Kernel Update, confused
It says 100%, but the 2 numbers at the bottom ar lower before the /.
And the scroll bar on the right is not all the way down … meaning there is likely more text below what is shown.
That would be the post-transaction hook “Updating linux initcpios” but the word initcpios is cut off from the picture.
The numbers are lower before the / because that means 1 of 6, 2 of 6, 3 of 6, etc. There were 6 post-transaction hooks. Have you never used pacman before?
Well crap I closed it, hope np errors happened. How do I check if everything went right, sys settings does say it is installed now.
It does say “changes were made successfully” at the top! :wink:
Sorry, just seemed something didn’t go right, it rebooted fine though. :slight_smile:
