The install fails because the file is written with - instead of _. How can we get this fixed?
can you please post a little more details what exactly you are talking about and what the problem is?
Please provide logs or other information where the community can get this from.
If just a file has a wrong name, what about renaming it?
If you are trying to install koreader-bin from the AUR, you’ll have to contact the AUR package maintainer, or possibly edit the build file before the installation starts (depending on what tool you are using for the install). More details definitely needed.
Ayuh. The package was flagged out of date a few days ago for the very reason mentioned above.
An alternative is installing the AppImage from the releases page.
Yup, this bug was documented 4 days ago on aur, and the necessary patches also posted there. Once I edited the build files as required, it worked. Thanks all.
