My shutdown times are rather slow, and I suspect primarily from this /dev/sda2: clean situation. Here is the full log which takes about 2 minutes to run through:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
My GPU is a 1070 Nvidia GTX. The other fellow solved it by uninstalling both and then reinstalling video-linux. What would you suggest in my situation?
With my desktop (which has an integrated Intel GPU and a discrete Nvidia card), I am only using video-nvidia with no problems:
mhwd -li
> Installed PCI configs:
Did that just now (looks identical to yours now). But my reboots still takes an absurd amount of time (very sad) equaling 2 minutes but feeling like 5 and displaying the same screen I shared earlier.
sudo systemd-analyze critical-chain INT ✘ 54s
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @18.853s
└─multi-user.target @18.853s
└─k3s.service @16.211s +2.640s
└─network-online.target @16.210s
└─NetworkManager-wait-online.service @2.065s +14.144s
└─NetworkManager.service @1.986s +78ms
└─dbus.service @1.842s +142ms
└─basic.target @1.839s
└─sockets.target @1.839s
└─docker.socket @1.838s +1ms
└─sysinit.target @1.807s
└─ufw.service @1.028s +779ms
└─systemd-sysctl.service @1.024s +2ms
└─systemd-modules-load.service @259ms +734ms
└─systemd-journald.socket @253ms
└─-.mount @196ms
└─-.slice @196ms
Mar 23 17:50:43 manoWarp kernel: #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23
Mar 23 17:50:43 manoWarp kernel: ata1.00: supports DRM functions and may not be fully accessible
Mar 23 17:50:43 manoWarp kernel: ata1.00: NCQ Send/Recv Log not supported
Mar 23 17:50:43 manoWarp kernel: usb 3-6: config 1 has an invalid interface number: 2 but max is 1
Mar 23 17:50:43 manoWarp kernel: usb 3-6: config 1 has no interface number 1
Mar 23 17:50:43 manoWarp kernel: nvidia: loading out-of-tree module taints kernel.
Mar 23 17:50:43 manoWarp kernel: nvidia: module license 'NVIDIA' taints kernel.
Mar 23 17:50:43 manoWarp kernel: Disabling lock debugging due to kernel taint
Mar 23 17:50:43 manoWarp kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 23 17:50:43 manoWarp kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 23 17:50:43 manoWarp kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 23 17:50:43 manoWarp kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 23 17:50:43 manoWarp kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Mar 23 17:50:43 manoWarp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.54 Tue Feb 8 04:42:21 UTC 2022
Mar 23 17:50:44 manoWarp kernel: iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
Mar 23 17:50:44 manoWarp kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Mar 23 17:50:44 manoWarp kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Mar 23 17:50:47 manoWarp sddm-helper[1229]: gkr-pam: no password is available for user
Mar 23 17:50:47 manoWarp kernel: kauditd_printk_skb: 121 callbacks suppressed
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: Configuration file /home/mano/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executabl>
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/Syncthing.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/org.kde.latte-dock.desktop:106: Unknown key name 'InitialPreference' in section 'Desktop Entry>
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: Configuration file /home/mano/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits.>
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Mar 23 17:50:47 manoWarp systemd-xdg-autostart-generator[1237]: /home/mano/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: Configuration file /home/mano/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executabl>
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/Syncthing.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/org.kde.latte-dock.desktop:106: Unknown key name 'InitialPreference' in section 'Desktop Entry>
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: Configuration file /home/mano/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits.>
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Mar 23 17:50:48 manoWarp systemd-xdg-autostart-generator[1302]: /home/mano/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 23 17:50:48 manoWarp kcminit_startup[1310]: QDBusConnection: error: could not send signal to service "" path "//home/mano/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.not>
Mar 23 17:50:48 manoWarp kded5[1344]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Mar 23 17:50:49 manoWarp kwin_x11[1347]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context>
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:46: this compose sequence is a duplicate of another; skipping line
Mar 23 17:50:49 manoWarp kwin_x11[1347]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
Mar 23 17:50:49 manoWarp ksmserver[1411]: Qt: Session management error: networkIdsList argument is NULL
Mar 23 17:50:49 manoWarp kded5[1344]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.9'
Mar 23 17:50:49 manoWarp kwalletd5[1254]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
Mar 23 17:50:49 manoWarp backlighthelper[1525]: org.kde.powerdevil: no kernel backlight interface found
Mar 23 17:50:49 manoWarp org_kde_powerdevil[1428]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Mar 23 17:50:49 manoWarp org_kde_powerdevil[1428]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Mar 23 17:50:49 manoWarp DiscoverNotifier[1477]: couldn't load "/usr/lib/qt/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt/plugins/disco>
Mar 23 17:50:49 manoWarp DiscoverNotifier[1485]: couldn't load "/usr/lib/qt/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt/plugins/disco>
Mar 23 17:50:49 manoWarp org_kde_powerdevil[1428]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mar 23 17:50:49 manoWarp org_kde_powerdevil[1428]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation probl>
Mar 23 17:50:49 manoWarp kded5[1344]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/>
Mar 23 17:50:49 manoWarp kded5[1344]: org.kde.plasma.nm.kded: Unhandled active connection state change: 1
Mar 23 17:50:49 manoWarp kded5[1344]: org.kde.plasma.dataengine.geolocation: error: "Unknown host location.services.mozilla.com: Host not found"
sudo journalctl -b0 -p4 INT ✘
Mar 24 11:00:06 manoWarp kernel: #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23
Mar 24 11:00:06 manoWarp kernel: ata1.00: supports DRM functions and may not be fully accessible
Mar 24 11:00:06 manoWarp kernel: ata1.00: NCQ Send/Recv Log not supported
Mar 24 11:00:06 manoWarp kernel: usb 3-6: config 1 has an invalid interface number: 2 but max is 1
Mar 24 11:00:06 manoWarp kernel: usb 3-6: config 1 has no interface number 1
Mar 24 11:00:07 manoWarp kernel: nvidia: loading out-of-tree module taints kernel.
