journalctl -p3 -b
– Logs begin at Mon 2020-10-12 18:43:34 CEST, end at Mon 2020-11-02 14:02:07 CET. –
nov 01 18:57:35 paola-81nf systemd-coredump[1124]: Process 1120 (perl) of user 1000 dumped core.
Stack trace of thread 1120:
#0 0x00007f41cd5bee84 __nss_readline (/usr/lib/libc-2.32.so + 0x124e84)
#1 0x00007f41cd66690d n/a (/usr/lib/libnss_files-2.32.so + 0x390d)
#2 0x00007f41cd666bcf _nss_files_getprotobyname_r (/usr/lib/libnss_files-2.32.so + 0x3bcf)
#3 0x00000000007eb32d n/a (/home/paola/IDriveForLinux/idriveIt/perl + 0x3eb32d)
nov 01 18:57:36 paola-81nf akonadiserver[1340]: org.kde.pim.akonadiserver: Failed to detect mysqld version!
nov 01 18:57:36 paola-81nf akonadiserver[1340]: org.kde.pim.akonadiserver: Could not start database server!
nov 01 18:57:36 paola-81nf akonadiserver[1340]: org.kde.pim.akonadiserver: executable: “/usr/bin/mysqld”
nov 01 18:57:36 paola-81nf akonadiserver[1340]: org.kde.pim.akonadiserver: arguments: ("–defaults-file=/home/paola/.local/share/akonadi/mysql.conf", “–datadir=/home/paola/.local/share/akonadi/db_data/”, “–socket=/run/user/1000/akonadi>
nov 01 18:57:36 paola-81nf akonadiserver[1340]: org.kde.pim.akonadiserver: process error: “execvp: Permission denied”
nov 01 18:57:36 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 01 18:57:36 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 01 19:03:45 paola-81nf akonadiserver[8016]: org.kde.pim.akonadiserver: Failed to detect mysqld version!
nov 01 19:03:45 paola-81nf akonadiserver[8016]: org.kde.pim.akonadiserver: Could not start database server!
nov 01 19:03:45 paola-81nf akonadiserver[8016]: org.kde.pim.akonadiserver: executable: “/usr/bin/mysqld”
nov 01 19:03:45 paola-81nf akonadiserver[8016]: org.kde.pim.akonadiserver: arguments: (”–defaults-file=/home/paola/.local/share/akonadi/mysql.conf", “–datadir=/home/paola/.local/share/akonadi/db_data/”, "–socket=/run/user/1000/akonadi>
nov 01 19:03:45 paola-81nf akonadiserver[8016]: org.kde.pim.akonadiserver: process error: “execvp: Permission denied”
nov 01 19:58:34 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 01 19:58:34 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 01 21:19:29 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 01 21:19:29 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 01 22:57:51 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 01 22:57:51 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 01 22:57:57 paola-81nf systemd-coredump[24454]: Process 24452 (perl) of user 1000 dumped core.
Stack trace of thread 24452:
#0 0x00007fbdc4c9ee84 __nss_readline (/usr/lib/libc-2.32.so + 0x124e84)
#1 0x00007fbdc4d4690d n/a (/usr/lib/libnss_files-2.32.so + 0x390d)
#2 0x00007fbdc4d46bcf _nss_files_getprotobyname_r (/usr/lib/libnss_files-2.32.so + 0x3bcf)
nov 02 08:07:07 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 02 08:07:07 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 02 08:09:34 paola-81nf systemd-coredump[32091]: Process 32089 (perl) of user 1000 dumped core.
Stack trace of thread 32089:
#0 0x00007fb3b85ace84 __nss_readline (/usr/lib/libc-2.32.so + 0x124e84)
#1 0x00007fb3b865490d n/a (/usr/lib/libnss_files-2.32.so + 0x390d)
#2 0x00007fb3b8654bcf _nss_files_getprotobyname_r (/usr/lib/libnss_files-2.32.so + 0x3bcf)
nov 02 09:46:26 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 02 09:46:26 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 02 09:48:45 paola-81nf systemd-coredump[36070]: Process 36065 (perl) of user 1000 dumped core.
Stack trace of thread 36065:
#0 0x00007ff0f422ae84 __nss_readline (/usr/lib/libc-2.32.so + 0x124e84)
#1 0x00007ff0f42d290d n/a (/usr/lib/libnss_files-2.32.so + 0x390d)
#2 0x00007ff0f42d2bcf _nss_files_getprotobyname_r (/usr/lib/libnss_files-2.32.so + 0x3bcf)
nov 02 12:48:49 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 02 12:48:49 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 02 12:50:54 paola-81nf systemd-coredump[43755]: Process 43751 (perl) of user 1000 dumped core.
Stack trace of thread 43751:
#0 0x00007fcf410b9e84 __nss_readline (/usr/lib/libc-2.32.so + 0x124e84)
#1 0x00007fcf4116190d n/a (/usr/lib/libnss_files-2.32.so + 0x390d)
#2 0x00007fcf41161bcf _nss_files_getprotobyname_r (/usr/lib/libnss_files-2.32.so + 0x3bcf)
nov 02 13:59:21 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
nov 02 13:59:21 paola-81nf bluetoothd[808]: src/profile.c:ext_start_servers() RFCOMM server failed for Headset unit: rfcomm_bind: Address already in use (98)
nov 02 14:01:37 paola-81nf systemd-coredump[54497]: Process 54495 (perl) of user 1000 dumped core.
Stack trace of thread 54495:
#0 0x00007f915fd3ae84 __nss_readline (/usr/lib/libc-2.32.so + 0x124e84)
#1 0x00007f915fde290d n/a (/usr/lib/libnss_files-2.32.so + 0x390d)
#2 0x00007f915fde2bcf _nss_files_getprotobyname_r (/usr/lib/libnss_files-2.32.so + 0x3bcf)
lines 12-69/69 (END)
