Hello,
i got some error during pamac update of package “ksnip”
here is the problem:
[hastebin] (Pamac Update result)
[hastebin] (Cmake Output Log)
Thank you for your support
Hello,
Hello @Synaptic
Problem:
CMake Error at CMakeLists.txt:60 (find_package):
Could not find a configuration file for package "kImageAnnotator" that is
compatible with requested version "0.4.0".
Solution:
pamac install kimageannotator
OR
pamac build kimageannotator-git
hi Megavolt, thank you
i solved with the pkg build command, but before i had to uninstall the old kimageannotator version