Mar 24 11:00:07 manoWarp kernel: nvidia: module license 'NVIDIA' taints kernel.
Mar 24 11:00:07 manoWarp kernel: Disabling lock debugging due to kernel taint
Mar 24 11:00:07 manoWarp kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 24 11:00:07 manoWarp kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 24 11:00:07 manoWarp kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 24 11:00:07 manoWarp kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Mar 24 11:00:07 manoWarp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.54 Tue Feb 8 04:42:21 UTC 2022
Mar 24 11:00:07 manoWarp kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Mar 24 11:00:07 manoWarp kernel: iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
Mar 24 11:00:07 manoWarp kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Mar 24 11:00:07 manoWarp kernel: thermal thermal_zone0: failed to read out thermal zone (-61)
Mar 24 11:00:11 manoWarp sddm-helper[1221]: gkr-pam: no password is available for user
Mar 24 11:00:11 manoWarp kernel: kauditd_printk_skb: 123 callbacks suppressed
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: Configuration file /home/mano/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executabl>
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/Syncthing.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/org.kde.latte-dock.desktop:106: Unknown key name 'InitialPreference' in section 'Desktop Entry>
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: Configuration file /home/mano/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits.>
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1229]: /home/mano/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: Configuration file /home/mano/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executabl>
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/Syncthing.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/org.kde.latte-dock.desktop:106: Unknown key name 'InitialPreference' in section 'Desktop Entry>
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: Configuration file /home/mano/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits.>
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Mar 24 11:00:11 manoWarp systemd-xdg-autostart-generator[1294]: /home/mano/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Mar 24 11:00:11 manoWarp kcminit_startup[1301]: QDBusConnection: error: could not send signal to service "" path "//home/mano/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.not>
Mar 24 11:00:12 manoWarp kded5[1336]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Mar 24 11:00:12 manoWarp kwin_x11[1339]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context>
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:46: this compose sequence is a duplicate of another; skipping line
Mar 24 11:00:12 manoWarp kwin_x11[1339]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
Mar 24 11:00:12 manoWarp kded5[1336]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.9'
Mar 24 11:00:12 manoWarp ksmserver[1407]: Qt: Session management error: networkIdsList argument is NULL
Mar 24 11:00:12 manoWarp kwalletd5[1246]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
Mar 24 11:00:12 manoWarp backlighthelper[1521]: org.kde.powerdevil: no kernel backlight interface found
Mar 24 11:00:12 manoWarp org_kde_powerdevil[1431]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Mar 24 11:00:12 manoWarp org_kde_powerdevil[1431]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Mar 24 11:00:12 manoWarp DiscoverNotifier[1470]: couldn't load "/usr/lib/qt/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt/plugins/disco>
Mar 24 11:00:12 manoWarp DiscoverNotifier[1480]: couldn't load "/usr/lib/qt/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt/plugins/disco>
Mar 24 11:00:12 manoWarp org_kde_powerdevil[1431]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Mar 24 11:00:12 manoWarp org_kde_powerdevil[1431]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation probl>
Mar 24 11:00:12 manoWarp kded5[1336]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/>
Mar 24 11:00:12 manoWarp kded5[1336]: org.kde.plasma.nm.kded: Unhandled active connection state change: 1
Mar 24 11:00:12 manoWarp kded5[1336]: org.kde.plasma.dataengine.geolocation: error: "Unknown host location.services.mozilla.com: Host not found"
