda kernel: usb 4-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=23.07
Αυγ 24 10:36:08 creamsoda kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Αυγ 24 10:36:08 creamsoda kernel: usb 4-1: Product: USB3.2 Hub
Αυγ 24 10:36:08 creamsoda kernel: usb 4-1: Manufacturer: GenesysLogic
Αυγ 24 10:36:08 creamsoda kernel: hub 2-1:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 2-1:1.0: 4 ports detected
Αυγ 24 10:36:08 creamsoda kernel: hub 4-1:1.0: USB hub found
Αυγ 24 10:36:08 creamsoda kernel: hub 4-1:1.0: 2 ports detected
Αυγ 24 10:36:08 creamsoda systemd[1]: Queued start job for default target Graphical Interface.
Αυγ 24 10:36:08 creamsoda systemd[1]: Created slice Slice /system/getty.
Αυγ 24 10:36:08 creamsoda systemd[1]: Created slice Slice /system/modprobe.
Αυγ 24 10:36:08 creamsoda systemd[1]: Created slice Slice /system/systemd-fsck.
Αυγ 24 10:36:08 creamsoda systemd[1]: Created slice User and Session Slice.
Αυγ 24 10:36:08 creamsoda systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Αυγ 24 10:36:08 creamsoda systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Αυγ 24 10:36:08 creamsoda systemd[1]: Reached target Login Prompts.
Αυγ 24 10:36:08 creamsoda systemd[1]: Reached target Remote File Systems.
Αυγ 24 10:36:08 creamsoda systemd[1]: Reached target Slice Units.
Αυγ 24 10:36:08 creamsoda systemd[1]: Reached target Local Verity Integrity Protected Volumes.
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on Device-mapper event daemon FIFOs.
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on LVM2 poll daemon socket.
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on Process Core Dump Socket.
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on Journal Audit Socket.
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on Journal Socket (/dev/log).
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on Journal Socket.
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on udev Control Socket.
Αυγ 24 10:36:08 creamsoda systemd[1]: Listening on udev Kernel Socket.
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounting Huge Pages File System...
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounting POSIX Message Queue File System...
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounting Kernel Debug File System...
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounting Kernel Trace File System...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Load AppArmor profiles...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Create List of Static Device Nodes...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Load Kernel Module configfs...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Load Kernel Module drm...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Load Kernel Module fuse...
Αυγ 24 10:36:08 creamsoda kernel: random: lvm: uninitialized urandom read (4 bytes read)
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Load Kernel Modules...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Remount Root and Kernel File Systems...
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Coldplug All udev Devices...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Setup Virtual Console...
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounted Huge Pages File System.
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounted POSIX Message Queue File System.
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounted Kernel Debug File System.
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounted Kernel Trace File System.
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Create List of Static Device Nodes.
Αυγ 24 10:36:08 creamsoda systemd[1]: modprobe@configfs.service: Deactivated successfully.
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Load Kernel Module configfs.
Αυγ 24 10:36:08 creamsoda systemd[1]: modprobe@drm.service: Deactivated successfully.
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Load Kernel Module drm.
Αυγ 24 10:36:08 creamsoda kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null). Quota mode: none.
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounting Kernel Configuration File System...
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Remount Root and Kernel File Systems.
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Load/Save Random Seed...
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in Create System Users being skipped.
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Create Static Device Nodes in /dev...
Αυγ 24 10:36:08 creamsoda kernel: Linux agpgart interface v0.103
Αυγ 24 10:36:08 creamsoda kernel: fuse: init (API version 7.33)
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounted Kernel Configuration File System.
Αυγ 24 10:36:08 creamsoda systemd[1]: modprobe@fuse.service: Deactivated successfully.
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Load Kernel Module fuse.
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounting FUSE Control File System...
Αυγ 24 10:36:08 creamsoda systemd[1]: Mounted FUSE Control File System.
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Create Static Device Nodes in /dev.
Αυγ 24 10:36:08 creamsoda systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Journal Service...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Rule-based Manager for Device Events and Files...
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Setup Virtual Console.
Αυγ 24 10:36:08 creamsoda kernel: usb 1-3: new high-speed USB device number 3 using xhci_hcd
Αυγ 24 10:36:08 creamsoda kernel: usb 3-3: new full-speed USB device number 3 using xhci_hcd
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1130 audit(1629790568.749:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda systemd[1]: Reached target Preparation for Local File Systems.
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1400 audit(1629790568.753:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=298 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda systemd[1]: Started Rule-based Manager for Device Events and Files.
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1130 audit(1629790568.773:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1400 audit(1629790568.783:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=300 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda systemd-journald[310]: Journal started
Αυγ 24 10:36:08 creamsoda systemd-journald[310]: Runtime Journal (/run/log/journal/e683230b568045a7af2b17f996d95737) is 8.0M, max 390.7M, 382.7M free.
Αυγ 24 10:36:08 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda audit[298]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=298 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda audit[300]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=300 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda systemd-modules-load[285]: Inserted module 'crypto_user'
Αυγ 24 10:36:08 creamsoda systemd-random-seed[295]: Kernel entropy pool is not initialized yet, waiting until it is.
Αυγ 24 10:36:08 creamsoda apparmor.systemd[278]: Restarting AppArmor
Αυγ 24 10:36:08 creamsoda apparmor.systemd[278]: Reloading AppArmor profiles
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Flush Journal to Persistent Storage...
Αυγ 24 10:36:08 creamsoda systemd[1]: Started Journal Service.
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1130 audit(1629790568.786:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda haveged[309]: haveged: command socket is listening at fd 3
Αυγ 24 10:36:08 creamsoda audit[300]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=300 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1400 audit(1629790568.793:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=300 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda systemd-journald[310]: Time spent on flushing to /var/log/journal/e683230b568045a7af2b17f996d95737 is 82.658ms for 914 entries.
Αυγ 24 10:36:08 creamsoda systemd-journald[310]: System Journal (/var/log/journal/e683230b568045a7af2b17f996d95737) is 448.1M, max 4.0G, 3.5G free.
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1400 audit(1629790568.836:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=302 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1130 audit(1629790568.859:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda kernel: acpi_cpufreq: overriding BIOS provided _PSD data
Αυγ 24 10:36:08 creamsoda kernel: audit: type=1400 audit(1629790568.863:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=301 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda kernel: usb 3-3: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
Αυγ 24 10:36:08 creamsoda kernel: usb 3-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Αυγ 24 10:36:08 creamsoda kernel: usb 1-3: New USB device found, idVendor=04f2, idProduct=b6c2, bcdDevice=27.14
Αυγ 24 10:36:08 creamsoda kernel: usb 1-3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Αυγ 24 10:36:08 creamsoda kernel: usb 1-3: Product: Integrated Camera
Αυγ 24 10:36:08 creamsoda kernel: usb 1-3: Manufacturer: Chicony Electronics Co.,Ltd.
Αυγ 24 10:36:08 creamsoda kernel: usb 1-3: SerialNumber: 0001
Αυγ 24 10:36:08 creamsoda kernel: ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
Αυγ 24 10:36:08 creamsoda kernel: usb 1-1.2: new full-speed USB device number 4 using xhci_hcd
Αυγ 24 10:36:08 creamsoda kernel: ACPI: video: Video Device [PEGP] (multi-head: yes  rom: no  post: no)
Αυγ 24 10:36:08 creamsoda audit[302]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=302 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda audit[301]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=301 comm="apparmor_parser"
Αυγ 24 10:36:08 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=plymouth-start comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Coldplug All udev Devices.
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting Show Plymouth Boot Screen...
Αυγ 24 10:36:08 creamsoda systemd[1]: Started Show Plymouth Boot Screen.
Αυγ 24 10:36:08 creamsoda systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
Αυγ 24 10:36:08 creamsoda systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Αυγ 24 10:36:08 creamsoda systemd[1]: Reached target Local Encrypted Volumes.
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Αυγ 24 10:36:08 creamsoda kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Αυγ 24 10:36:08 creamsoda systemd[1]: Finished Flush Journal to Persistent Storage.
Αυγ 24 10:36:08 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:08 creamsoda kernel: acpi device:01: registered as cooling_device12
Αυγ 24 10:36:08 creamsoda kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input4
Αυγ 24 10:36:08 creamsoda kernel: ACPI: video: Video Device [VGA] (multi-head: yes  rom: no  post: no)
Αυγ 24 10:36:08 creamsoda kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20210105/psargs-330)
Αυγ 24 10:36:08 creamsoda kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20210105/psparse-529)
Αυγ 24 10:36:08 creamsoda kernel: ACPI: \_SB_.PCI0.GP17.VGA_.LCD_: _BCM evaluation failed
Αυγ 24 10:36:08 creamsoda kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0e/LNXVIDEO:01/input/input5
Αυγ 24 10:36:08 creamsoda systemd[1]: Found device SAMSUNG MZALQ512HALU-000L2 3.
