Hello,
I am finally writing a post regarding this issue I’ve been having for quite some time now, and that usually ends up being a big hassle and productivity breaker.
Sometimes, in the few days following a system reboot, my laptop’s keyboard can stop working after resuming from suspension (I suspend my computer all the time, and seldom shutdown/reboot). I can’t even log-in to try to sort this out, and I usually just end up rebooting from that screen.
There are some interesting things about this issue though:
- It seems the internal drivers do see the keyboard work, as its backlight turns back on if I click on any key, after it turns off by timeout.
- If the problem does not occur within the first 2 or 3 days after the reboot, it will never happen again (I’ve went with a two month uptime with no issues).
- Some function keys will work, like brightness and sleep, but others won’t, such as the volume controls.
- Pressing keys on the external USB keyboard does not wake up the computer, but doing so on the built-in keyboard does, despite it not working properly afterwards.
I have searched on these forums and Arch’s, but no solution worked for me, ie. reloading the atkbd
kernel module (couldn’t even do it since it said it was built-in).
I have also looked at the system journal and couldn’t find anything related to this, but I may have looked in the wrong place.
Does anyone have any idea of what might be wrong here? I’d really like to solve this rather annoying issue
My laptop is an XMG Fusion 15, and I have the qc71_laptop
platform driver installed (through DKMS).
sudo inxi -v7azy
Kernel: 5.10.117-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b8e4ec89-794c-4ce3-b10a-0102bf25e5b4 rw apparmor=1
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: SchenkerGmbH product: XMG FUSION 15 (XFU15L19)
v: Late 2019 serial: <filter> Chassis: type: 10 v: 1.0 serial: N/A
Mobo: Intel model: LAPQC71A v: K54899-304 serial: <filter> UEFI: Intel
v: QCCFL357.0138.2021.0721.1705 date: 07/21/2021
ID-1: BAT0 charge: 74.8 Wh (80.0%) condition: 93.5/93.5 Wh (100.0%)
volts: 12.4 min: 11.4 model: standard type: Li-ion serial: <filter>
status: N/A
RAM: total: 15.48 GiB used: 5.64 GiB (36.5%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: Corsair part-no: CM4X8GF2666C18S2 serial: N/A
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 900 min/max: 800/4500 base/boost: 792/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.6 V ext-clock: 100 MHz
cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 9: 900
10: 900 11: 900 12: 900 bogomips: 62431
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Intel
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:3
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x084d built: 2018 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348
class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Sound Server-1: ALSA v: k5.10.117-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.51 running: yes
vendor: Intel driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 3d:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp61s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 3e:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp62s0 state: down mac: <filter>
IF-ID-1: br-2aa0e7e24a39 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 8087:0029 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 3.0
lmp-v: 5.2 sub-v: 2232 hci-v: 5.2 rev: 2232
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Local Storage: total: 465.76 GiB used: 385.26 GiB (82.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P3CR021 temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 246d 1h cycles: 3,328
read-units: 35,371,131 [18.1 TB] written-units: 19,877,739 [10.1 TB]
ID-1: / raw-size: 70 GiB size: 68.35 GiB (97.64%) used: 63.07 GiB (92.3%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: root
uuid: b8e4ec89-794c-4ce3-b10a-0102bf25e5b4
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 8BCC-FA41
ID-3: /home raw-size: 350 GiB size: 343.44 GiB (98.13%)
used: 322.19 GiB (93.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3 label: home uuid: c2c4dab5-0a58-42d4-b279-2791c65f4a17
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p4 maj-min: 259:4 label: SWAP
uuid: 89ff7953-8699-42ab-bf57-98a619111bac
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-6:2 info: Integrated Express ITE Device(8291)
type: Keyboard,HID driver: N/A interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:ce00 class-ID: 0300
Device-2: 1-9:5 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:a09f class-ID: 0300
Device-3: 1-12:6 info: HP Wireless Keyboard and Optical Mouse receiver
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 03f0:0b0c class-ID: 0301
Device-4: 1-13:3 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b68b
Device-5: 1-14:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 53.0 C pch: 57.0 C mobo: 53.0 C
Fan Speeds (RPM): cpu: 2837 fan-2: 2859
Processes: 356 Uptime: 12h 19m wakeups: 8 Init: systemd v: 250
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 3441
lib: 543 flatpak: 0 Shell: fish (sudo) v: 3.4.1 default: Bash v: 5.1.16
running-in: kitty inxi: 3.3.16
