While I was updating using sudo pacman -S yay my computer turned off and changed to light mode when I tried to change the appearance to dark mode using gnome tweaks I blinked to dark and automatically changed to light.
Check the Night Theme Switcher extension settings.
Its on but its still light mode
Then turn Night Theme Switcher off. If it’s daytime and you try and switch to to a dark theme, what you described will happen.
Its night time for me Im GMT+1 but I still dont get how an update changed my applications to light mode
I fixed it somehow looks like it added a button to my nav bar to switch between light and dark mode it switched to light mode automatically.
Thank you for your help @Yochanan