Αυγ 24 10:36:08 creamsoda systemd[1]: Found device SAMSUNG MZALQ512HALU-000L2 1.
Αυγ 24 10:36:08 creamsoda systemd[1]: Found device SAMSUNG MZALQ512HALU-000L2 4.
Αυγ 24 10:36:08 creamsoda systemd[1]: Activating swap Swap Partition...
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting File System Check on /dev/disk/by-uuid/7419-D98D...
Αυγ 24 10:36:08 creamsoda kernel: random: mktemp: uninitialized urandom read (6 bytes read)
Αυγ 24 10:36:08 creamsoda systemd[1]: Starting File System Check on /dev/disk/by-uuid/c58f94bb-b1d9-4f64-95b4-2e80deedf035...
Αυγ 24 10:36:08 creamsoda kernel: snd_rn_pci_acp3x 0000:05:00.5: enabling device (0000 -> 0002)
Αυγ 24 10:36:08 creamsoda kernel: ccp 0000:05:00.2: enabling device (0000 -> 0002)
Αυγ 24 10:36:08 creamsoda kernel: ccp 0000:05:00.2: ccp: unable to access the device: you might be running a broken BIOS.
Αυγ 24 10:36:09 creamsoda kernel: input: MSFT0001:00 04F3:3186 Mouse as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0001/input/input6
Αυγ 24 10:36:09 creamsoda kernel: input: MSFT0001:00 04F3:3186 Touchpad as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0001/input/input7
Αυγ 24 10:36:09 creamsoda kernel: hid-generic 0018:04F3:3186.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:00 04F3:3186] on i2c-MSFT0001:00
Αυγ 24 10:36:09 creamsoda kernel: ccp 0000:05:00.2: tee enabled
Αυγ 24 10:36:09 creamsoda kernel: ccp 0000:05:00.2: psp enabled
Αυγ 24 10:36:09 creamsoda systemd-fsck[390]: /dev/nvme0n1p3: clean, 142443/11780096 files, 26841546/47104000 blocks
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished File System Check on /dev/disk/by-uuid/c58f94bb-b1d9-4f64-95b4-2e80deedf035.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-c58f94bb\x2db1d9\x2d4f64\x2d95b4\x2d2e80deedf035 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Mounting /home...
Αυγ 24 10:36:09 creamsoda kernel: Adding 3466236k swap on /dev/nvme0n1p4.  Priority:-2 extents:1 across:3466236k SSFS
Αυγ 24 10:36:09 creamsoda haveged[309]: haveged: ver: 1.9.14; arch: x86; vend: ; build: (gcc 10.2.0 ITV); collect: 128K
Αυγ 24 10:36:09 creamsoda haveged[309]: haveged: cpu: (VC); data: 32K (V); inst: 32K (V); idx: 24/40; sz: 32154/54019
Αυγ 24 10:36:09 creamsoda haveged[309]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.00379
Αυγ 24 10:36:09 creamsoda haveged[309]: haveged: fills: 0, generated: 0
Αυγ 24 10:36:09 creamsoda systemd[1]: Activated swap Swap Partition.
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Swaps.
Αυγ 24 10:36:09 creamsoda systemd[1]: Mounting Temporary Directory /tmp...
Αυγ 24 10:36:09 creamsoda kernel: usb 3-4: new full-speed USB device number 4 using xhci_hcd
Αυγ 24 10:36:09 creamsoda systemd[1]: Mounted Temporary Directory /tmp.
Αυγ 24 10:36:09 creamsoda kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
Αυγ 24 10:36:09 creamsoda kernel: random: crng init done
Αυγ 24 10:36:09 creamsoda kernel: random: 3 urandom warning(s) missed due to ratelimiting
Αυγ 24 10:36:09 creamsoda systemd-fsck[389]: fsck.fat 4.2 (2021-01-31)
Αυγ 24 10:36:09 creamsoda systemd-fsck[389]: /dev/nvme0n1p1: 186 files, 6544/255492 clusters
Αυγ 24 10:36:09 creamsoda systemd[1]: Mounted /home.
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished File System Check on /dev/disk/by-uuid/7419-D98D.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-7419\x2dD98D comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: input: Ideapad extra buttons as /devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input8
Αυγ 24 10:36:09 creamsoda systemd[1]: Mounting /boot/efi...
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Load/Save Random Seed.
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in First Boot Complete being skipped.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: ideapad_acpi VPC2004:00: DYTC interface is not available
And here is the second part (log was too big to fit in a single post, unfortunately).
cat part2.log
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.2: New USB device found, idVendor=258a, idProduct=1006, bcdDevice=20.43
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.2: Product: Gaming KB
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.2: Manufacturer: Gaming KB
Αυγ 24 10:36:09 creamsoda kernel: nvidia: loading out-of-tree module taints kernel.
Αυγ 24 10:36:09 creamsoda kernel: nvidia: module license 'NVIDIA' taints kernel.
Αυγ 24 10:36:09 creamsoda kernel: Disabling lock debugging due to kernel taint
Αυγ 24 10:36:09 creamsoda audit[303]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=303 comm="apparmor_parser"
Αυγ 24 10:36:09 creamsoda audit[303]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=303 comm="apparmor_parser"
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Load AppArmor profiles.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
Αυγ 24 10:36:09 creamsoda snapd-apparmor[434]: find: ‘/var/lib/snapd/apparmor/profiles/’: No such file or directory
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd.apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: input: PC Speaker as /devices/platform/pcspkr/input/input9
Αυγ 24 10:36:09 creamsoda kernel: piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
Αυγ 24 10:36:09 creamsoda kernel: piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
Αυγ 24 10:36:09 creamsoda kernel: piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
Αυγ 24 10:36:09 creamsoda kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Αυγ 24 10:36:09 creamsoda kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
Αυγ 24 10:36:09 creamsoda kernel: sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
Αυγ 24 10:36:09 creamsoda kernel: sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
Αυγ 24 10:36:09 creamsoda kernel: usb 3-4: New USB device found, idVendor=048d, idProduct=c100, bcdDevice=10.00
Αυγ 24 10:36:09 creamsoda kernel: usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Αυγ 24 10:36:09 creamsoda kernel: usb 3-4: Product: ITE Device(8910)
Αυγ 24 10:36:09 creamsoda kernel: usb 3-4: Manufacturer: ITE Tech. Inc.
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
Αυγ 24 10:36:09 creamsoda kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Αυγ 24 10:36:09 creamsoda kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 235
Αυγ 24 10:36:09 creamsoda kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Αυγ 24 10:36:09 creamsoda kernel: RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
Αυγ 24 10:36:09 creamsoda kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
Αυγ 24 10:36:09 creamsoda kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Αυγ 24 10:36:09 creamsoda systemd[1]: Mounted /boot/efi.
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Local File Systems.
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Create Volatile Files and Directories...
Αυγ 24 10:36:09 creamsoda kernel: cryptd: max_cpu_qlen set to 1000
Αυγ 24 10:36:09 creamsoda kernel: libphy: r8169: probed
Αυγ 24 10:36:09 creamsoda kernel: r8169 0000:03:00.0 eth0: RTL8168h/8111h, 8c:8c:aa:02:df:6c, XID 541, IRQ 69
Αυγ 24 10:36:09 creamsoda kernel: r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
Αυγ 24 10:36:09 creamsoda systemd[1]: Received SIGRTMIN+20 from PID 206 (plymouthd).
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Create Volatile Files and Directories.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
Αυγ 24 10:36:09 creamsoda audit: BPF prog-id=18 op=LOAD
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Network Time Synchronization...
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in Update is Completed being skipped.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Record System Boot/Shutdown in UTMP...
Αυγ 24 10:36:09 creamsoda audit[460]: SYSTEM_BOOT pid=460 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Record System Boot/Shutdown in UTMP.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.63.01  Tue Aug  3 20:44:16 UTC 2021
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Network Time Synchronization.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target System Time Set.
