After flashing the image ( Manjaro - Raspberry Pi 4 Minimal ) onto the SD card, booting and setting it up, I have not Ethernet connection.
The LEDs are blinking, I tried three different network cables.
I tried to add a file eth0.network in /etc/systemd/network/
[Match]
Name=eth0
[Network]
DHCP=yes
but it had no effect other than changing the output of networkctl from Unmanaged to Configuring
ip link gives me
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether dc:a6:32:61:31:2e brd ff:ff:ff:ff:ff:ff
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DORMANT group default qlen 1000
link/ether dc:a6:32:61:31:30 brd ff:ff:ff:ff:ff:ff
networkctl gives me
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 eth0 ether degraded configuring
3 wlan0 wlan no-carrier unmanaged
3 links listed.
systemctl status systemd-networkd gives me
● systemd-networkd.service - Network Service
Loaded: loaded (/usr/lib/systemd/system/systemd-networkd.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2020-10-04 02:13:07 HKT; 1min 34s ago
TriggeredBy: ● systemd-networkd.socket
Docs: man:systemd-networkd.service(8)
Main PID: 172 (systemd-network)
Status: "Processing requests..."
Tasks: 1 (limit: 4252)
CGroup: /system.slice/systemd-networkd.service
└─172 /usr/lib/systemd/systemd-networkd
Oct 04 02:13:07 raspi systemd-networkd[172]: Enumeration completed
Oct 04 02:13:07 raspi systemd-networkd[172]: eth0: IPv6 successfully enabled
Oct 04 02:13:07 raspi systemd-networkd[172]: eth0: Link UP
Oct 04 02:13:07 raspi systemd[1]: Started Network Service.
Oct 04 02:13:08 raspi systemd-networkd[172]: wlan0: Link UP
Oct 04 02:13:08 raspi systemd-networkd[172]: wlan0: Link DOWN
Oct 04 02:13:11 raspi systemd-networkd[172]: eth0: Gained carrier
Oct 04 02:13:12 raspi systemd-networkd[172]: eth0: Gained IPv6LL
Oct 04 02:13:54 raspi systemd-networkd[172]: eth0: Gained IPv6LL
Hi,
My bad, it was dhcpcd to check as it’s the client, dhcpd is the server.
Well, could you check if you have NetworkManager service installed ? $ sudo systemctl status NetworkManager (the case for the N and the M are important.)
If you do not have NetworkManager service, what you can try to do is (as root) : $ dhcpcd -k (release your ip) $ dhcpcd (renew the ip)
Could you show us what do you have in you /etc/dhcpcd.conf ?
Also, check with your router if you have some ipv4 available
That unfortunately does not help. In the end I get an error message that the operation timed out.
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
#clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
duid
# Persist interface configuration when dhcpcd exits.
persistent
# vendorclassid is set to blank to avoid sending the default of
# dhcpcd-<version>:<os>:<machine>:<platform>
vendorclassid
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Request a hostname from the network
option host_name
# Most distributions have NTP support.
#option ntp_servers
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
noipv4ll
The router works fine for IPv4 with my Desktop on ether and Laptop, Phones, etc on Wifi.
I meant, could you check if you still have available ip address to assign in the range defined on your router ?
What is this range and how many devices do you have at home ?
Also, in the dhcpcd.conf, could you comment out “duid” and uncomment the line “clientid”, save the file and then restart the service.
Then you can do the same by commenting the line “require dhcp_server_identifier”, save the file, restart the service
It appears that it is not even trying to obtain an IPv4.
Just to be sure: I am using a Raspberry 4B. And not sure whether it makes a difference, but I am temporarily based in China mainland, so the big firewall is a thing for me when it comes to Google nameservers. I don’t think that’s relevant at the current stage though.
Alright, i can be caused by an incorrect system time, maybe.
what is the output of timedatectl status ?
In the mean time, you could configure a static ip address temporarely :
In the /etc/dhcpcd.conf file, add:
interface eth0
static ip_address=192.168.0.4/24 (replace with the ip you want)
static routers=192.168.0.1 (replace with yours)
static domain_name_servers=192.168.0.1 (replace with yours)
Do you have any external drives attached?
I have the same problem on my RPI 3, no ethernet connection when i boot with external HDD attached. When i boot without HDD everything is ok.
Local time: Sun 2020-10-04 02:14:01 HKT
Universal time: Sat 2020-10-03 18:14:01 UTC
RTC time: n/a
Time zone: Asia/Hong_Kong (HKT, +0800)
System clock synchronized: no
NTP service: active
RTC in local TZ: no
I tried that but I don’t know how to set the router in a way that a certain range is reserved for static IPs (since it’s all in chinese).
ping test.de gives me
PING test.de (20.73.36.41) 56(84) bytes of data.
From _gateway (192.168.1.1) icmp_seq=1 Packet filtered
From _gateway (192.168.1.1) icmp_seq=2 Packet filtered
From _gateway (192.168.1.1) icmp_seq=3 Packet filtered
From _gateway (192.168.1.1) icmp_seq=4 Packet filtered
From _gateway (192.168.1.1) icmp_seq=5 Packet filtered
From _gateway (192.168.1.1) icmp_seq=6 Packet filtered
--- test.de ping statistics ---
9 packets transmitted, 0 received, +6 errors, 100% packet loss, time 8040ms
as does curl test.de
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (7) Failed to connect to test.de port 80: No route to host
even though networkctl now gives me
2 eth0 ether routable unmanaged
3 links listed.
and ip addr now gives me
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
inet 192.168.1.110/24 brd 192.168.1.255 scope global noprefixroute eth0
inet6 fe80::64d5:9874:d8b7:a36e/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
Your system clock is not synchronized, which is not good in my opinion to get and ip address.
It should be synchronized by default, so you might have changed something in your system, although i do not know how it is on the minimal version, however in the xfce version, it is by default.
Does systemd-timesyncd service is started/enable ?
