Kmail message window is blury in wayland
Hello,
I just upgraded to Plasma 6 and switched to wayland. Now the fonts in the kmail message window looks pixeled:
Folder list, message list and menu look good.
The fonts in System Settings all look good:
Any hint or idea what could go wrong is welcome.
Many thanks
Rainer
I would try to install the package
gnu-free-fonts
If this does not solve your issue you could add
QT_SCALE_FACTOR_ROUNDING_POLICY=RoundPreferFloor
to the file /etc/environment.
Afterwards, reboot.
Many thanks for the super fast response.
It seems
fixed the issue.
Is that required temporarily to work around a known issue?
I would consider it as a non-temporary solution.