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.3: New USB device found, idVendor=1532, idProduct=0037, bcdDevice= 2.00
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.3: Product: Razer DeathAdder 2013
Αυγ 24 10:36:09 creamsoda kernel: usb 1-1.3: Manufacturer: Razer
Αυγ 24 10:36:09 creamsoda systemd-modules-load[285]: Inserted module 'nvidia'
Αυγ 24 10:36:09 creamsoda kernel: AVX2 version of gcm_enc/dec engaged.
Αυγ 24 10:36:09 creamsoda kernel: AES CTR mode by8 optimization enabled
Αυγ 24 10:36:09 creamsoda kernel: Intel(R) Wireless WiFi driver for Linux
Αυγ 24 10:36:09 creamsoda kernel: iwlwifi 0000:04:00.0: enabling device (0000 -> 0002)
Αυγ 24 10:36:09 creamsoda kernel: iwlwifi 0000:04:00.0: api flags index 2 larger than supported by driver
Αυγ 24 10:36:09 creamsoda kernel: iwlwifi 0000:04:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
Αυγ 24 10:36:09 creamsoda kernel: iwlwifi 0000:04:00.0: loaded firmware version 62.49eeb572.0 cc-a0-62.ucode op_mode iwlmvm
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_intel 0000:05:00.6: enabling device (0000 -> 0002)
Αυγ 24 10:36:09 creamsoda kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  470.63.01  Tue Aug  3 20:30:55 UTC 2021
Αυγ 24 10:36:09 creamsoda kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input10
Αυγ 24 10:36:09 creamsoda kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input11
Αυγ 24 10:36:09 creamsoda kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input12
Αυγ 24 10:36:09 creamsoda kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input13
Αυγ 24 10:36:09 creamsoda kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input14
Αυγ 24 10:36:09 creamsoda systemd-modules-load[285]: Inserted module 'nvidia_drm'
Αυγ 24 10:36:09 creamsoda kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
Αυγ 24 10:36:09 creamsoda kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Load Kernel Modules.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Apply Kernel Variables...
Αυγ 24 10:36:09 creamsoda kernel: kvm: Nested Virtualization enabled
Αυγ 24 10:36:09 creamsoda kernel: SVM: kvm: Nested Paging enabled
Αυγ 24 10:36:09 creamsoda kernel: SVM: Virtual VMLOAD VMSAVE supported
Αυγ 24 10:36:09 creamsoda kernel: SVM: Virtual GIF supported
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Apply Kernel Variables.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting CLI Netfilter Manager...
Αυγ 24 10:36:09 creamsoda ufw-init[532]: Skip starting firewall: ufw (not enabled)
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished CLI Netfilter Manager.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target System Initialization.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started CUPS Scheduler.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Daily rotation of log files.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Daily man-db regeneration.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Monthly clean packages cache.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Generate mirrorlist weekly.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started pkgfile database update timer.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Daily verification of password and group files.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Daily Cleanup of Temporary Directories.
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Path Units.
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Timer Units.
Αυγ 24 10:36:09 creamsoda systemd[1]: Listening on CUPS Scheduler.
Αυγ 24 10:36:09 creamsoda systemd[1]: Listening on D-Bus System Message Bus Socket.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Socket activation for snappy daemon.
Αυγ 24 10:36:09 creamsoda systemd[1]: Listening on Socket activation for snappy daemon.
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Socket Units.
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Basic System.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started D-Bus System Message Bus.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Network Manager...
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Clean up modules from old kernels...
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Authorization Manager...
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Snap Daemon...
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in SSH Key Generation being skipped.
Αυγ 24 10:36:09 creamsoda audit: BPF prog-id=19 op=LOAD
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_codec_realtek hdaudioC1D0:    inputs:
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_codec_realtek hdaudioC1D0:      Mic=0x19
Αυγ 24 10:36:09 creamsoda kernel: snd_hda_codec_realtek hdaudioC1D0:      Internal Mic=0x12
Αυγ 24 10:36:09 creamsoda linux-module-cleanup[544]: cat: /usr/lib/modules/.old: No such file or directory
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting User Login Management...
Αυγ 24 10:36:09 creamsoda systemd[1]: linux-module-cleanup.service: Deactivated successfully.
Αυγ 24 10:36:09 creamsoda audit: BPF prog-id=20 op=LOAD
Αυγ 24 10:36:09 creamsoda audit: BPF prog-id=21 op=LOAD
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Clean up modules from old kernels.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=linux-module-cleanup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda polkitd[542]: Started polkitd version 0.119
Αυγ 24 10:36:09 creamsoda kernel: MCE: In-kernel MCE decoding enabled.
Αυγ 24 10:36:09 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event2 (Power Button)
Αυγ 24 10:36:09 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event1 (Power Button)
Αυγ 24 10:36:09 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event0 (Lid Switch)
Αυγ 24 10:36:09 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event3 (AT Translated Set 2 keyboard)
Αυγ 24 10:36:09 creamsoda systemd-logind[545]: New seat seat0.
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.6595] NetworkManager (version 1.32.8-1) is starting... (for the first time)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.6599] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Αυγ 24 10:36:09 creamsoda systemd[1]: Started User Login Management.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Network Manager.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.6708] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Network.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Network Manager Wait Online...
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting CUPS Scheduler...
Αυγ 24 10:36:09 creamsoda systemd[1]: Started OpenSSH Daemon.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sshd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.6758] manager[0x55e855afb000]: monitoring kernel firmware directory '/lib/firmware'.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Permit User Sessions...
Αυγ 24 10:36:09 creamsoda dbus-daemon[539]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=540 comm="/usr/bin/NetworkManager --no-daemon ")
Αυγ 24 10:36:09 creamsoda snapd[543]: AppArmor status: apparmor is enabled but some kernel features are missing: dbus, network
Αυγ 24 10:36:09 creamsoda audit: BPF prog-id=22 op=LOAD
Αυγ 24 10:36:09 creamsoda audit: BPF prog-id=23 op=LOAD
Αυγ 24 10:36:09 creamsoda audit: BPF prog-id=24 op=LOAD
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Hostname Service...
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Permit User Sessions.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting GNOME Display Manager...
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Hold until boot process finishes up...
Αυγ 24 10:36:09 creamsoda systemd[1]: Started GNOME Display Manager.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=gdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda sshd[601]: Server listening on 0.0.0.0 port 22.
Αυγ 24 10:36:09 creamsoda sshd[601]: Server listening on :: port 22.
Αυγ 24 10:36:09 creamsoda kernel: iwlwifi 0000:04:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
Αυγ 24 10:36:09 creamsoda polkitd[542]: Loading rules from directory /etc/polkit-1/rules.d
Αυγ 24 10:36:09 creamsoda polkitd[542]: Loading rules from directory /usr/share/polkit-1/rules.d
Αυγ 24 10:36:09 creamsoda polkitd[542]: Finished loading, compiling and executing 8 rules
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Authorization Manager.
Αυγ 24 10:36:09 creamsoda polkitd[542]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Modem Manager...
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Αυγ 24 10:36:09 creamsoda kernel: fbcon: Taking over console
Αυγ 24 10:36:09 creamsoda kernel: Console: switching to colour frame buffer device 128x48
Αυγ 24 10:36:09 creamsoda systemd[1]: Received SIGRTMIN+21 from PID 206 (plymouthd).
Αυγ 24 10:36:09 creamsoda dbus-daemon[539]: [system] Successfully activated service 'org.freedesktop.hostname1'
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Hostname Service.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7245] hostname: hostname: using hostnamed
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7245] hostname: hostname changed from (none) to "creamsoda"
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7249] dns-mgr[0x55e855ab4250]: init: dns=default,systemd-resolved rc-manager=symlink
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7256] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/rfkill/rfkill0) (platform driver ideapad_acpi)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7270] manager[0x55e855afb000]: rfkill: Wi-Fi hardware radio set enabled
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7270] manager[0x55e855afb000]: rfkill: WWAN hardware radio set enabled
Αυγ 24 10:36:09 creamsoda snapd[543]: daemon.go:248: started snapd/2.51.3-2 (series 16; classic; devmode) manjaro/ (amd64) linux/5.12.19-1-MANJARO.
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7369] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.32.8-1/libnm-device-plugin-bluetooth.so)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7390] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.32.8-1/libnm-device-plugin-ovs.so)
Αυγ 24 10:36:09 creamsoda ModemManager[619]: <info>  ModemManager (version 1.16.10) starting in system bus...
