I have a Razer Chroma and unfortunately it does not have a config nor map for several keys, especially on the Keypad.
Are there any Keyboard configs that support the Keypad Del Key in non-num lock mode?
Yes, I know there is a Del key, but I normally use the Keypad Insert/Del Keys. I also use the Keypad cursor movements, especially for pg-up & pg-down or diagonal movement depending on the context. I am not an accountant or Spreadsheet wiz… I would rather not spending a week learning to remap all of the keys.
I don’t have a Razer, so maybe I’m missing something, but I would’ve thought all layouts for keyboards with num pads would have them defined. I use the Generic 105-key PC layout and all of the keys work with and without num lock.
What layout are you using? I don’t see any for Razer.
