Language settings Issue
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ cat /etc/locale.gen | grep 'hr_HR'
#hr_HR.UTF-8 UTF-8
#hr_HR ISO-8859-2
#hr_HR.UTF-8 UTF-8
Edit the file - line in file must read
hr_HR.UTF-8 UTF-8
Remember to save the file :grin:
lol , I saved it every time :slight_smile: sorry, I am wasting your time xd
It looks like this :
#he_IL.UTF-8 UTF-8
#he_IL ISO-8859-8
#hi_IN UTF-8
#hif_FJ UTF-8
#hne_IN UTF-8
hr_HR.UTF-8 UTF-8
#hr_HR ISO-8859-2
#hsb_DE ISO-8859-2
#hsb_DE.UTF-8 UTF-8
Then the file is OK - now run locale-gen
sudo locale-gen
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ sudo locale-gen
[sudo] password for marko:
Generating locales...
  en_US.UTF-8... done
Generation complete.
Something is wrong… should I reflash new fresh installation of KDE ,this time full not minimal ?
I think your changes are not saved - are you using gui editor - kate?
sudo nano /etc/locale.gen
Then scroll down and ensure the line read as mentioned
Press F2yEnter to save the change.
Then run locale-gen
Now is correct :
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ sudo nano /etc/locale.gen
  en_US.UTF-8... done
  hr_HR.UTF-8... done
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ locale -a
C
en_US.utf8
hr_HR.utf8
POSIX
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ localectl
   System Locale: LANG=en_US.UTF-8
       VC Keymap: croat
      X11 Layout: hr
       X11 Model: pc101
I rebooted laptop, still is mixed language . Also I checked, eng is set to default…weird
Got it. After few tries , I finally have it settled.
Needed to change lang to something else , than switched back to eng_us and all good now xD
Thanks @ManjaroDevOps for help