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7457] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.32.8-1/libnm-device-plugin-team.so)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7463] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.32.8-1/libnm-device-plugin-wwan.so)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7473] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.32.8-1/libnm-device-plugin-wifi.so)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7480] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.32.8-1/libnm-device-plugin-adsl.so)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7484] manager: rfkill: Wi-Fi disabled by radio killswitch; enabled by state file
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7485] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7486] manager: Networking is enabled by state file
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7491] dhcp-init: Using DHCP client 'internal'
Αυγ 24 10:36:09 creamsoda dbus-daemon[539]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=540 comm="/usr/bin/NetworkManager --no-daemon ")
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7498] settings: Loaded settings plugin: keyfile (internal)
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Network Manager Script Dispatcher Service...
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7530] device (lo): carrier: link connected
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7533] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7548] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Αυγ 24 10:36:09 creamsoda dbus-daemon[539]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Network Manager Script Dispatcher Service.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7587] ovsdb: Could not connect: No such file or directory
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7587] ovsdb: disconnected from ovsdb
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Modem Manager.
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7701] modem-manager: ModemManager not available
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: loop: module loaded
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.7915] modem-manager: ModemManager now available
Αυγ 24 10:36:09 creamsoda mtp-probe[662]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3"
Αυγ 24 10:36:09 creamsoda mtp-probe[662]: bus: 1, device: 3 was not an MTP device
Αυγ 24 10:36:09 creamsoda kernel: loop0: detected capacity change from 0 to 8
Αυγ 24 10:36:09 creamsoda systemd[1]: Created slice Slice /system/systemd-backlight.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
Αυγ 24 10:36:09 creamsoda systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Load/Save RF Kill Switch Status...
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:acpi_video0.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.8810] manager: rfkill: Wi-Fi now enabled by radio killswitch
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight...
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Load/Save RF Kill Switch Status.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input15
Αυγ 24 10:36:09 creamsoda kernel: input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input16
Αυγ 24 10:36:09 creamsoda kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@leds:platform::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: tmp-sanity\x2dmountpoint\x2d307458003.mount: Deactivated successfully.
Αυγ 24 10:36:09 creamsoda mtp-probe[692]: checking bus 3, device 4: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4"
Αυγ 24 10:36:09 creamsoda mtp-probe[692]: bus: 3, device: 4 was not an MTP device
Αυγ 24 10:36:09 creamsoda kernel: r8169 0000:03:00.0 eno1: renamed from eth0
Αυγ 24 10:36:09 creamsoda snapd[543]: daemon.go:341: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Snap Daemon.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.9343] device (eth0): interface index 2 renamed iface from 'eth0' to 'eno1'
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.9399] manager: startup complete
Αυγ 24 10:36:09 creamsoda kernel: iwlwifi 0000:04:00.0: base HW address: 68:54:5a:66:41:80
Αυγ 24 10:36:09 creamsoda NetworkManager[540]: <info>  [1629790569.9400] device (eno1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Network Manager Wait Online.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Network is Online.
Αυγ 24 10:36:09 creamsoda systemd[1]: Started NoMachine Server daemon.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=nxserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda kernel: input: MSFT0001:00 04F3:3186 Mouse as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0001/input/input17
Αυγ 24 10:36:09 creamsoda kernel: input: MSFT0001:00 04F3:3186 Touchpad as /devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:04F3:3186.0001/input/input18
Αυγ 24 10:36:09 creamsoda kernel: hid-multitouch 0018:04F3:3186.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:00 04F3:3186] on i2c-MSFT0001:00
Αυγ 24 10:36:09 creamsoda dbus-daemon[539]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.6' (uid=0 pid=610 comm="/usr/bin/gdm ")
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target User and Group Name Lookups.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Accounts Service...
Αυγ 24 10:36:09 creamsoda kernel: mousedev: PS/2 mouse device common for all mice
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting Save/Restore Sound Card State...
Αυγ 24 10:36:09 creamsoda systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Αυγ 24 10:36:09 creamsoda accounts-daemon[739]: started daemon version 0.6.55
Αυγ 24 10:36:09 creamsoda dbus-daemon[539]: [system] Successfully activated service 'org.freedesktop.Accounts'
Αυγ 24 10:36:09 creamsoda systemd[1]: Started Accounts Service.
Αυγ 24 10:36:09 creamsoda alsactl[754]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xc3000000 irq 88)
Αυγ 24 10:36:09 creamsoda alsactl[754]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda alsactl[754]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HD-Audio Generic at 0xc3540000 irq 89)
Αυγ 24 10:36:09 creamsoda alsactl[754]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
Αυγ 24 10:36:09 creamsoda systemd[1]: Finished Save/Restore Sound Card State.
Αυγ 24 10:36:09 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:09 creamsoda systemd[1]: Reached target Sound Card.
Αυγ 24 10:36:09 creamsoda kernel: Generic FE-GE Realtek PHY r8169-300:00: attached PHY driver (mii_bus:phy_addr=r8169-300:00, irq=MAC)
Αυγ 24 10:36:09 creamsoda audit[766]: USER_AUTH pid=766 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:09 creamsoda audit[766]: USER_ACCT pid=766 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:09 creamsoda audit[766]: CRED_ACQ pid=766 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:09 creamsoda audit[766]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=8 a1=7ffd2e60b150 a2=3 a3=78 items=0 ppid=610 pid=766 auid=120 uid=0 gid=120 euid=0 suid=0 fsuid=0 egid=120 sgid=120 fsgid=120 tty=(none) ses=1 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" subj==unconfined key=(null)
Αυγ 24 10:36:09 creamsoda audit: PROCTITLE proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D6C61756E63682D656E7669726F6E6D656E745D
Αυγ 24 10:36:09 creamsoda systemd[1]: Created slice User Slice of UID 120.
Αυγ 24 10:36:09 creamsoda systemd[1]: Starting User Runtime Directory /run/user/120...
Αυγ 24 10:36:09 creamsoda systemd-logind[545]: New session 1 of user gdm.
Αυγ 24 10:36:10 creamsoda systemd[1]: Finished User Runtime Directory /run/user/120.
Αυγ 24 10:36:10 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda systemd[1]: Starting User Manager for UID 120...
Αυγ 24 10:36:10 creamsoda dbus-daemon[539]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.14' (uid=0 pid=776 comm="(systemd) ")
Αυγ 24 10:36:10 creamsoda dbus-daemon[539]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Αυγ 24 10:36:10 creamsoda systemd[776]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Αυγ 24 10:36:10 creamsoda audit[776]: USER_ACCT pid=776 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda audit[776]: CRED_ACQ pid=776 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Αυγ 24 10:36:10 creamsoda audit[776]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd8dc0b200 a2=3 a3=78 items=0 ppid=1 pid=776 auid=120 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
Αυγ 24 10:36:10 creamsoda audit: PROCTITLE proctitle="(systemd)"
Αυγ 24 10:36:10 creamsoda systemd[776]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>]
Αυγ 24 10:36:10 creamsoda systemd[776]: pam_unix(systemd-user:session): session opened for user gdm(uid=120) by (uid=0)
Αυγ 24 10:36:10 creamsoda systemd[776]: pam_env(systemd-user:session): deprecated reading of user environment enabled
Αυγ 24 10:36:10 creamsoda audit[776]: USER_START pid=776 uid=0 auid=120 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda audit: BPF prog-id=25 op=LOAD
Αυγ 24 10:36:10 creamsoda audit[776]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffd7ba2cfd0 a2=78 a3=7ffd7ba2cfd0 items=0 ppid=1 pid=776 auid=120 uid=120 gid=120 euid=120 suid=120 fsuid=120 egid=120 sgid=120 fsgid=120 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
Αυγ 24 10:36:10 creamsoda audit: BPF prog-id=25 op=UNLOAD
Αυγ 24 10:36:10 creamsoda kernel: intel_rapl_common: Found RAPL domain package
Αυγ 24 10:36:10 creamsoda kernel: intel_rapl_common: Found RAPL domain core
Αυγ 24 10:36:10 creamsoda snapd[543]: stateengine.go:150: state ensure error: Get "https://api.snapcraft.io/api/v1/snaps/sections": dial tcp: lookup api.snapcraft.io: no such host
Αυγ 24 10:36:10 creamsoda systemd-xdg-autostart-generator[792]: Configuration file /etc/xdg/autostart/manjaro-apply-locale.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.1587] settings: (eno1): created default wired connection 'Wired connection 1'
Αυγ 24 10:36:10 creamsoda mtp-probe[809]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.3"
Αυγ 24 10:36:10 creamsoda mtp-probe[810]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.2"
Αυγ 24 10:36:10 creamsoda kernel: r8169 0000:03:00.0 eno1: Link is Down
Αυγ 24 10:36:10 creamsoda mtp-probe[809]: bus: 1, device: 5 was not an MTP device
Αυγ 24 10:36:10 creamsoda mtp-probe[810]: bus: 1, device: 4 was not an MTP device
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.1606] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:02.2/0000:04:00.0/ieee80211/phy0/rfkill2) (driver iwlwifi)
Αυγ 24 10:36:10 creamsoda systemd[776]: Queued start job for default target Main User Target.
