After a little research there seems to be “Zen Arch Repository” that exists for this this exact scenario.
echo -e '\n[zen-browser]\nSigLevel = Never\nServer = https://zen-archlinux.github.io/arch' | sudo tee -a /etc/pacman.conf
It is unofficial so I don’t think I wanna do that, that’d be even more riskier than AUR.
an Appimage would also be similar to flatpak I guess??
And there is Tarball method, it is official. I never tried it.
Should I go for Tarball script?
curl -fsSL https://github.com/zen-browser/updates-server/raw/refs/heads/main/install.sh | bash
Update : I just installed Tarball version of Zen, moved all the data (profile) from flatpak to native version.
cp -a ~/.var/app/app.zen_browser.zen/.zen ~/
Thankfully that all went very smoothly, just had to select the old profile and make it default in about:profiles.
All the logins and data is moved successfully.
The core issue isn’t fixed though, kwalletd6 is still taking 251 MiB of memory actively…
Seems unusual to me, it should be around 10-30 MiB.
at this point, might as well inxi -zv8
❯ inxi -zv8
Kernel: 7.1.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.1-x86_64
root=UUID=ab1f84f1-6ca3-43bb-be66-d7a9dda7067a rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.28.0
wm: kwin_wayland with: krunner tools: avail: hyprlock vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20AMS36W0J v: ThinkPad X240
Mobo: LENOVO model: 20AMS36W0J v: 0B98401 WIN serial: <superuser required>
part-nu: LENOVO_MT_20AM_BU_Think_FM_ThinkPad X240 uuid: <superuser required>
Firmware: UEFI-[Legacy] vendor: LENOVO v: GIET99WW (2.49 )
date: 03/17/2020
ID-1: BAT0 charge: 0 Wh condition: N/A/23.2 Wh volts: 11.51 min: 11.1
model: SANYO 45N1773 type: Li-ion serial: <filter> charging:
status: not charging control: start: 0% end: 100% cycles: N/A
System RAM: total: 4 GiB available: 3.51 GiB used: 2.3 GiB (65.3%)
Array-1: capacity: 8 GiB slots: 1 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Kingston part-no: ACR16D3LS1NGG/4G serial: <filter>
Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2674 min/max: 800/2900 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2674 2: 2674 3: 2674 4: 2674 bogomips: 19952
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo ThinkPad X240
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:65 chip-ID: 04ca:7035
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x05e0 built: 2013 res: mode: 1366x768
hz: 60 scale: 100% (1) dpi: 125 gamma: 1.2 chroma: red: x: 0.592 y: 0.349
green: x: 0.337 y: 0.569 blue: x: 0.161 y: 0.122 white: x: 0.314 y: 0.329
size: 277x156mm (10.91x6.14") diag: 318mm (12.5") ratio: 16:9
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
drv: crocus x11: drv: crocus
API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.7-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW GT2)
device-ID: 8086:0a16 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.357 layers: 6 device: 0 type: integrated-gpu name: Intel
HD Graphics 4400 (HSW GT2) driver: mesa intel v: 26.1.7-arch1.1
device-ID: 8086:0a16 surfaces: N/A
de: kscreen-console,kscreen-doctor wl: nwg-displays,wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
API: ALSA v: k7.1.8-2-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: nsmd status: off
tools: jack_control
Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240 driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:4 chip-ID: 8087:07dc
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 17 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 465.76 GiB used: 173.24 GiB (37.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPLX-08ZNTT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A05 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 173.24 GiB (37.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: ab1f84f1-6ca3-43bb-be66-d7a9dda7067a
