Konsole not accepting password
New to Manjaro.Konsole is stuck on password .My password works on software but not accepted by konsole
Please add your exact command and share the error you get. No screenshots!
sudo snap install transitionsdj
```error:[sudo] password for drzc:
you can have 2 different passwords: root and user
you can test with sudo and su command ?
konsole Locale is the same as gui ? you can test to type password for check
myPassé77
,yPqsse77
oops, it’s my locale and keyboard
