I have a Keychron K3v2 and the F-keys don’t work, the multimedia functions work and are remarkably well integrated into the system but I cannot get the F-keys to work neither on Bluetooth nor on Cable. The F-keys work if I switch the Keyboard to Mac/iOS but then the Alt and Windows key are switched around. The same happens on Windows, so I am not sure if this is a software issue or an issue of the Keyboard.
Hi @gkraemer,
I don’t know if this’ll mean anything to you, but according to this page:
Running Arch with my K1v4. No issues at all. I do have to set it to Mac mode to get F-keys to work, but other than that it works fine.
Hope it helps!
Thanks, seems to be a general issue with Keychron keyboards then. The problem with Mac mode is that the Alt and Windows keys are swapped.
[1] seems promising.
[1] Mike Shade | Keychron Linux Function Keys
update [1] made it work correctly.
