I have been using Manjaro for about 3 months or so on an HP Envy laptop that i had to put a fresh SSD in as I got it with no storage drive. Long story short, one of the hinges on the back plate broke so i decided to simply take the the SSD out and put it in with a second HP Envy laptop. Touchscreen and Touchpad both work with no issue, but the keyboard does not work once the OS is booted up. I am able to use it in the BIOS though which tells me that this is a driver issue. I am having to use KDE Connect/a USB keyboard to type, but would really prefer getting the internal keyboard working. I have been searching for a solution for hours to no avail.
Here are some things I tried:
ran the following
sudo modprobe -r atkbd && sleep 2 && sudo modpro atkbd
ran evtest
and selected AT Translated Set 2 keyboard
and nothing happened when i pressed keys
already tried multiple different Generic and Hewlett Packard keyboard models.
currently using kernel 5.18, but started this process with kernel 5.15
