I did a full system upgrade with pacman -Syu
, then rebooted. Now, the following occurs:
When booting the computer, it reaches the login/lock screen (SSDM) and the keyboard, trackpad, and trackpoint do not work. Additionally, plugging in USB keyboards/mice doesn’t work either.
The keyboard works in the BIOS and in GRUB. I can login via tty by appending 3
to the linux
command in the boot parameters (note that using Ctrl + Alt + F2
does not work from the login screen). I’ve tried changing the kernel (5.10, 5.13, and 5.17 all do not fix the issue).
System information
I’ve removed some of the lines here that are (likely) irrelevant since I had to type this by hand on a separate computer. I couldn’t get SMTP to work from the tty…please let me know if there is something missing that is actually necessary.
$ inxi -Fazy
Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=<> rw quiet apparmor=1
security=apparmor resume=UUID=<>
udev.log_priority=3 3
Console: tty 1 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20KHCTO1WW v: ThinkPad X1 Carbon 6th
Mobo: LENOVO model: 20KHCTO1WW v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N23ET52W (1.27 )
date: 07/18/2018
ID-1: BAT0 charge: 44.2 Wh (88.0%) condition 50.2/57.0 Wh (88.1%)
vots: 12.3 min: 11.6 model: LGC 01AV494 type Li-poly serial: <filter>
status: discharging cycles: 276
Info: model: Intel Core i7-8650U bits 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping (0xA (10) microcode: 0xEC
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2014 KiB desc: 4x256 KiB
L4: 8 MiB desc 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 33615
Type: itlb_multihit status KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX; conditional cache flushes, SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store bypass disabled via prctl
Type: spectre_v2 mitigation: Retpolines, IBPG: conditional, IBRS_FW, STIPB: conditional, RSB filling
Device-1: Inted UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
prots: active: eDP-1 empty DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID; 8086:5917 class-ID: 0300
Display: server: X.org v: 1.21.1.3 driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 tty: 160x45
Monitor-1: eDP-1 model: AU Optronics 0x2336 built: 2017 res: 2560x1440
dpi: 120 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:0 modes: 2560x1440
Device-1 Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-7:3 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 476.94 GiB used: 27.93 GiB (5.9%)
SMART Message: Unable to run smartctl. Root privileges required
model: MZVLB512HAJQ-000L7 size: 476.43 GiB block-size: physical: 512 B
rev: 4L2QEXA7 temp: 26.9 C scheme: GPT
ID-1: / raw-size 459.72 GiB size: 451.43 GiB (98.20%)
used: 27.93 GiB (6.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 16.92 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
Processes: 169 Uptime: 8m wakeups: 343 Memory: 15.38 GiB
used: 506.2 MiB (3.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1325 pacman: 1317 lib: 356 flatpak: 8
Shell: Bash (login) v: 5.1.16 running-in: tty 1 inxi: 3.3.15