Αυγ 24 10:36:10 creamsoda kernel: iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
Αυγ 24 10:36:10 creamsoda systemd[776]: Created slice User Application Slice.
Αυγ 24 10:36:10 creamsoda systemd[776]: Reached target Paths.
Αυγ 24 10:36:10 creamsoda systemd[776]: Reached target Timers.
Αυγ 24 10:36:10 creamsoda systemd[776]: Starting D-Bus User Message Bus Socket.
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on GnuPG network certificate management daemon.
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on GnuPG cryptographic agent and passphrase cache.
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on p11-kit server.
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on Multimedia System.
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on Sound System.
Αυγ 24 10:36:10 creamsoda systemd[776]: Listening on D-Bus User Message Bus Socket.
Αυγ 24 10:36:10 creamsoda systemd[776]: Reached target Sockets.
Αυγ 24 10:36:10 creamsoda systemd[776]: Reached target Basic System.
Αυγ 24 10:36:10 creamsoda systemd[1]: Started User Manager for UID 120.
Αυγ 24 10:36:10 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda systemd[776]: Starting Update XDG user dir configuration...
Αυγ 24 10:36:10 creamsoda systemd[1]: Started Session 1 of User gdm.
Αυγ 24 10:36:10 creamsoda systemd[776]: Finished Update XDG user dir configuration.
Αυγ 24 10:36:10 creamsoda systemd[776]: Reached target Main User Target.
Αυγ 24 10:36:10 creamsoda systemd[776]: Startup finished in 153ms.
Αυγ 24 10:36:10 creamsoda gdm-launch-environment][766]: pam_env(gdm-launch-environment:session): deprecated reading of user environment enabled
Αυγ 24 10:36:10 creamsoda audit[766]: USER_START pid=766 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.1839] device (wlan0): driver supports Access Point (AP) mode
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.1850] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.1859] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp4s0'
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.1902] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Αυγ 24 10:36:10 creamsoda systemd[776]: Started D-Bus User Message Bus.
Αυγ 24 10:36:10 creamsoda gnome-session[850]: gnome-session-binary[850]: WARNING: Failed to upload environment to systemd: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Αυγ 24 10:36:10 creamsoda gnome-session-binary[850]: WARNING: Failed to upload environment to systemd: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Αυγ 24 10:36:10 creamsoda gnome-session[850]: gnome-session-binary[850]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Αυγ 24 10:36:10 creamsoda gnome-session-binary[850]: WARNING: Failed to reset failed state of units: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Αυγ 24 10:36:10 creamsoda gnome-session-binary[850]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Αυγ 24 10:36:10 creamsoda gnome-session[850]: gnome-session-binary[850]: WARNING: Falling back to non-systemd startup procedure due to error: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Name "org.freedesktop.systemd1" does not exist
Αυγ 24 10:36:10 creamsoda gnome-session[850]: gnome-session-binary[850]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
Αυγ 24 10:36:10 creamsoda gnome-session-binary[850]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
Αυγ 24 10:36:10 creamsoda kernel: ACPI: \: failed to evaluate _DSM (0x1001)
Αυγ 24 10:36:10 creamsoda gnome-shell[858]: Adding device '/dev/dri/card0' (nvidia-drm) using non-atomic mode setting (using atomic mode setting not allowed).
Αυγ 24 10:36:10 creamsoda gnome-shell[858]: g_hash_table_destroy: assertion 'hash_table != NULL' failed
Αυγ 24 10:36:10 creamsoda gnome-shell[858]: Failed to open gpu '/dev/dri/card0': Failed to activate universal planes: Operation not permitted
Αυγ 24 10:36:10 creamsoda gnome-shell[858]: Failed to create backend: No GPUs found
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.4526] device (wlp4s0): set-hw-addr: set MAC address to C6:87:68:34:1C:BB (scanning)
Αυγ 24 10:36:10 creamsoda gnome-session[850]: gnome-session-binary[850]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Αυγ 24 10:36:10 creamsoda gnome-session-binary[850]: WARNING: App 'org.gnome.Shell.desktop' exited with code 1
Αυγ 24 10:36:10 creamsoda gnome-session-binary[850]: Unrecoverable failure in required component org.gnome.Shell.desktop
Αυγ 24 10:36:10 creamsoda kernel: mc: Linux media interface: v0.10
Αυγ 24 10:36:10 creamsoda kernel: input: Gaming KB  Gaming KB  as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.2/1-1.2:1.0/0003:258A:1006.0002/input/input19
Αυγ 24 10:36:10 creamsoda audit[766]: USER_END pid=766 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:10 creamsoda audit[766]: CRED_DISP pid=766 uid=0 auid=120 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:10 creamsoda gdm[610]: Gdm: GdmDisplay: Session never registered, failing
Αυγ 24 10:36:10 creamsoda gdm-launch-environment][766]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Αυγ 24 10:36:10 creamsoda systemd[1]: session-1.scope: Deactivated successfully.
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Removed session 1.
Αυγ 24 10:36:10 creamsoda gdm[610]: Gdm: Child process -822 was already dead.
Αυγ 24 10:36:10 creamsoda audit[892]: USER_AUTH pid=892 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:10 creamsoda systemd[1]: Received SIGRTMIN+21 from PID 206 (plymouthd).
Αυγ 24 10:36:10 creamsoda audit[892]: USER_ACCT pid=892 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:10 creamsoda systemd[1]: Finished Hold until boot process finishes up.
Αυγ 24 10:36:10 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=plymouth-quit-wait comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda systemd[1]: Reached target Multi-User System.
Αυγ 24 10:36:10 creamsoda systemd[1]: Reached target Graphical Interface.
Αυγ 24 10:36:10 creamsoda systemd[1]: Starting TLP system startup/shutdown...
Αυγ 24 10:36:10 creamsoda audit[892]: CRED_ACQ pid=892 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:10 creamsoda audit[892]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=8 a1=7ffcdfd4afe0 a2=3 a3=78 items=0 ppid=610 pid=892 auid=120 uid=0 gid=120 euid=0 suid=0 fsuid=0 egid=120 sgid=120 fsgid=120 tty=(none) ses=3 comm="gdm-session-wor" exe="/usr/lib/gdm-session-worker" subj==unconfined key=(null)
Αυγ 24 10:36:10 creamsoda audit: PROCTITLE proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D6C61756E63682D656E7669726F6E6D656E745D
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: New session 3 of user gdm.
Αυγ 24 10:36:10 creamsoda systemd[1]: Started Session 3 of User gdm.
Αυγ 24 10:36:10 creamsoda gdm-launch-environment][892]: pam_env(gdm-launch-environment:session): deprecated reading of user environment enabled
Αυγ 24 10:36:10 creamsoda audit[892]: USER_START pid=892 uid=0 auid=120 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=creamsoda addr=? terminal=/dev/tty1 res=success'
Αυγ 24 10:36:10 creamsoda kernel: hid-generic 0003:258A:1006.0002: input,hidraw1: USB HID v1.11 Keyboard [Gaming KB  Gaming KB ] on usb-0000:05:00.3-1.2/input0
Αυγ 24 10:36:10 creamsoda kernel: input: Gaming KB  Gaming KB  System Control as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.2/1-1.2:1.1/0003:258A:1006.0003/input/input20
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (--) Log file renamed from "/var/lib/gdm/.local/share/xorg/Xorg.pid-901.log" to "/var/lib/gdm/.local/share/xorg/Xorg.0.log"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (WW) Failed to open protocol names file lib/xorg/protocol.txt
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: X.Org X Server 1.20.13
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: X Protocol Version 11, Revision 0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: Build Operating System: Linux Manjaro Linux
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: Current Operating System: Linux creamsoda 5.12.19-1-MANJARO #1 SMP PREEMPT Tue Jul 20 20:57:37 UTC 2021 x86_64
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=bd60bfe4-216c-47a3-b221-f41f0a61e28b rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: Build Date: 29 July 2021  08:07:46PM
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: Current version of pixman: 0.40.0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         Before reporting problems, check http://wiki.x.org
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         to make sure that you have the latest version.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: Markers: (--) probed, (**) from config file, (==) default setting,
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         (++) from command line, (!!) notice, (II) informational,
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Log file: "/var/lib/gdm/.local/share/xorg/Xorg.0.log", Time: Tue Aug 24 10:36:10 2021
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) ServerLayout "layout"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) |-->Screen "Screen0" (0)
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) |   |-->Monitor "Monitor0"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) |   |-->Device "Device0"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Automatically adding devices
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Automatically enabling devices
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Automatically adding GPU devices
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Automatically binding GPU devices
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (WW) The directory "/usr/share/fonts/misc" does not exist.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         Entry deleted from font path.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) FontPath set to:
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         /usr/share/fonts/TTF,
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         /usr/share/fonts/OTF
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) ModulePath set to "/usr/lib/xorg/modules"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) Extension "COMPOSITE" is enabled
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) The server relies on udev to provide the list of input devices.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         If no devices become available, reconfigure udev or disable AutoAddDevices.