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /swap raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/cache raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-5: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
Kernel: swappiness: 40 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 20 GiB used: 1.09 GiB (5.5%) priority: -1
file: /swap/swapfile
Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 2-1:70 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
chip-ID: 0000:3825 class-ID: 0301
Device-2: 2-2:47 info: Usb KeyBoard type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: c0f4:0ff5 class-ID: 0300
Device-3: 2-7:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
Device-4: 2-8:65 info: Lite-On Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04ca:7035 class-ID: 0e02
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 2274 pm: pacman pkgs: 2202 libs: 490 tools: pamac,yay pm: flatpak
pkgs: 72
1: https://manjaro.mirror.garr.it/manjaro/unstable/$repo/$arch
2: https://manjaro.c3sl.ufpr.br/unstable/$repo/$arch
3: https://forksystems.mm.fcix.net/manjaro/unstable/$repo/$arch
4: https://mirror.bakertelekom.fr/manjaro/unstable/$repo/$arch
5: https://mirror.raiolanetworks.com/manjaro/unstable/$repo/$arch
6: https://mirrors2.manjaro.org/unstable/$repo/$arch
7: https://ohioix.mm.fcix.net/manjaro/unstable/$repo/$arch
8: https://ftp.belnet.be/mirrors/manjaro/repos/unstable/$repo/$arch
9: https://mirror.math.princeton.edu/pub/manjaro/unstable/$repo/$arch
10: https://fosszone.csd.auth.gr/manjaro/unstable/$repo/$arch
11: https://ftpmirror1.infania.net/mirror/manjaro/unstable/$repo/$arch
12: https://mirror.dc.uz/manjaro/unstable/$repo/$arch
13: https://manjaro.repo.cure.edu.uy/unstable/$repo/$arch
14: https://ftp.tu-chemnitz.de/pub/linux/manjaro/unstable/$repo/$arch
15: https://mirrors.ucr.ac.cr/manjaro/unstable/$repo/$arch
16: https://mirror.telepoint.bg/manjaro/unstable/$repo/$arch
17: https://mirrors.ocf.berkeley.edu/manjaro/unstable/$repo/$arch
18: https://volico.mm.fcix.net/manjaro/unstable/$repo/$arch
19: https://muug.ca/mirror/manjaro/unstable/$repo/$arch
20: https://manjaro.mirror-services.net/pub/unstable/$repo/$arch
21: https://ba.mirror.garr.it/mirrors/manjaro/unstable/$repo/$arch
22: https://mirror.csclub.uwaterloo.ca/manjaro/unstable/$repo/$arch
23: https://mirror.datacenter.by/pub/mirrors/manjaro/unstable/$repo/$arch
24: https://ftp.psnc.pl/linux/manjaro/unstable/$repo/$arch
25: https://ask4.mm.fcix.net/manjaro/unstable/$repo/$arch
26: https://manjaro.mirrors.lavatech.top/unstable/$repo/$arch
27: https://mirror.archlinux.tw/Manjaro/unstable/$repo/$arch
28: https://gsl-syd.mm.fcix.net/manjaro/unstable/$repo/$arch
29: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
30: https://mirror.netcologne.de/manjaro/unstable/$repo/$arch
31: https://ct.mirror.garr.it/mirrors/manjaro/unstable/$repo/$arch
32: https://distrohub.kyiv.ua/manjaro/unstable/$repo/$arch
33: https://ftp.caliu.cat/pub/distribucions/manjaro/unstable/$repo/$arch
34: https://mirror.vinehost.net/manjaro/unstable/$repo/$arch
35: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable/$repo/$arch
36: https://mirror.init7.net/manjaro/unstable/$repo/$arch
37: https://nocix.mm.fcix.net/manjaro/unstable/$repo/$arch
38: https://mirror.nju.edu.cn/manjaro/unstable/$repo/$arch
39: https://mirror.phoepsilonix.love/manjaro/unstable/$repo/$arch
40: https://mirror.fcix.net/manjaro/unstable/$repo/$arch
41: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/unstable/$repo/$arch
42: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
43: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
44: https://ftp.snt.utwente.nl/pub/linux/manjaro/unstable/$repo/$arch
45: https://mirrors.gigenet.com/manjaro/unstable/$repo/$arch
46: https://ziply.mm.fcix.net/manjaro/unstable/$repo/$arch
47: https://southfront.mm.fcix.net/manjaro/unstable/$repo/$arch
48: https://mirror.futureweb.be/manjaro/unstable/$repo/$arch
49: https://mirrors.sonic.net/manjaro/unstable/$repo/$arch
50: https://irltoolkit.mm.fcix.net/manjaro/unstable/$repo/$arch
