Having just installed an ultrawide monitor, I want to tidy up the window placement a little, so I’ve installed kwin-scripts-tiling-git
from the AUR. While the windows are tiled, and I can adjust the Layout, any other settings do not appear to be working. For example, I want the main window to use two thirds of the desktop, I set the “Default Master Width” to 66%. Yet opening additional windows and the master is always 50%. The Gaps settings also have zero affect. Am I missing something?
Are there any other “maintained” tiling managers that I should try out?