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Module ABI versions:
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         X.Org ANSI C Emulation: 0.4
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         X.Org Video Driver: 24.1
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         X.Org XInput driver : 24.1
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         X.Org Server Extension : 10.0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (++) using VT number 1
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) xfree86: Adding drm device (/dev/dri/card0)
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (--) PCI:*(1@0:0:0) 10de:1f95:17aa:3a3e rev 161, Mem @ 0xc2000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00002000/128, BIOS @ 0x????????/131072
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) LoadModule: "glx"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Module glx: vendor="X.Org Foundation"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         compiled for 1.20.13, module version = 1.0.0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         ABI class: X.Org Server Extension, version 10.0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) LoadModule: "nvidia"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Module nvidia: vendor="NVIDIA Corporation"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         compiled for 1.6.99.901, module version = 1.0.0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         Module class: X.Org Video Driver
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA dlloader X Driver  470.63.01  Tue Aug  3 20:37:27 UTC 2021
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) systemd-logind: releasing fd for 226:0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading sub module "fb"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) LoadModule: "fb"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading /usr/lib/xorg/modules/libfb.so
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Module fb: vendor="X.Org Foundation"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         ABI class: X.Org ANSI C Emulation, version 0.4
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading sub module "wfb"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) LoadModule: "wfb"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading /usr/lib/xorg/modules/libwfb.so
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Module wfb: vendor="X.Org Foundation"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading sub module "ramdac"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) LoadModule: "ramdac"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Module "ramdac" already built-in
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) NVIDIA(0): RGB weight 888
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) NVIDIA(0): Default visual is TrueColor
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) Option "AllowNVIDIAGpuScreens"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Applying OutputClass "nvidia" options to /dev/dri/card0
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (**) NVIDIA(0): Enabling 2D acceleration
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading sub module "glxserver_nvidia"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) LoadModule: "glxserver_nvidia"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
Αυγ 24 10:36:10 creamsoda kernel: videodev: Linux video capture interface: v2.00
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: Core ver 2.22
Αυγ 24 10:36:10 creamsoda kernel: NET: Registered protocol family 31
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: HCI device and connection manager initialized
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: HCI socket layer initialized
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: L2CAP socket layer initialized
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: SCO socket layer initialized
Αυγ 24 10:36:10 creamsoda kernel: input: Gaming KB  Gaming KB  Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.2/1-1.2:1.1/0003:258A:1006.0003/input/input21
Αυγ 24 10:36:10 creamsoda kernel: input: Gaming KB  Gaming KB  Keyboard as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.2/1-1.2:1.1/0003:258A:1006.0003/input/input22
Αυγ 24 10:36:10 creamsoda kernel: hid-generic 0003:258A:1006.0003: input,hiddev96,hidraw2: USB HID v1.11 Keyboard [Gaming KB  Gaming KB ] on usb-0000:05:00.3-1.2/input1
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]:         Module class: X.Org Server Extension
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA GLX Module  470.63.01  Tue Aug  3 20:35:52 UTC 2021
Αυγ 24 10:36:10 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA: The X server supports PRIME Render Offload.
Αυγ 24 10:36:10 creamsoda kernel: input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0004/input/input23
Αυγ 24 10:36:10 creamsoda kernel: input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4/3-4:1.0/0003:048D:C100.0004/input/input24
Αυγ 24 10:36:10 creamsoda kernel: hid-generic 0003:048D:C100.0004: input,hiddev97,hidraw3: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:05:00.4-4/input0
Αυγ 24 10:36:10 creamsoda kernel: input: Razer Razer DeathAdder 2013 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.3/1-1.3:1.0/0003:1532:0037.0005/input/input25
Αυγ 24 10:36:10 creamsoda kernel: hid-generic 0003:1532:0037.0005: input,hidraw4: USB HID v1.11 Mouse [Razer Razer DeathAdder 2013] on usb-0000:05:00.3-1.3/input0
Αυγ 24 10:36:10 creamsoda kernel: usbcore: registered new interface driver btusb
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: hci0: Firmware revision 0.0 build 191 week 21 2021
Αυγ 24 10:36:10 creamsoda kernel: input: Razer Razer DeathAdder 2013 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.3/1-1.3:1.1/0003:1532:0037.0006/input/input26
Αυγ 24 10:36:10 creamsoda systemd[776]: Reached target Bluetooth.
Αυγ 24 10:36:10 creamsoda systemd[1]: Starting Bluetooth service...
Αυγ 24 10:36:10 creamsoda bluetoothd[939]: Bluetooth daemon 5.60
Αυγ 24 10:36:10 creamsoda systemd[1]: Started Bluetooth service.
Αυγ 24 10:36:10 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda systemd[1]: Reached target Bluetooth Support.
Αυγ 24 10:36:10 creamsoda bluetoothd[939]: Starting SDP server
Αυγ 24 10:36:10 creamsoda dbus-daemon[539]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.3' (uid=0 pid=540 comm="/usr/bin/NetworkManager --no-daemon ")
Αυγ 24 10:36:10 creamsoda systemd[1]: Starting WPA supplicant...
Αυγ 24 10:36:10 creamsoda kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210105/nsarguments-61)
Αυγ 24 10:36:10 creamsoda dbus-daemon[539]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Αυγ 24 10:36:10 creamsoda systemd[1]: Started WPA supplicant.
Αυγ 24 10:36:10 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda wpa_supplicant[961]: Successfully initialized wpa_supplicant
Αυγ 24 10:36:10 creamsoda kernel: input: Razer Razer DeathAdder 2013 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.3/1-1.3:1.1/0003:1532:0037.0006/input/input27
Αυγ 24 10:36:10 creamsoda kernel: hid-generic 0003:1532:0037.0006: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer DeathAdder 2013] on usb-0000:05:00.3-1.3/input1
Αυγ 24 10:36:10 creamsoda kernel: usb 1-3: Found UVC 1.10 device Integrated Camera (04f2:b6c2)
Αυγ 24 10:36:10 creamsoda kernel: input: Razer Razer DeathAdder 2013 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.3/1-1.3:1.2/0003:1532:0037.0007/input/input28
Αυγ 24 10:36:10 creamsoda kernel: input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3/1-3:1.0/input/input29
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: BNEP filters: protocol multicast
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: BNEP socket layer initialized
Αυγ 24 10:36:10 creamsoda bluetoothd[939]: Bluetooth management interface 1.19 initialized
Αυγ 24 10:36:10 creamsoda kernel: hid-generic 0003:1532:0037.0007: input,hidraw6: USB HID v1.11 Keyboard [Razer Razer DeathAdder 2013] on usb-0000:05:00.3-1.3/input2
Αυγ 24 10:36:10 creamsoda kernel: usbcore: registered new interface driver usbhid
Αυγ 24 10:36:10 creamsoda kernel: usbhid: USB HID core driver
Αυγ 24 10:36:10 creamsoda kernel: usbcore: registered new interface driver uvcvideo
Αυγ 24 10:36:10 creamsoda mtp-probe[1025]: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.3"
Αυγ 24 10:36:10 creamsoda mtp-probe[1025]: bus: 1, device: 5 was not an MTP device
Αυγ 24 10:36:10 creamsoda mtp-probe[1037]: checking bus 3, device 4: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4"
Αυγ 24 10:36:10 creamsoda mtp-probe[1037]: bus: 3, device: 4 was not an MTP device
Αυγ 24 10:36:10 creamsoda mtp-probe[1039]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-3"
Αυγ 24 10:36:10 creamsoda mtp-probe[1038]: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-1/1-1.2"
Αυγ 24 10:36:10 creamsoda mtp-probe[1039]: bus: 1, device: 3 was not an MTP device
Αυγ 24 10:36:10 creamsoda mtp-probe[1038]: bus: 1, device: 4 was not an MTP device
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.8042] device (wlp4s0): supplicant interface state: internal-starting -> disconnected
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.8043] Wi-Fi P2P device controlled by interface wlp4s0 created
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.8047] manager: (p2p-dev-wlp4s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.8049] device (p2p-dev-wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.8056] device (wlp4s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Αυγ 24 10:36:10 creamsoda NetworkManager[540]: <info>  [1629790570.8066] device (p2p-dev-wlp4s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:10 creamsoda kernel: Bluetooth: hci0: MSFT filter_enable is already on
Αυγ 24 10:36:10 creamsoda kernel: NET: Registered protocol family 38
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event26 (Razer Razer DeathAdder 2013)
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event18 (Gaming KB  Gaming KB  System Control)
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event21 (ITE Tech. Inc. ITE Device(8910) Keyboard)
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event20 (Gaming KB  Gaming KB  Keyboard)
Αυγ 24 10:36:10 creamsoda tlp[895]: Applying power save settings...done.
