Kwallet doesn't work in Plasma 6
So I recently did the update that moved Plasma from version 5 to 6. Everything seems to be working great but kwallet has stopped working. After digging around it seems like the issue is that kwallet5 is still installed and is causing issues.
I tried to remove it but it was just a string of dependencies that kept cascading. Any help would be appreciated on how to get kwallet working again
KDE Plasma Version: 6.0.5
KDE Frameworks Version: 6.2.0
Qt Version: 6.7.1
Kernel Version: 6.6.32-1-MANJARO (64-bit)
Graphics Platform: X11
Thanks Matt
I dont think that needs to be removed.
As far as I can tell kwallet is working here - to keep my network password etc.
What exactly is not working?
What symptoms do you experience?
Thanks cscs, it didn’t click that it was all in specific software and not kwallet related. So the issue is in Jetbrains software and they just need to update.
https://youtrack.jetbrains.com/issue/IJPL-4180/KWallet-password-manager-not-working-on-KDE-Plasma-6
