Its been stuck here for more than 10 mins.
This problem is not on Kubuntu, (KDE ubuntu) and also there is no issue with bashrc because integrated terminal on IDEs works perfectly fine, they also sourcing same bashrc file
Konsole, by default, uses zsh - even if the system shell is bash.
What actions got you to this state?
What files did you edit/change?
That i know, but I changed the shell long time ago to /bin/bash.
Also I havent dont anything specific pacman -Syuu
is all I done that is also weeks ago. But I am facing this issue since 3 4 days strange part is when I logout and relogin (not restart) it works again but after some time I had to do the relogin process again.
Something is definitely wrong.
I supose you can use TTY (ctrl+alt+fX[f2,f3.,etc])
From there you can double check your updates;
sudo pacman -Syu
You can also try to reset things like ~/.config/konsolerc
Well its switched to zsh.
Maybe you can create/test a new user and see if the problem exists there?
That way we can at least know if its system-wide or localized.
After logout / login it is working and I havent faced issue since than.