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event19 (Gaming KB  Gaming KB  Consumer Control)
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event24 (Razer Razer DeathAdder 2013 Keyboard)
Αυγ 24 10:36:10 creamsoda systemd-logind[545]: Watching system buttons on /dev/input/event17 (Gaming KB  Gaming KB )
Αυγ 24 10:36:10 creamsoda tlp[895]: Setting battery charge thresholds...done.
Αυγ 24 10:36:10 creamsoda systemd[1]: Finished TLP system startup/shutdown.
Αυγ 24 10:36:10 creamsoda audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:10 creamsoda systemd[1]: Startup finished in 10.245s (firmware) + 1.995s (loader) + 1.435s (kernel) + 2.626s (userspace) = 16.303s.
Αυγ 24 10:36:10 creamsoda kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000c3fff window]
Αυγ 24 10:36:10 creamsoda kernel: caller _nv000722rm+0x1ad/0x200 [nvidia] mapping multiple BARs
Αυγ 24 10:36:11 creamsoda kernel: NVRM: nv_acpi_dsm_method: DSM data invalid!
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0):     DFP-0
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0):     DFP-1
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0):     DFP-2 (boot)
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0):     DFP-3
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1650 Ti (TU117-A) at PCI:1:0:0
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     (GPU-0)
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0): Memory: 4194304 kBytes
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0): VideoBIOS: 90.17.4e.00.1c
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0): Detected PCI Express Link width: 16X
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): Samsung U32H85x (DFP-2): connected
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): Samsung U32H85x (DFP-2): Internal TMDS
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): Samsung U32H85x (DFP-2): 600.0 MHz maximum pixel clock
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-3): connected
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-3): Internal DisplayPort
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-3): 2660.0 MHz maximum pixel clock
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (==) NVIDIA(0):
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (==) NVIDIA(0):     will be used as the requested mode.
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0): Validated MetaModes:
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     "DFP-3:nvidia-auto-select,DFP-2:nvidia-auto-select"
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0): Virtual screen size determined to be 5760 x 2160
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0): DPI set to (143, 144); computed from "UseEdidDpi" X config
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (--) NVIDIA(0):     option
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (WW) NVIDIA: Failed to bind sideband socket to
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (WW) NVIDIA:     '/var/run/nvidia-xdriver-b49eefe8' Permission denied
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA:     access.
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     configuration option may not be set correctly.  When the
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0):     Config Options in the README.
Αυγ 24 10:36:11 creamsoda /usr/lib/gdm-x-session[901]: (II) NVIDIA(0): Setting mode "DFP-3:nvidia-auto-select,DFP-2:nvidia-auto-select"
Αυγ 24 10:36:11 creamsoda kernel: BUG: unable to handle page fault for address: ffff8ae06c998cf0
Αυγ 24 10:36:11 creamsoda kernel: #PF: supervisor read access in kernel mode
Αυγ 24 10:36:11 creamsoda kernel: #PF: error_code(0x0000) - not-present page
Αυγ 24 10:36:11 creamsoda kernel: PGD 5f001067 P4D 5f001067 PUD 0
Αυγ 24 10:36:11 creamsoda kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
Αυγ 24 10:36:11 creamsoda kernel: CPU: 8 PID: 901 Comm: Xorg Tainted: P           OE     5.12.19-1-MANJARO #1
Αυγ 24 10:36:11 creamsoda kernel: Hardware name: LENOVO 82B5/LNVNB161216, BIOS EUCN28WW 10/20/2020
Αυγ 24 10:36:11 creamsoda kernel: RIP: 0010:_nv002230kms+0x92/0x160 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel: Code: fa 81 e1 cc cc cc cc ba 02 00 00 00 0f 45 ca 31 d2 a9 aa aa aa aa 0f 95 c2 44 09 ca 44 09 c2 09 fa 09 ca 89 d0 48 8d 7c 85 00 <44> 8b 87 ec 00 00 00 45 85 c0 74 0e 44 89 c0 0f 1f 80 00 00 00 00
Αυγ 24 10:36:11 creamsoda kernel: RSP: 0018:ffff9a4cc1593af8 EFLAGS: 00010246
Αυγ 24 10:36:11 creamsoda kernel: RAX: 00000000ffffffff RBX: ffff8adc6c964008 RCX: 0000000000000000
Αυγ 24 10:36:11 creamsoda kernel: RDX: 00000000ffffffff RSI: ffff9a4cc1053008 RDI: ffff8ae06c998c04
Αυγ 24 10:36:11 creamsoda kernel: RBP: ffff8adc6c998c08 R08: 0000000000000002 R09: 0000000000000000
Αυγ 24 10:36:11 creamsoda kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff9a4cc31c8790
Αυγ 24 10:36:11 creamsoda kernel: R13: 0000000000000000 R14: ffff9a4cc31c8790 R15: 0000000000000000
Αυγ 24 10:36:11 creamsoda kernel: FS:  00007f8f3646b940(0000) GS:ffff8add86e00000(0000) knlGS:0000000000000000
Αυγ 24 10:36:11 creamsoda kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Αυγ 24 10:36:11 creamsoda kernel: CR2: ffff8ae06c998cf0 CR3: 00000001022ca000 CR4: 0000000000350ee0
Αυγ 24 10:36:11 creamsoda kernel: Call Trace:
Αυγ 24 10:36:11 creamsoda kernel:  ? _nv000542kms+0x45c/0x580 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? kmem_cache_free+0x10c/0x480
Αυγ 24 10:36:11 creamsoda kernel:  ? nvkms_call_rm+0x5b/0x80 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? _nv002512kms+0x51/0x60 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? _nv000383kms+0x55/0xb0 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? _nv000187kms+0x1e9/0x330 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? _nv002567kms+0x168d/0x1a80 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? _nv000562kms+0x50/0x50 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? nvKmsIoctl+0x96/0x1d0 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? nvkms_ioctl+0x111/0x180 [nvidia_modeset]
Αυγ 24 10:36:11 creamsoda kernel:  ? nvidia_frontend_unlocked_ioctl+0x37/0x50 [nvidia]
Αυγ 24 10:36:11 creamsoda kernel:  ? __x64_sys_ioctl+0x82/0xb0
Αυγ 24 10:36:11 creamsoda kernel:  ? do_syscall_64+0x33/0x40
Αυγ 24 10:36:11 creamsoda kernel:  ? entry_SYSCALL_64_after_hwframe+0x44/0xae
Αυγ 24 10:36:11 creamsoda kernel: Modules linked in: cmac algif_hash algif_skcipher af_alg bnep uvcvideo btusb videobuf2_vmalloc btrtl videobuf2_memops videobuf2_v4l2 btbcm btintel videobuf2_common bluetooth videodev ecdh_generic usbhid mc ecc intel_rapl_msr joydev mousedev hid_multitouch squashfs wmi_bmof loop intel_rapl_common iwlmvm edac_mce_amd snd_hda_codec_realtek kvm_amd nvidia_drm(POE) snd_hda_codec_generic mac80211 kvm ledtrig_audio snd_hda_codec_hdmi nvidia_modeset(POE) libarc4 snd_hda_intel irqbypass crct10dif_pclmul snd_intel_dspcfg crc32_pclmul snd_intel_sdw_acpi ghash_clmulni_intel iwlwifi snd_hda_codec aesni_intel drm_kms_helper crypto_simd snd_hda_core cryptd snd_hwdep snd_pcm r8169 vfat cec sp5100_tco nvidia(POE) rapl cfg80211 fat pcspkr realtek snd_timer syscopyarea i2c_piix4 k10temp tpm_crb ideapad_laptop sysfillrect mdio_devres snd platform_profile sysimgblt sparse_keymap ucsi_acpi snd_rn_pci_acp3x ccp libphy fb_sys_fops soundcore tpm_tis snd_pci_acp3x rfkill typec_ucsi tpm_tis_core typec
Αυγ 24 10:36:11 creamsoda kernel:  cm32181 roles tpm wmi video pinctrl_amd rng_core industrialio i2c_hid_acpi i2c_hid acpi_cpufreq mac_hid drm agpgart fuse crypto_user bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd libps2 i8042 crc32c_intel xhci_pci serio
Αυγ 24 10:36:11 creamsoda kernel: ---[ end trace 18ec8ed47580e500 ]---
Αυγ 24 10:36:12 creamsoda ModemManager[619]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.1/0000:03:00.0': not supported by any plugin
Αυγ 24 10:36:12 creamsoda ModemManager[619]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:04:00.0': not supported by any plugin
Αυγ 24 10:36:14 creamsoda wpa_supplicant[961]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=GR
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.2879] policy: auto-activating connection 'Rigel' (d7dc8a07-1fad-4ed3-9058-5ecf5cb279f6)
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.2889] device (wlp4s0): Activation: starting connection 'Rigel' (d7dc8a07-1fad-4ed3-9058-5ecf5cb279f6)
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.2893] device (wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.2897] manager: NetworkManager state is now CONNECTING
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.2932] device (wlp4s0): set-hw-addr: reset MAC address to 68:54:5A:66:41:80 (preserve)
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3015] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3025] device (wlp4s0): Activation: (wifi) access point 'Rigel' has security, but secrets are required.
