Hi, I have a 2017 macbook air. Manjaro (with Gnome) works great.
However, I have this wi-fi driver: broadcom-wl-dkms 6.30.223.271-26.
I also have kernel 5.9.1 installed. When I install a new kernel (5.10 LTS, 5.12 and 5.13) the wi-fi does not work anymore.
How can I upgrade my kernel while keeping the wi-fi on my computer?
You may need to manually update your driver every time the kernel updates. I have a wi-fi card i need to (make install) a driver for from a git project, & every kernel update i need to re-install it.
I dont need to re-install linux-headers, or base-devel because those are packages that get updated in the system upgrade as you noticed, but a special driver not in repositories wont get updated.
Thank’s it worked !
For the record, and eventually other users close to my situation : I discovered that this driver had a more update version on arch repos, so I uninstalled my actual driver and manualy installed the new one (not available on the software center) and it works perfectly with the 5.10 LTS kernel.
