Kwin crashes every <1h
Hello
inxi -F
System:    Host: pc Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.5 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x serial: <superuser required>
           UEFI: American Megatrends v: 5603 date: 07/28/2020
CPU:       Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP L2 cache: 3 MiB
           Speed: 1912 MHz min/max: 1550/3600 MHz Core speeds (MHz): 1: 1912 2: 1392 3: 1429 4: 1423 5: 3479 6: 3046 7: 1424
           8: 1429 9: 2382 10: 1361 11: 1491 12: 3020
Graphics:  Device-1: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 460.39
           Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia resolution: 3440x1440~100Hz
           OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
Audio:     Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
           Device-3: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo
           Sound Server: ALSA v: k5.10.15-1-MANJARO
Network:   Device-1: Intel I211 Gigabit Network driver: igb
           IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 88:d7:f6:c7:35:6a
           Device-2: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB driver: btusb,rtl8xxxu
           IF: wlp1s0f0u5i2 state: down mac: 82:0b:fc:1c:41:1f
Bluetooth: Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB driver: btusb,rtl8xxxu
           Message: Required tool hciconfig not installed. Check --recommends
Drives:    Local Storage: total: 1.14 TiB used: 698.82 GiB (60.0%)
           ID-1: /dev/sda vendor: Seagate model: ST1000LM014-1EJ164 size: 931.51 GiB
           ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 69.17 GiB used: 46.58 GiB (67.3%) fs: ext4 dev: /dev/sdb7
           ID-2: /boot/efi size: 63 MiB used: 270 KiB (0.4%) fs: vfat dev: /dev/sdb6
           ID-3: /home size: 49.78 GiB used: 30.33 GiB (60.9%) fs: ext4 dev: /dev/sdb5
Swap:      ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:   System Temperatures: cpu: 44.4 C mobo: N/A gpu: nvidia temp: 37 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Info:      Processes: 365 Uptime: 18m Memory: 15.63 GiB used: 5 GiB (32.0%) Shell: Bash inxi: 3.3.01
From a week or so, I’ve been experiencing an issue with kwin. It always crashes.
After it crashes, i have to go to compositor in settings, re-enable compositor, then via terminal:
kwin_x11 --replace
This fix the issue for some time, less than an hour (some times even few minutes), but then it crashes again.
I can’t see any particular pattern when it crashes. The display freezes for few seconds (but not the system, because I can still hear audio if I was watching a video) and then kwin stops.
Two days ago, I updated kwin, but did not resolve the issue. I switched to kwin-low-latency but the issue is still there.
Does this also happen when you create a new user and log in there? (E.G. luigir-it2)
If yes, can you post for the new user the output of:
journalctl --priority=3 --boot=0 | grep --ignore-case kwin
:thinking:
P.S. If that would be too big, take --priority=2.
I’m sorry, I’ve just seen you answer. After updating to plasma 5.21 it didn’t crash anymore
Man I do really hate to do a:
DISPLAY=:0 kwin_x11 --replace
at tty2 in every 2 hours in Manjaro!!
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
