/boot/efi is missing
Hi! Recently I’ve been trying to install the latest Manjaro Pahvo, but there’s simply no /boot/efi/ mounting point. Usually I’m doing Manual Partitioning, but it didn’t work, so I tried Replace Partition option and it didn’t work again.
I’m dual booting from Win10, and previously I had another Manjaro and Fedora that installed perfectly, but now I’m facing some problems.
What do you mean? Does Manjaro boot after you install it? Or what is what you get? What error?
It doesn’t show anything. Everything installs successfully, no errors, but when I choose drive, where I’ve installed Manjaro, it boots Windows instead.
Boot the installation media, open a terminal, execute these commands and post the output here:
sudo efibootmgr -v
sudo lsblk -f
sudo fdisk -l
can you return , from USB live manjaro
open a terminal and a browser on this topic
and returns
inxi  -Fxza
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
sudo parted -l
[manjaro@manjaro ~]$ sudo efibootmgr -v
EFI variables are not supported on this system.
[manjaro@manjaro ~]$ sudo lsblk -f
NAME   FSTYPE   FSVER            LABEL            UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0  squashfs 4.0        0   100% /run/miso/sfs/livefs
loop1  squashfs 4.0        0   100% /run/miso/sfs/mhwdfs
loop2  squashfs 4.0        0   100% /run/miso/sfs/desktopfs
loop3  squashfs 4.0        0   100% /run/miso/sfs/rootfs
sda
├─sda1 ntfs                      Local Disk       DE944D54944D2FF7
├─sda2 ext4     1.0                               c12fa2s8-8391-40df-90f8-37b5aeeaf422
├─sda3 btrfs                                      aac4f2c0-6ddc-4a3a-806d-eeae2dd7b4f7
├─sda4 vfat     FAT32            NO_LABEL         A410-432D
└─sda5
sdb
└─sdb1 ntfs                                       7C04CF0204CEBE80
sdc
├─sdc1 vfat     FAT32                             C2FA-5A08
├─sdc2
├─sdc3 ntfs                                       C25605035604F9C5
└─sdc4 ntfs                                       F4222B1E222AE578
sdd    iso9660  Joliet Extension MANJARO_KDE_2113 2021-09-16-12-14-41-00                     0   100% /run/miso/bootmnt
├─sdd1 iso9660  Joliet Extension MANJARO_KDE_2113 2021-09-16-12-14-41-00
└─sdd2 vfat     FAT12            MISO_EFI         E363-7F8B
[manjaro@manjaro ~]$ sudo fdisk -l
Disk /dev/sda: 596.17 GiB, 640135028736 bytes, 1250263728 sectors
Disk model: SAMSUNG HD642JJ
Disklabel type: gpt
Disk identifier: 60DC0E6F-9FCF-40EE-A470-E47F61520AC6
Device         Start        End   Sectors   Size Type
/dev/sda1       2048  614402047 614400000   293G Microsoft basic data
/dev/sda2  869306368 1250263694 380957327 181.7G EFI System
/dev/sda3  616499200  869306367 252807168 120.5G Linux filesystem
/dev/sda4  614402048  615426047   1024000   500M EFI System
/dev/sda5  615426048  615444479     18432     9M BIOS boot
Partition table entries are not in disk order.
Disk /dev/sdb: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: ST2000DM001-1CH1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 63C2E449-1833-4E70-874B-6DADA00531E8
/dev/sdb1  239616 3907028991 3906789376  1.8T Microsoft basic data
Disk /dev/sdc: 232.89 GiB, 250059350016 bytes, 488397168 sectors
Disk model: Samsung SSD 860
Disklabel type: gpt
Disk identifier: EF6D72E5-932E-458F-BBFB-58450FD0931C
/dev/sdc1       2048    206847    204800   100M EFI System
/dev/sdc2     206848    239615     32768    16M Microsoft reserved
/dev/sdc3     239616 487352429 487112814 232.3G Microsoft basic data
/dev/sdc4  487354368 488394751   1040384   508M Windows recovery environment
Disk /dev/loop0: 70.67 MiB, 74100736 bytes, 144728 sectors
Disk /dev/loop1: 580.53 MiB, 608731136 bytes, 1188928 sectors
Disk /dev/loop2: 1.8 GiB, 1927942144 bytes, 3765512 sectors
Disk /dev/loop3: 734.69 MiB, 770375680 bytes, 1504640 sectors
Disk /dev/sdd: 30.22 GiB, 32451330048 bytes, 63381504 sectors
Disk model: Transcend 32GB
Disklabel type: dos
Disk identifier: 0x00000000
Device     Boot   Start     End Sectors  Size Id Type
/dev/sdd1  *         64 6755599 6755536  3.2G  0 Empty
/dev/sdd2       6755600 6763791    8192    4M ef EFI (FAT-12/16/32)
[manjaro@manjaro ~]$ inxi -Fxza
System:    Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
           misolabel=MANJARO_KDE_2113 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
           nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
           Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
           Mobo: ASUSTeK model: B85-PLUS v: Rev X.0x serial: <filter> BIOS: American Megatrends v: 2001 date: 06/13/2014
CPU:       Info: Quad Core model: Intel Core i7-4771 bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60)
           stepping: 3 microcode: 28 cache: L2: 8 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 55898
           Speed: 798 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 798 2: 1280 3: 1453 4: 1224 5: 3494 6: 1419 7: 799
           8: 910
           Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: ASUSTeK
           driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
           alternate: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
           OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.41.0 5.13.15-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.2.1
           direct render: Yes
Audio:     Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
           Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
           Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.35 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK H81M-C driver: r8169 v: kernel
           port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives:    Local Storage: total: 2.66 TiB used: 0 KiB (0.0%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: HD642JJ size: 596.17 GiB block-size: physical: 512 B
           logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1118 scheme: GPT
           ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164 size: 1.82 TiB block-size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC27 scheme: GPT
           ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: GPT
           ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Transcend model: JetFlash Transcend 32GB size: 30.22 GiB block-size:
           physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
Partition: Message: No partition data found.
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 35.0 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1
Info:      Processes: 290 Uptime: 3m wakeups: 0 Memory: 19.44 GiB used: 2.28 GiB (11.7%) Init: systemd v: 249 tool: systemctl
           Compilers: gcc: N/A Packages: pacman: 1233 lib: 331 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
           inxi: 3.3.06
[manjaro@manjaro ~]$ test -d /sys/firmware/efi && echo efi || echo bios
bios
for install manjaro
UEFI, create a profile and save for Windows and another for linux on UEFI motherboard
recheck all option in your UEFI ( for linux)
SecureBoot off
Fast Boot off
No CSM
No Legacy
all disks on AHCI
boot only on UEFI:<partition 1> → EFI install manjaro
you can check in terminal , before install
inxi  -Mxa
sudo efibootmgr -v
sudo parted -l
*** do not format /boot/efi , only add after for mountpoint ***
