Keyboard Layout keybinds and Spare layouts dont work
Hey, I’m pretty new to Linux sorry if I don’t know don’t what I’m doing
I normally use 2 layouts and I added a custom layout for coding, but I don’t want the custom layout to be in the standard change-layout cycle.
I set ‘Spare layouts’ to 2, yet the change-layout shortcut still cycles through the custom layout. When I add 4 layouts, it works as expected—but the custom keybind (Ctrl+Shift+Enter) to switch to the custom layout doesn’t work at all.
Does anyone know what might be causing this or how to fix this?
  Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e25eb414-7401-4086-851c-0725906b306f rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F37a
    date: 02/16/2022
  System RAM: total: 32 GiB available: 31.27 GiB used: 5.24 GiB (16.8%)
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2D3600C18 serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3599 min/max: 550/4651 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3599 2: 3599 3: 3599
    4: 3599 5: 3599 6: 3599 7: 3599 8: 3599 9: 3599 10: 3599 11: 3599 12: 3599
    bogomips: 88843
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT / 7800
    XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1,Writeback-1
    bus-ID: 0c:00.0 chip-ID: 1002:747e class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 4480x2520 display-ID: 0
  Monitor-1: DP-2 pos: top-right model: Gigabyte M27Q X serial: <filter>
    built: 2022 res: mode: 2560x1440 hz: 240 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9 modes:
    max: 2560x1440 min: 640x480
  Monitor-2: HDMI-A-2 pos: bottom-l model: BenQ RL2455 serial: <filter>
    built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
    size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
    surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: radeontop wl: wayland-info,wlr-randr
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0c:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Audio-Technica AT2020USB+
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 0909:001c class-ID: 0300
  API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.0
    chip-ID: 8086:1528 class-ID: 0200
  IF: enp5s0f0 state: down mac: <filter>
  Device-2: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.1
  IF: enp5s0f1 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  IF-ID-1: mullvpn state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 2357:0604
  Local Storage: total: 6.37 TiB used: 143.25 GiB (2.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
    Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
    temp: 42.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 143.25 GiB (7.8%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7 label: N/A
    uuid: e25eb414-7401-4086-851c-0725906b306f
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
    uuid: BA92-28E0
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: D28E-B11A
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 1.82 TiB fs: ntfs label: N/A
    uuid: FAF89128F890E3E3
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 546 MiB fs: ntfs label: N/A
    uuid: 12BE8106BE80E417
  ID-5: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: SSD 860 EVO
    uuid: 38088F12088ECDF6
  ID-6: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: Hard drive
    uuid: 8432ABCC32ABC192
  Hub-2: 1-2:2 info: VIA Labs Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2210
  Hub-3: 1-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-3.4:5 info: Ducky One 3 RGB type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1311 class-ID: 0300
    serial: <filter>
  Device-2: 1-4:4 info: Integrated Express IT8297 RGB LED Controller
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8297 class-ID: 0301
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-5: 2-2:2 info: VIA Labs Hub ports: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0210
  Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-4:2 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Hub-7: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-2:2 info: Logitech USB Receiver type: mouse,keyboard,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
  Device-2: 5-4:3 info: Audio-Technica AT2020USB+ type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-10: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 44.0 C mobo: 29.0 C gpu: amdgpu temp: 50.0 C
    mem: 68.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 11
  Processes: 337 Power: uptime: 41m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1937 pm: pacman pkgs: 1916 libs: 506 tools: pamac,yay pm: flatpak
    pkgs: 21 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