51: https://mirror.nyist.edu.cn/manjaro/unstable/$repo/$arch
52: https://mirror.alwyzon.net/manjaro/unstable/$repo/$arch
53: https://linorg.usp.br/manjaro/unstable/$repo/$arch
54: http://ftp.uni-kl.de/pub/linux/manjaro/unstable/$repo/$arch
55: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
56: https://mirrors.eric.ovh/manjaro/unstable/$repo/$arch
57: https://mirror.kku.ac.th/manjaro/unstable/$repo/$arch
58: https://cofractal-ewr.mm.fcix.net/manjaro/unstable/$repo/$arch
59: https://ipng.mm.fcix.net/manjaro/unstable/$repo/$arch
60: https://mirror.freedif.org/Manjaro/unstable/$repo/$arch
61: https://manjaro.mirror.wearetriple.com/unstable/$repo/$arch
62: https://ftp.linux.org.tr/manjaro/unstable/$repo/$arch
63: https://mirrors.ft.uam.es/manjaro/unstable/$repo/$arch
64: https://mirror.kamtv.ru/manjaro/unstable/$repo/$arch
65: https://mirrors.cicku.me/manjaro/unstable/$repo/$arch
66: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
67: https://mirror.aarnet.edu.au/pub/manjaro/unstable/$repo/$arch
68: https://mirrors.up.pt/pub/manjaro/unstable/$repo/$arch
69: https://kartolo.sby.datautama.net.id/manjaro/unstable/$repo/$arch
70: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/unstable/$repo/$arch
71: https://manjaro.ipacct.com/manjaro/unstable/$repo/$arch
72: https://mirror.23m.com/manjaro/unstable/$repo/$arch
73: https://mirrors.xtom.jp/manjaro/unstable/$repo/$arch
74: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/unstable/$repo/$arch
75: https://mirror.dkm.cz/manjaro/unstable/$repo/$arch
76: https://ftp.lysator.liu.se/pub/manjaro/unstable/$repo/$arch
77: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
78: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/unstable/$repo/$arch
79: https://nnenix.mm.fcix.net/manjaro/unstable/$repo/$arch
80: https://mirror1.sox.rs/manjaro/unstable/$repo/$arch
81: https://mirror.truenetwork.ru/manjaro/unstable/$repo/$arch
82: https://mirror.yandex.ru/mirrors/manjaro/unstable/$repo/$arch
83: https://mirror.dimensiondata.com/mirrors/manjaro.org/unstable/$repo/$arch
84: https://mirrors.atlas.net.co/manjaro/unstable/$repo/$arch
85: https://manjaro.mirror.liquidtelecom.com/unstable/$repo/$arch
86: https://ftp.free.org/mirrors/repo.manjaro.org/repos/unstable/$repo/$arch
87: https://mirror.it4i.cz/manjaro/unstable/$repo/$arch
88: https://mirrors.dotsrc.org/manjaro/unstable/$repo/$arch
89: https://manjaro.grena.ge/unstable/$repo/$arch
90: https://ftp.halifax.rwth-aachen.de/manjaro/unstable/$repo/$arch
91: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
92: https://mirrors.sjtug.sjtu.edu.cn/manjaro/unstable/$repo/$arch
93: https://mirror.xenyth.net/manjaro/unstable/$repo/$arch
94: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/unstable/$repo/$arch
Processes:
CPU top: 5 of 261
1: cpu: 15.3% command: zen pid: 212262 mem: 335.5 MiB (9.3%)
2: cpu: 7.2% command: zen pid: 212436 mem: 410.6 MiB (11.4%)
3: cpu: 4.4% command: zen pid: 213115 mem: 267.6 MiB (7.4%)
4: cpu: 4.2% command: kwin_wayland pid: 141097 mem: 112.3 MiB (3.1%)
5: cpu: 2.9% command: zen pid: 212390 mem: 45.3 MiB (1.2%)
Memory top: 5 of 261
1: mem: 410.6 MiB (11.4%) command: zen pid: 212436 cpu: 7.2%
2: mem: 335.5 MiB (9.3%) command: zen pid: 212262 cpu: 15.3%
3: mem: 316.5 MiB (8.7%) command: zen pid: 212632 cpu: 1.6%
4: mem: 267.6 MiB (7.4%) command: zen pid: 213115 cpu: 4.4%
5: mem: 260.5 MiB (7.2%) command: kwalletd6 pid: 211310 cpu: 2.1%
Processes: 261 Power: uptime: 4d 3h 25m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 15 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 1.39 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
tool: systemctl
Compilers: clang: 22.1.8 gcc: 16.2.1 Shell: Zsh v: 5.9.2
running-in: yakuake inxi: 3.3.41
Moderator Edit: Merged consecutive replies
Some more context : I have never once opened kWallet and used it ever, so is this an essential utility or I can stop it from starting and being in bg?
