Hello together, since today I cannot start the console even though it is installed. And when I try to start Yakuake, this gives me an error message, The console module cannot be loaded. Console must be installed to run Yakuake. This is already installed with Konsole (console) 22.08.0-1 from official software sources (extra). How can I get the console working again? I work with KDE Plasma 5.25.5 X11
Hello,
Is quite unclear what “since today” means aside giving the aproximate time-frame. What happened before is more important: installed updates not rebooted the system, corrupted packages updates, you put the system on sleep after update …
Switch to TTY and as your user logged in TTY run this command:
sudo pacman-mirrors -f5 && sudo pacman -Syyu konsole yakuake && systemctl reboot
Hello everyone, I was able to solve the problem in the German manjaro forum. It just needs this command and I can use the console again.
pamac install kcoreaddons kauth
