Manjaro XFCE, by default Ctrl+Fn
switches to workspace n
Ctrl+F5
doesn’t work in vscodium
How to disable Ctrl+Fn
as global shortcuts?
From the Whisker Menu open Settings Manager > Window Manager > Keyboard (tab).
To the bottom of the shortcuts list, you’ll find the ones (beginning with Workspace 1, Workspace 2, etc) to edit/change.
Click on each Action/Shortcut and select Edit to enter a new key combination.
