I use cat to show me a quite long textfile that has more lines than there are room for on one page in Konsole.
I scroll up to somewhere at the top of the text, select a few words, use Ctrl-Shift-C to copy the text to clipboard. So far, all is well.
The next step introduces my problem. I switch to Firefox, to be able to search a web page, and as I do this, the current line, where the cursor is ready for you to type some command or something, will be pushed into view and I lose sight of the selected text at the top.
It does not matter how I switch to Firefox, using the mouse to select its icon in the panel at the lower part of the screen, or using Alt-Tab, both do the same thing: The active line with the cursor is pushed into view for no good reason.
It also does not seem to matter which program I switch to, it doesn’t have to be Firefox. I tried it with Dolphin and the same problem shows up.
If I select the text, right-click the selection and choose copy from the menu, the problem goes away, but I don’t like that method of doing things. In any case, it seems as if the keyboard is involved somehow, with Konsole sensing that the keys have been triggered and therefore focuses on the current line where the active cursor actually is located.
Is there any way to stop Konsole from doing this?
I have not seen this behavior before the last update on May 2, so I was wondering if there is some setting I am not aware of that has been introduced or changed.
I have looked in settings, restarted, but nothing I do seem to make a difference.
Thanks.
