Hello,
I’m curious and I decided to test Wayland on my system, The first tries wasn’t good, there was too many bugs, and so I back to xorg, but now, after some updates, looks like Wayland is in a much better stage and I’m liking, but there is still one annoying bug related on my keyboard, the layout is correct but the accents are not working correctly.
Example:
It should be: ã
but I only get: ~a
I was able to fix this issue on xorg with below command, but it’s not working on wayland, is there I way to fix this issue on Wayland?
$ setxkbmap -model abnt2 -layout br -variant abnt2
Kernel: 5.15.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=dfa33105-8d9e-4555-9174-609a71216485 ro quiet apparmor=1
security=apparmor resume=UUID=493ccde5-7f80-4bf5-b22c-98ce796aade6
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: SDDM
Type: Desktop Mobo: Gigabyte model: GA-870A-UD3 v: x.x serial: <filter>
BIOS: Award v: F5 date: 08/01/2011
RAM: total: 7.76 GiB used: 3.23 GiB (41.5%)
Info: Quad Core model: AMD Phenom II X4 965 bits: 64 type: MCP arch: K10
family: 10 (16) model-id: 4 stepping: 3 microcode: 10000C8 cache: L2: 2 MiB
bogomips: 27337
Speed: 2200 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Flags: 3dnow 3dnowext 3dnowprefetch abm apic clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nonstop_tsc nopl npt nrip_save nx osvw pae pat pdpe1gb pge
pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a svm svm_lock
syscall tsc vme vmmcall wdt
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300
Display: wayland server: X.Org 1.21.1.2 compositor: kwin_wayland driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :1 screens: 1
s-diag: 582mm (22.9")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.42.0
5.15.0-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte GA-880GMA-USB3
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: 9e00 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.48 TiB used: 1.75 TiB (70.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Corsair Force GS
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5.07 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Patriot model: Burst size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: KB.3 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT120BX100SSD1
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: MU01 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital model: WD20PURZ-85GU6Y0
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS50 rev: TN02
dev-links: cdrom
ID-1: / raw-size: 214.77 GiB size: 210.4 GiB (97.96%)
used: 104.88 GiB (49.8%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
label: LINUX-SSD uuid: dfa33105-8d9e-4555-9174-609a71216485
ID-2: /home/<filter>/Games raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 60.68 GiB (55.4%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
label: LINUX-GAMES uuid: ef7d7ba9-f8da-4419-b9a3-ca9e2232da86
ID-3: /home/<filter>/HDD-DATA-2T raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.59 TiB (87.2%) fs: ntfs dev: /dev/sde1 maj-min: 8:65 label: DATA_2T
uuid: 28A6726FA6723CFE
ID-1: swap-1 type: partition size: 8.8 GiB used: 13.5 MiB (0.1%)
priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 493ccde5-7f80-4bf5-b22c-98ce796aade6
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: E680DA2C5F90FD24
ID-2: /dev/sda2 maj-min: 8:2 size: 223.48 GiB fs: ntfs label: WIN-SSD
uuid: 07492E03A516286B
ID-3: /dev/sdb1 maj-min: 8:17 size: 119.24 GiB fs: ntfs label: WIN-GAMES
uuid: EAE6EE7DE6EE4A01
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1 speed: 12 Mb/s
Device-1: 7-3:2 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Device-2: 7-4:3 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2521 class-ID: 0301
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-9: 9-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 38.9 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 221
Processes: 256 Uptime: 37m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1502 pacman: 1488 lib: 445 flatpak: 14
Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.07