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3025] device (wlp4s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3083] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3084] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> interface_disabled
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3098] device (wlp4s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3104] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3110] device (wlp4s0): Activation: (wifi) connection 'Rigel' has security, and secrets exist.  No new secrets needed.
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3111] Config: added 'ssid' value 'Rigel'
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3111] Config: added 'scan_ssid' value '1'
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3112] Config: added 'bgscan' value 'simple:30:-70:86400'
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3112] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3112] Config: added 'auth_alg' value 'OPEN'
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3112] Config: added 'psk' value '<hidden>'
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3687] device (wlp4s0): supplicant interface state: interface_disabled -> inactive
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3688] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> inactive
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3839] device (wlp4s0): supplicant interface state: inactive -> scanning
Αυγ 24 10:36:14 creamsoda NetworkManager[540]: <info>  [1629790574.3841] device (p2p-dev-wlp4s0): supplicant management interface state: inactive -> scanning
Αυγ 24 10:36:14 creamsoda snapd[543]: daemon.go:508: gracefully waiting for running hooks
Αυγ 24 10:36:14 creamsoda snapd[543]: daemon.go:510: done waiting for running hooks
Αυγ 24 10:36:14 creamsoda snapd[543]: daemon stop requested to wait for socket activation
Αυγ 24 10:36:14 creamsoda systemd[1]: snapd.service: Deactivated successfully.
Αυγ 24 10:36:14 creamsoda audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:14 creamsoda kernel: kauditd_printk_skb: 77 callbacks suppressed
Αυγ 24 10:36:14 creamsoda kernel: audit: type=1131 audit(1629790574.953:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:15 creamsoda systemd[1]: systemd-rfkill.service: Deactivated successfully.
Αυγ 24 10:36:15 creamsoda audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:15 creamsoda kernel: audit: type=1131 audit(1629790575.669:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:15 creamsoda wpa_supplicant[961]: wlp4s0: SME: Trying to authenticate with b0:be:76:8a:9d:69 (SSID='Rigel' freq=5180 MHz)
Αυγ 24 10:36:15 creamsoda kernel: wlp4s0: authenticate with b0:be:76:8a:9d:69
Αυγ 24 10:36:15 creamsoda NetworkManager[540]: <info>  [1629790575.7760] device (wlp4s0): supplicant interface state: scanning -> authenticating
Αυγ 24 10:36:15 creamsoda kernel: wlp4s0: send auth to b0:be:76:8a:9d:69 (try 1/3)
Αυγ 24 10:36:15 creamsoda NetworkManager[540]: <info>  [1629790575.7761] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Αυγ 24 10:36:15 creamsoda wpa_supplicant[961]: wlp4s0: Trying to associate with b0:be:76:8a:9d:69 (SSID='Rigel' freq=5180 MHz)
Αυγ 24 10:36:15 creamsoda NetworkManager[540]: <info>  [1629790575.8897] device (wlp4s0): supplicant interface state: authenticating -> associating
Αυγ 24 10:36:15 creamsoda kernel: wlp4s0: authenticated
Αυγ 24 10:36:15 creamsoda kernel: wlp4s0: associate with b0:be:76:8a:9d:69 (try 1/3)
Αυγ 24 10:36:15 creamsoda NetworkManager[540]: <info>  [1629790575.8898] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Αυγ 24 10:36:15 creamsoda kernel: wlp4s0: associate with b0:be:76:8a:9d:69 (try 2/3)
Αυγ 24 10:36:16 creamsoda kernel: wlp4s0: RX AssocResp from b0:be:76:8a:9d:69 (capab=0x411 status=0 aid=1)
Αυγ 24 10:36:16 creamsoda kernel: wlp4s0: associated
Αυγ 24 10:36:16 creamsoda wpa_supplicant[961]: wlp4s0: Associated with b0:be:76:8a:9d:69
Αυγ 24 10:36:16 creamsoda wpa_supplicant[961]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Αυγ 24 10:36:16 creamsoda wpa_supplicant[961]: wlp4s0: WPA: Key negotiation completed with b0:be:76:8a:9d:69 [PTK=CCMP GTK=CCMP]
Αυγ 24 10:36:16 creamsoda wpa_supplicant[961]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to b0:be:76:8a:9d:69 completed [id=0 id_str=]
Αυγ 24 10:36:16 creamsoda kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2157] device (wlp4s0): supplicant interface state: associating -> completed
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2159] device (wlp4s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Rigel"
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2160] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> completed
Αυγ 24 10:36:16 creamsoda wpa_supplicant[961]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-59 noise=9999 txrate=234000
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2169] device (wlp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2179] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2750] dhcp4 (wlp4s0): state changed unknown -> bound, address=101.101.101.197
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2805] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2851] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2855] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2866] manager: NetworkManager state is now CONNECTED_LOCAL
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2891] manager: NetworkManager state is now CONNECTED_SITE
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.2893] policy: set 'Rigel' (wlp4s0) as default for IPv4 routing and DNS
Αυγ 24 10:36:16 creamsoda dbus-daemon[539]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.3' (uid=0 pid=540 comm="/usr/bin/NetworkManager --no-daemon ")
Αυγ 24 10:36:16 creamsoda dbus-daemon[539]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.3033] device (wlp4s0): Activation: successful, device activated.
Αυγ 24 10:36:16 creamsoda NetworkManager[540]: <info>  [1629790576.4821] manager: NetworkManager state is now CONNECTED_GLOBAL
Αυγ 24 10:36:19 creamsoda systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Αυγ 24 10:36:19 creamsoda audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:19 creamsoda kernel: audit: type=1131 audit(1629790579.869:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Αυγ 24 10:36:21 creamsoda NetworkManager[540]: <info>  [1629790581.9312] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Αυγ 24 10:36:21 creamsoda NetworkManager[540]: <info>  [1629790581.9328] policy: set 'Rigel' (wlp4s0) as default for IPv6 routing and DNS
Αυγ 24 10:36:28 creamsoda wpa_supplicant[961]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-53 noise=9999 txrate=234000
This seems most relevant:
So the issue is likely with the nvidia driver. I am no expert in that field, so i can only forward you to some documentation, maybe try another driver compatible with your model or the open-source nouveau driver.
https://wiki.archlinux.org/title/NVIDIA#Multiple_monitors
https://wiki.archlinux.org/title/NVIDIA/Troubleshooting
You might also want to try other kernel versions, like the newer 5.13 or the LTS 5.10.
Unfortunately, trying the nouveau driver is not an option, since I also develop and test code on the GPU (CUDA). Thus, I need the NVIDIA driver.
I will give a different NVIDIA driver a shot, though.
Afterwards, I will try reading the troubleshooting Wiki.
I have tried kernels 5.10 LTS, 5.12 and 5.13.
Problem persists.
Hi @SlapGas, were you able to solve this issue?
