Hi, I write this post in this section because I think I have a problem with the video card drivers, if I’m wrong I kindly ask that the post be moved to the appropriate section.
I have a Dell Vostro 3558 notebook with Manjaro in dualboot with Windows 10 Pro, systems boot normally with rEFInd but Grub is still available.
Yesterday I started Manjaro and was left on a black screen with a steady cursor, it was not flashing.
Following some discussion on Manjaro.org I tried to start Manjaro with no success.
+ Alt + / F3 / F4 ... nothing happens.
without X - TTY1 from Grub I can't log in; my username is not accepted even though I have tried several times.
With manjaro-chroot -a I get an error message:
sudo manjaro-chroot -a
Mounting (ManjaroLinux) [/dev/sda7]
mount: [/mnt]
mount: [/mnt/boot/efi]
mount: [/mnt/home]
chroot: failed to run command '/bin/bash': No such file or directory
umount: [/mnt/home]
umount: [/mnt/boot/efi]
umount: [/mnt]
manjaro-chroot
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 122.3M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 582M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.4G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 743.4M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 111.8G 0 disk
├─sda1 8:1 0 450M 0 part
├─sda2 8:2 0 100M 0 part
├─sda3 8:3 0 16M 0 part
├─sda4 8:4 0 40G 0 part
├─sda5 8:5 0 556M 0 part
├─sda6 8:6 0 35.7G 0 part
└─sda7 8:7 0 35G 0 part
sdb 8:16 1 7.2G 0 disk
├─sdb1 8:17 1 7.2G 0 part
│ └─ventoy 254:0 0 2.9G 1 dm /run/miso/bootmnt
└─sdb2 8:18 1 32M 0 part
sr0 11:0 1 1024M 0 rom
mmcblk0 179:0 0 3.7G 0 disk
└─mmcblk0p1 179:1 0 3.7G 0 part /run/media/manjaro/4GB
sudo mount /dev/sda7 /mnt
sudo mount /dev/sda6 /mnt/home/
sudo manjaro-chroot /mnt
chroot: failed to run command '/bin/sh': No such file or directory
Dec 05 23:18:46 agetty[387]: tty1: can't exec /bin/login: No such file or directory
Dec 05 23:18:56 systemd[1]: getty@tty1.service: Deactivated successfully.
[manjaro-gnome /]# ls -lahd /bin
ls: cannot access '/bin': No such file or directory
[manjaro-gnome /]# sudo ls -lahd /bin
[manjaro-gnome /]# ln -sf /usr/bin/ /bin
[manjaro-gnome /]#
