Since Manjaro Update to 25.09 Ksystemlog stays bright even though dark mode is set. Is this a system error?
No error. ![]()
It depends whether you enter Rootâs password or continue with your own privileges, as to whether it will follow your Userâs theme, or Rootâs.
I just confirmed this on my system. ![]()
Thanks for your explanation! ![]()
The strange thing is that it was dark in the previous version 25.08. Are you starting the program from the console? Because I click on it graphically as a user. And something else. It only occurs in Manjaro. For example, with a different OS, Ksystemlog is also dark as normal.
When I start it from the menu, it asks for the root password and if given it uses rootâs light theme - however if you click ignore then it starts as your user and of course your userâs theme is used.
You should be able to set a theme for root. I used to do it, but I havenât in a long long time.
There are 2 obvious explanations:
- Youâve been clicking ignore
- The root user has been configured to use a dark theme
It could be both as rootâs theme isnât changed on Manjaro (unless done by the user/sys-admin), but itâs possible another distro has decided to match rootâs theme to the userâs theme. Iâm not aware of anyone doing that but I donât really pay much attention to other distros.
Thanks for your detailed explantation!
Alternatively to setting root to a dark theme, you can make sure youâre a member of âwheelâ (giving you permission to view the logs, and disable âRun as a different userâ for KsystemLog in the KDEMenuEditor or in the .desktop file.
I actually think itâs better that a different theme is used for the User and for Root; makes it easy to see that the (GUI) program is running with root privileges.
Well the first user is always added to wheel, so they probably are already.
As I suggested theyâve probably been clicking on ignore and not noticed because they already had permission.
I doubt it matters, but I think thatâs there in case you need to use it from another account that doesnât have permission, that might explain why thereâs an ignore button and why it asks for the root password and not the (sudo) userâs.
Just clicking ignore is also an option.
