Lapdock DisplayLink external Display
Hi,
I try to install and activate the DisplayLink in my Lapdock, to activate my external Monitor.
I have installed:
pamac build evdi-compat-git
pamac install displaylink
It worked 1 time, until reboot.
I tried to narrow down the issue, but I failed to do so.
Who could guide me to solve the issue?
[thinkbook14g3 ~]# modinfo evdi
filename:       /lib/modules/6.6.63-1-MANJARO/updates/dkms/evdi.ko.zst
license:        GPL
description:    Extensible Virtual Display Interface
author:         DisplayLink (UK) Ltd.
import_ns:      DMA_BUF
import_ns:      DMA_BUF
srcversion:     829CDA7787383F6C0C336C4
depends:
retpoline:      Y
vermagic:       6.6.63-1-MANJARO SMP preempt mod_unload
sig_id:         PKCS#7
signer:         DKMS module signing key
sig_key:        39:79:E3:03:8F:34:C1:71:78:19:CB:F5:5B:50:4B:1D:F0:B8:3C:2B
sig_hashalgo:   sha512
signature:      1B:94:1E:26:46:9C:49:A7:95:48:13:3B:4D:57:BE:BB:9E:8E:7D:FF:
		7E:F4:9A:34:8E:4A:C3:DF:42:41:BB:FC:F2:80:C8:9E:B2:89:CB:0A:
		A8:E6:67:C2:EE:7A:9B:6F:A6:97:58:E8:5F:93:A5:B2:AE:69:E1:31:
		EF:40:73:FA:F0:04:C5:D8:81:F4:67:82:01:6D:F8:3E:2D:C7:B9:EC:
		4E:03:94:B3:4E:FD:4D:F7:DA:5F:83:4E:7C:92:7A:CB:2E:F4:A7:88:
		A8:C9:B9:3C:07:3A:EC:4D:3F:C5:A0:C6:33:CA:2F:38:42:C9:B0:85:
		AB:5A:B1:E2:7E:66:9F:B9:59:F4:DD:AC:90:64:2E:73:82:92:07:98:
		A4:54:F2:AF:7E:69:9B:C0:CC:EC:1B:FA:D8:94:F8:5D:A4:9D:9B:DF:
		37:43:E0:5E:79:A5:6A:10:6B:6E:51:4D:97:99:00:C0:7C:8F:D1:26:
		3A:8C:0E:E8:1F:78:DA:E2:4F:AD:14:E2:41:56:E5:25:3F:77:34:E8:
		34:A7:06:EE:31:41:78:B0:B2:17:26:B6:B6:AB:C5:E0:B5:86:DA:28:
		A1:27:ED:5C:2E:3D:63:ED:0B:00:D3:B7:77:FB:54:4B:AC:8F:3B:F2:
		B1:2F:2F:C8:AA:5C:94:1C:AF:30:DD:14:01:C3:EE:C7
parm:           initial_loglevel:Initial log level (int)
parm:           initial_device_count:Initial DRM device count (default: 0) (ushort)
[thinkbook14g3 ~]# modinfo udl
filename:       /lib/modules/6.6.63-1-MANJARO/kernel/drivers/gpu/drm/udl/udl.ko.zst
license:        GPL
srcversion:     5ACBF185475B1A9A477CD0D
alias:          usb:v17E9p*d*dc*dsc*dp*icFFisc00ip00in*
depends:
retpoline:      Y
intree:         Y
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        52:19:B6:B3:D1:99:96:0A:C9:23:8C:30:0B:21:6E:7C:96:99:DA:9C
signature:      30:65:02:31:00:97:69:72:28:1B:35:7B:56:20:40:CB:63:53:E6:68:
		5C:DF:90:4B:97:A0:F4:F1:06:52:A0:C6:AF:DB:87:D9:B1:5D:94:99:
		53:C6:CD:E4:87:AE:D7:89:A5:E4:8C:65:D9:02:30:47:05:99:88:9A:
		46:DE:39:22:6C:DB:B7:94:F1:7A:E1:83:8E:D3:C7:B3:D2:AC:B1:42:
		15:E1:27:B3:25:AB:E5:B8:5B:8C:AE:FF:7C:0B:4D:9C:43:7B:19:DD:
		8C:6A:1D
journalctl --unit=displaylink.service --no-pager
Dez 04 09:50:14 thinkbook14g3 systemd[1]: Starting DisplayLink Manager Service...
