With the Gnome 40 upgrade the keyboard navigation stopped working in the Search widget.
It works for me. Try disabling all extensions and log out / log in. If it’s not an extension causing it, try creating a new user and see if you can reproduce it.
Thanks @Yochanan for the suggestion. It appears that the dash-to-dock
extension is causing the issue. I created a Github issue for this problem.
