Konsole transparency not taking effect during konsole launch
#1
I have this issue with the konsole that when I open it the transparency is not taking effect instead it reverts to default which is blurry, I already searched for a fix but it didn’t solve my problem, I’m running the latest Manjaro KDE , can someone help me to fix this?
#2
Is not an issue, hence it needs no fix … is an option that you can change from Settings >Desktop Behavior > Desktop Effects > Blur.
You either disable it, or you modify the settings to have lesser/lighter effect.
Also, you can disable Blur by editing the Scheme for Konsole:
#3
Thank you so much it is working now.