Dez 04 09:50:15 thinkbook14g3 run_as_users_with_display[3219]: /usr/bin/run_as_users_with_display: line 19: warning: command substitution: ignored null byte in input
Dez 04 09:50:15 thinkbook14g3 run_as_users_with_display[3219]: /usr/bin/run_as_users_with_display: line 21: warning: command substitution: ignored null byte in input
Dez 04 09:50:15 thinkbook14g3 run_as_users_with_display[3219]: /usr/bin/run_as_users_with_display: line 17: warning: command substitution: ignored null byte in input
Dez 04 09:50:15 thinkbook14g3 run_as_users_with_display[3219]: /usr/bin/run_as_users_with_display: line 18: warning: command substitution: ignored null byte in input
Dez 04 09:50:15 thinkbook14g3 run_as_users_with_display[3219]: /usr/bin/run_as_users_with_display: line 20: warning: command substitution: ignored null byte in input
Dez 04 09:50:15 thinkbook14g3 run_as_users_with_display[3219]: Running as uwe: systemctl --user --no-block start displaylink-connect.service
Dez 04 09:50:15 thinkbook14g3 sudo[3301]:     root : PWD=/usr/lib/displaylink ; USER=uwe ; COMMAND=/usr/bin/env DISPLAY=:0 XAUTHORITY=/home/uwe/.Xauthority XDG_CONFIG_HOME=/home/uwe/.config XDG_RUNTIME_DIR=/run/user/1002 DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1002/bus systemctl --user --no-block start displaylink-connect.service
Dez 04 09:50:15 thinkbook14g3 sudo[3301]: pam_unix(sudo:session): session opened for user uwe(uid=1002) by (uid=0)
Dez 04 09:50:15 thinkbook14g3 sudo[3301]: pam_unix(sudo:session): session closed for user uwe
Dez 04 09:50:15 thinkbook14g3 systemd[1]: Started DisplayLink Manager Service.
[thinkbook14g3 ~]# inxi --full --admin --filter --width
  Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=79eb6d1c-2435-4239-8be0-38f8dca5affc rw quiet
    cryptdevice=UUID=cb853fd0-31c2-4e8f-bb3c-a4d3f3dee239:luks-cb853fd0-31c2-4e8f-bb3c-a4d3f3dee239
    root=/dev/mapper/luks-cb853fd0-31c2-4e8f-bb3c-a4d3f3dee239 apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-eb36942c-993e-4bdd-8b56-9303a5c18302
    udev.log_priority=3
  Console: pty pts/1 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 21A2 v: ThinkBook 14 G3 ACL
    serial: <filter> Chassis: type: 10 v: ThinkBook 14 G3 ACL serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN serial: <filter>
    part-nu: LENOVO_MT_21A2_BU_idea_FM_ThinkBook 14 G3 ACL
    uuid: 68d45192-8afe-11ec-810f-e4a8dfb2d502 UEFI: LENOVO v: GQCN30WW(V1.16)
    date: 12/23/2021
  ID-1: BAT1 charge: 43.7 Wh (98.0%) condition: 44.6/45.0 Wh (99.1%)
    volts: 12.4 min: 11.6 model: 0x4C 0x47 0x43 0x00 0x32 0x30 0x31 0x39 0x4C
    0x31 0x39 0x33 0x50 0x44 0x41 type: Li-ion serial: <filter>
    status: not charging cycles: 76
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608103
    desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 400 min/max: 400/4056 base/boost: 2100/4050 scaling:
    driver: amd-pstate-epp governor: powersave volts: 1.2 V ext-clock: 100 MHz
    cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
    10: 400 11: 400 12: 400 bogomips: 50323
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Lenovo
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 38.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 13d3:56ff
    class-ID: 0e02
  Display: unspecified server: X.org v: 1.21.1.14 compositor: xfwm4 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu tty: 117x51
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x140a built: 2019 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL Message: GL data unavailable in console, glxinfo missing.
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-4: DisplayLink LAPDOCK driver: cdc_ncm,snd-usb-audio type: USB
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.4:5
    chip-ID: 17e9:4307 class-ID: 0a00 serial: <filter>
  API: ALSA v: k6.6.63-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active (root, process) with:
    tools: pacat,pactl,pavucontrol
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  IF-ID-1: enp5s0f3u2u4i5 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3
    chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11
    status: discoverable: no pairing: no
  Local Storage: total: 476.94 GiB used: 400.31 GiB (83.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HBLU-00BL2
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5L2QFXM7 temp: 28.9 C
    scheme: GPT
  ID-1: / raw-size: 461.73 GiB size: 453.41 GiB (98.20%)
    used: 400.3 GiB (88.3%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-cb853fd0-31c2-4e8f-bb3c-a4d3f3dee239
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-1: swap-1 type: partition size: 14.91 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-eb36942c-993e-4bdd-8b56-9303a5c18302
  System Temperatures: cpu: 47.6 C mobo: 34.0 C gpu: amdgpu temp: 39.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 13.47 GiB used: 2.33 GiB (17.3%)
  Processes: 365 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.37 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1907 pm: pacman pkgs: 1887 libs: 497 tools: pamac pm: flatpak
    pkgs: 20 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash (su) v: 5.2.37
    running-in: pty pts/1 inxi: 3.3.36
I have now a working setup.
The solution, that worked for me was:
Reinstalling evdi 1.14.7-1
it did not work the very 1st time, because of the missing linux-header files.
(Linux66-headers)
