Kvantum is causing problems
If a distro-supplied kvantum theme is removed from the repository, then the user can still use it by fetching the theme from store.kde.org, save and unpack the tarball in their $HOME somewhere, and then load the theme into the Kvantum Manager. kvantum will then store the theme in its configuration directory under $HOME/.config/Kvantum.
I know, right?
Not anymore. :wink:
Just downloaded xfce minimal ISO and it’s there. Even in installer packages.
The removal is since yesterday, the iso-s on the site are from 19. Sept. Maybe there are newer on gitlab. Does not really matter much on a rolling release. Just update the system and remove the orphans (or not).
+1 to this!
Important Note: The Manjaro Sway Edition spin uses Matcha-dark-sea as its default theme! So removing kvantum-theme-matcha will break it for all Manjaro Sway users!
kvantum-theme-matcha will be be replaced with kvantum-manjaro in next ISO release
gitlab.manjaro.org - Kvantum theme & package name changes (9809566d)
It’s important to note that “Matcha” themes are a complete set of themes for both GTK & QT.
So while matcha-kde has not had recent commits, it doesn’t seem true that in general “Matcha” themes are unmaintained, based on the following recent releases for matcha-gtk:
The developer is maintaining many other themes, and it could be that the matcha-kde variant just hasn’t received as much attention, or is considered feature complete at this point. :person_shrugging:
FYI, the kvantum-theme-matcha theme we use was originally a fork of Vince’s Matcha-kde theme by @cscs.
❯ pacman -Si kvantum-theme-matcha | grep URL
URL             : https://gitlab.com/cscs/matcha-kde
Yes, I’m aware :wink:
Just wanted to make sure others are aware of current dependencies for Manjaro Sway, in case the idea was to remove that package from repos.
Source: cscs/matchama-kde
Matchama KDE - This is a port of the popular GTK theme Matcha for Plasma 5 desktop with a few additions and extras.
EDIT: FYI: In case it helps for future reference & theme migration…
It looks like the same original developer, vinceliuice, has been working recently on a theme called Qogir. It has a Qogir-manjaro-dark variant which looks very similar to Matcha-dark-sea & Matchama themes.
Hi @Teo ,
I can olny say that removing kvantum and running the instruction to update as was posted it solved my problem.
kvantum was replaced with kvantum-manjaro and I did not remove the matcha package. I selected another dark theme when I run kavantum afterwards.
Maybe I am lucky enough, I will wait to another update.
Regards,
kvantum-manjaro has a dependency kvantum, obviously. You can’t install a theme without the theming engine, lol.
so no, it was not. In the beginning of the topic is explained what is what.
ADDON EDIT:
I am glad that someone decided to revert the change since of today and the theme is againg a dependency by default. It is only logical, if you provide a xfce desktop with matcha-gtk-theme by default, and installed kvantum and qt5ct by default, to provide a matching visual appearance in the qt apps. Otherwise a novice user will either think “manjaro xfce is ugly inconsistent” wenn he runs his first qt app, or post a topic “how to fix” and always receive the answer, “yeah we know, now install this”.
The inconsistency with the gtk4 dark theme (the missing theme) is bad enough, maybe it is time to fix that too in the default config, since the manjaro team is actively developing (pamac) for gtk4? Shouldn’t be that hard to clone a file or 2 with another name in the system path, as i did in my .config. Maybe make adv-gtk4 package and a dependency of pamac, exactly as adv-gtk3 now works?
Will try this at the weekend, I don’t need the glibc fix as I don’t have glibc-locales installed.
Switching pamac to pamac-gtk3 it’s rather ugly looking compared to the gtk4 default.
