Could someone please guide me on further diagnostics to resolve this issue?
When I’m on Linux 5.14, there’s a consistent lag between a keystroke and the display on the screen. This happens with Chromve, Vivaldi, and even typing into Kate has a lag. Displaying on a terminal fills one page, pauses, and then goes on to the next page.
Here’s the environment running on the current 5.14 kenel.
$ sudo inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=e336ea36-9445-48dc-875e-ad7a58ebbeac rw quiet apparmor=1
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 20URS01K00 v: ThinkPad T15g Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20URS01K00 v: SDK0T08861 WIN serial: <filter>
UEFI: LENOVO v: N30ET40W (1.23 ) date: 08/03/2021
ID-1: BAT0 charge: 95.0 Wh (100.0%) condition: 95.0/94.0 Wh (101.1%)
volts: 12.3 min: 11.5 model: Celxpert 5B10W13959 type: Li-poly
serial: <filter> status: Full cycles: 2
RAM: total: 15.26 GiB used: 2.17 GiB (14.2%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: No Module Installed
Device-2: ChannelA-DIMM1 size: 8 GiB speed: spec: 3200 MT/s
actual: 2933 MT/s type: DDR4 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: SK Hynix part-no: HMA81GS6DJR8N-XN
serial: <filter>
Device-3: ChannelB-DIMM0 size: No Module Installed
Device-4: ChannelB-DIMM1 size: 8 GiB speed: spec: 3200 MT/s
serial: <filter>
Info: 8-Core model: Intel Core i9-10885H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
cache: L1: 512 KiB L2: 16 MiB L3: 16 MiB bogomips: 76816
Speed: 3600 MHz min/max: 800/5300 MHz base/boost: 2400/2400 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3601 7: 3600 8: 3600 9: 3601 10: 3600 11: 3600 12: 3600 13: 3600
14: 3600 15: 3600 16: 3600
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep sgx
sgx_lc smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Lenovo driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:1e91 class-ID: 0300
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 5986:9106 class-ID: 0e02
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3120x1920 s-dpi: 96 s-size: 823x506mm (32.4x19.9")
s-diag: 966mm (38")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Monitor-2: HDMI-1-0 res: 1200x1920 hz: 60
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:0d4c class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 942.7 GiB used: 170.13 GiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
SMART: yes health: PASSED on: 12d 13h cycles: 148
read-units: 653,581 [334 GB] written-units: 2,011,195 [1.02 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: PC SN730 SDBQNTY-512G-1001 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11170101 temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 61 hrs cycles: 211
read-units: 2,610,103 [1.33 TB] written-units: 1,449,339 [742 GB]
ID-1: / raw-size: 34.18 GiB size: 33.35 GiB (97.56%) used: 25.85 GiB (77.5%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:7 label: N/A
uuid: e336ea36-9445-48dc-875e-ad7a58ebbeac
ID-2: /boot/efi raw-size: 250 MiB size: 246.1 MiB (98.46%)
used: 6.8 MiB (2.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:6 label: ESP uuid: D99F-2F77
ID-3: /dos raw-size: 475.69 GiB size: 475.69 GiB (100.00%)
used: 134.04 GiB (28.2%) fs: ntfs block-size: 4096 B dev: /dev/nvme1n1p3
maj-min: 259:3 label: Windows uuid: 98EA0440EA041CDE
ID-4: /home raw-size: 381.53 GiB size: 374.54 GiB (98.17%)
used: 10.23 GiB (2.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:9 label: N/A uuid: a5e20ecf-1871-481d-a70e-6a43b417af31
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:10 label: N/A
uuid: ca150e80-ab12-4408-9fee-b62040556ae8
ID-1: /dev/nvme0n1p3 maj-min: 259:8 size: 34.18 GiB fs: ext4 label: N/A
uuid: fd104b97-a9b7-4a4a-9554-e31802efa593
ID-2: /dev/nvme1n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: 4C01-3927
ID-3: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WinRE_DRV
uuid: 7002049002045D8A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:2 info: Lenovo ThinkPad Compact Keyboard with TrackPoint
type: Keyboard,Mouse driver: lenovo,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 17ef:6047 class-ID: 0301
Device-2: 1-8:3 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9106
class-ID: 0e02
Device-3: 1-9:4 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-4: 1-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 67.0 C mobo: N/A
Processes: 357 Uptime: 1m wakeups: 3 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1367 lib: 371
flatpak: 0 Shell: Bash (sudo) v: 5.1.8 running-in: konsole inxi: 3.3.06
I can’t see how it this might be different under Linux 5.13, but I’ll provide the similar information on this system, working perfectly.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
RAM: total: 15.26 GiB used: 3.12 GiB (20.4%)
Info: 8-Core model: Intel Core i9-10885H bits: 64 type: MT MCP
cache: L2: 16 MiB bogomips: 76816
Speed: 857 MHz min/max: 800/5300 MHz Core speeds (MHz): 1: 857 2: 890 3: 807
4: 854 5: 985 6: 819 7: 835 8: 853 9: 825 10: 820 11: 900 12: 815 13: 878
14: 832 15: 818 16: 853
s-diag: 966mm (38")
diag: 394mm (15.5")
direct render: Yes
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
serial: <filter> rev: 11170101 temp: 46.9 C scheme: GPT
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7 label: N/A
used: 6.8 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: ESP
uuid: D99F-2F77
used: 134.04 GiB (28.2%) fs: ntfs dev: /dev/nvme1n1p3 maj-min: 259:3
used: 10.23 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:9
uuid: 4C01-3927
ID-3: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
class-ID: 0e02
class-ID: e001
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 369 Uptime: 4m wakeups: 3 Init: systemd v: 249 tool: systemctl
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Thanks for any help!
