Keybindings warning - reason: mkinitcpio
When using consolefont AND get an error after sudo mkinitcpio -P
because of this Error:
“ERROR: consolefont: requested font not found: …”
And then change the entry “consolefont keymap” in mkinitcpio to: sd-vconsole
then there will be a warning like: gsd-media-keys[…]: Failed to grab accelerator for keybinding settings:
Solution in THIS case: replace “sd-vconsole” by “keymap”.
EDIT:
from ArchWiki - mkinitcpio…
Why would you do that? sd-vconsole is not a substitute for keymap. You still need keymap, unless you have a traditional US keyboard layout. But even then still I would not recommend leaving out keymap.
If you dont mind the default keymap of us then you can omit it.
Likely in that case, if /etc/vconsole exists … it may even be commented out.
keymap hook explanation:
Adds and Loads the specified keymap(s) from /etc/vconsole.conf during early userspace.
/etc/vconsole explanation:
A persistent keymap can be set in /etc/vconsole.conf, which is read by systemd on start-up. The KEYMAP variable is used for specifying the keymap. If the variable is empty or not set, the us keymap is used as default value.
What is the issue exactly?
Means the font specified in /etc/vconsole.conf was not found in /usr/share/kbd/consolefonts.
Changing the hook won’t help you there.
It is, IF you use systemd init - see: https://www.freedesktop.org/software/systemd/man/latest/systemd-vconsole-setup.service.html - otherwise changing it just invites errors and drops functionality. Last I checked the default was still busybox.
Correct, but i do not need " consolefont" anyway.
sd-vconsoleis not a substitute for keymap` ==> consists of “keymap” and “consolefont”
later not needed so keymap is enough afai-think…
My personal mkinitcpio:
HOOKS=(systemd autodetect modconf block keyboard keymap filesystems)
(using enabled systemd-fsck)
This … and really nothing else.
how to avoid this messages – was my real question…
According to pacman that’s from gnome-settings-daemon.
I wonder how much that has to do with init.
that was hard to discern (for me) and I didn’t catch that
My mistake — I was thinking of the keyboard hook and getting it mixed up with keymap. Indeed, with the sd-vconsole hook, you don’t need the keymap hook anymore. :wink:
Or neither/none, in cases like outlined above :slight_smile:
( my current: autodetect systemd modconf kms block keyboard filesystems fsck )
