Hello, i have been trying to add my HP_LaserJet_Professional_P_1102w printer to my Manjaro so i could be able to print some images and files;
I started by running hplip, which recognized the printer, but as soon as i try to enter the file throught browsing it it gets stuck; in reality, it does nothing.
here is the print of the screen in which i get stuck
I also tried to to do it via terminal, but also no luck;
here’s the output
sudo hp-setup -i
HP Linux Imaging and Printing System (ver. 3.20.9)
Printer/Fax Setup Utility ver. 9.0
Copyright © 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
(Note: Defaults for each question are maked with a ‘*’. Press to accept the default.)
SELECT CONNECTION (I/O) TYPE |
Num Connection Description
Type
0* usb Universal Serial Bus (USB)
1 net Network/Ethernet/Wireless (direct connection or JetDirect)
2 par Parallel Port (LPT:)
Enter number 0…2 for connection type (q=quit, enter=usb*) ? 0
Using connection type: usb
Setting up device: hp:/usb/HP_LaserJet_Professional_P_1102w?serial=000000000YJ5F7VTPR1a
PRINT QUEUE SETUP |
Please enter a name for this print queue (m=use model name:‘HP_LaserJet_Professional_P_1102w’*, q=quit) ?
Using queue name: HP_LaserJet_Professional_P_1102w
Locating PPD file… Please wait.
error: No PPD found for model laserjet_professional_p_1102w using old algorithm.
error: Unable to find an appropriate PPD file.
Would you like to specify the path to the correct PPD file to use (y=yes, n=no*, q=quit) ? y
Please enter the full filesystem path to the PPD file to use (q=quit) :/home/haroldo/Impressora/hp-laserjet_professional_p_1102w.ppd
Description for the file: HP LaserJet Professional p 1102w, hpcups 3.20.9
Use this file (y=yes*, n=no, q=quit) ? y
Enter a location description for this printer (q=quit) ?
Enter additonal information or notes for this printer (q=quit) ?
Adding print queue to CUPS:
Device URI: hp:/usb/HP_LaserJet_Professional_P_1102w?serial=000000000YJ5F7VTPR1a
Queue name: HP_LaserJet_Professional_P_1102w
PPD file: /home/haroldo/Impressora/hp-laserjet_professional_p_1102w.ppd
Information:
PRINTER TEST PAGE |
Would you like to print a test page (y=yes*, n=no, q=quit) ? y
warning: hp-testpage should not be run as root/superuser.
Testpage Print Utility ver. 6.0
error: No device found that support this feature.
error: No installed printers found (or) Invalid printer device selected
Done.
