Hello,
I have a wierd issue with my computer.
On startup, Everything runs perfectly well. However after a while, Keyboard and Mouse stops working but not entirely.
I can still move the mouse around and select different windows and even open applications, However i cannot drag windows or right click to see options
On my keyboard (External or Onboard), I can toggle the Caplock button and see the lights come on. But i cannot use any other keys.
Using the mouse, I’m able to log off or suspend and when i login again, everything seems to run fine.
I use an external Apple Keyboard connected via bluetooth
Here is what i tried.
- I boot into older kernel 5.4.124-1 via the grub, However issues persist
- I also download another kernel 5.12.9-1 via Manjaro Settings Manager and boot into this, However issues persist
Please what other information do i need to provide
lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
02:00.0 Network controller: Intel Corporation Wireless 8260 (rev 42)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
inxi -Fazy
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=1f729481-18eb-463d-9a6c-f05f54ad32f1 rw quiet apparmor=1
security=apparmor resume=UUID=7fe7e34f-ee1d-49c6-9ca6-264281a225d1
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: LENOVO product: 80QF v: Lenovo Edge 2-1580
serial: <filter> Chassis: type: 10 v: Lenovo Edge 2-1580 serial: <filter>
Mobo: LENOVO model: Lenovo Edge 2-1580 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: D3CN34WW date: 08/31/2016
ID-1: BAT0 charge: 34.0 Wh (100.0%) condition: 34.0/45.0 Wh (75.6%)
volts: 12.2 min: 11.1 model: SMP L14M3P21 type: Li-poly serial: <filter>
status: Full
Device-1: hid-b8:f6:b1:04:11:c0-battery model: Apple Wireless Keyboard
serial: N/A charge: N/A status: Discharging
Info: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: E2 cache:
L2: 4 MiB
bogomips: 20810
Speed: 3000 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3000 2: 2858
3: 3000 4: 3000
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 5986:0670 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x572mm (60.0x22.5")
s-diag: 1628mm (64.1")
Monitor-1: eDP1 res: 1920x1080 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Monitor-2: HDMI1 res: 3840x2160 hz: 30 dpi: 68 size: 1440x810mm (56.7x31.9")
diag: 1652mm (65")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0
bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF-ID-1: br-48195ba776c7 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: pan1 state: down mac: <filter>
IF-ID-4: veth53de25c state: up speed: 10000 Mbps duplex: full mac: <filter>
bus-ID: 1-8:5 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 232.89 GiB used: 196.99 GiB (84.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-1: / raw-size: 226.56 GiB size: 222 GiB (97.99%) used: 196.94 GiB (88.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 6.03 GiB used: 49.1 MiB (0.8%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 64.0 C mobo: 44.0 C
Processes: 265 Uptime: 4h 49m wakeups: 14 Memory: 7.57 GiB
used: 2.84 GiB (37.6%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1528 pacman: 1511 lib: 426 flatpak: 0 snap: 17
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04
