Hello, community! My Lenovo laptop has inconsistent kernel panics on last 3 Manjaro releases. Issue can happen several reboots in a row, so as once in a week or two.
Symptoms: CapsLk indicator blinks, kernel commands ignored (unable to REISUB). After hard turn off and next boot system journal is wiped.
The laptop has rare combination on AMD integrated GPU with Nvidia card, so I suspect problem origin is there. I was using optimus-manager as described in Arch Wiki, and to exclude error there recently I’ve reinstalled Manjaro, but problem remains.
To support backlight setting I had to make changes to grub config:
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 acpi.backlight=video nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1 amdgpu.backlight=0"
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=ace0bad8-28bd-4394-be04-6f16f09c2607 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming 3 15ARH05
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ARH05
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: FCCN15WW date: 12/23/2020
ID-1: BAT0 charge: 40.4 Wh (97.8%) condition: 41.3/45.0 Wh (91.7%)
volts: 12.7 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
status: N/A cycles: 76
RAM: total: 30.79 GiB used: 5.33 GiB (17.3%)
RAM Report:
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1946 high: 3085 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1964 2: 2723
3: 1415 4: 1526 5: 1397 6: 1514 7: 2572 8: 3085 9: 1628 10: 1602 11: 1867
12: 2065 bogomips: 71891
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.25-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:c822
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: br-499717b4500a state: down mac: <filter>
IF-ID-2: br-e2c9524fa80f state: down mac: <filter>
IF-ID-3: br-fd445cdec72a state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 1.36 TiB used: 46.88 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 40WD
scheme: GPT
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 17.79 GiB (8.9%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: ace0bad8-28bd-4394-be04-6f16f09c2607
used: 568 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 6D0E-7BD5
ID-3: /home raw-size: 698.49 GiB size: 698.49 GiB (100.00%)
used: 29.09 GiB (4.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 57c7fd23-2de5-4fb4-b2e0-f07d6516c1fd
ID-4: /var/cache raw-size: 200 GiB size: 200 GiB (100.00%)
used: 17.79 GiB (8.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: ace0bad8-28bd-4394-be04-6f16f09c2607
ID-5: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: partition size: 32.23 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: cd5c2a44-93ca-4420-9b07-d4f71adf14e6
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 7B0A-6572
ID-2: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda2 maj-min: 8:2 size: 465.75 GiB fs: ntfs label: System
uuid: 50964CB7964C9EFA
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 1-2.1:4 info: Logitech Corded Keyboard K280e type: Keyboard,HID
power: 98mA chip-ID: 046d:c328 class-ID: 0300
Hub-3: 1-2.3:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-2.4:6 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
Device-2: 1-2.5:7 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
Device-3: 1-3:3 info: IMC Networks Integrated Camera type: Video
Hub-4: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-7: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 417 Uptime: 4m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1366 pacman: 1356 lib: 370
flatpak: 6 snap: 4 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.13
dmesg --level emerg,alert,crit,err,warn
[ 0.275985] TSC synchronization [CPU#0 -> CPU#1]:
[ 0.275985] Measured 7984323882 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.276141] #2 #3 #4 #5 #6 #7 #8 #9 #10 #11
[ 0.588130] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.588131] pci 0000:00:00.2: PCI INT A: not connected
[ 0.688853] Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 1.299615] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 2.169880] nvidia: loading out-of-tree module taints kernel.
[ 2.169890] nvidia: module license 'NVIDIA' taints kernel.
[ 2.169891] Disabling lock debugging due to kernel taint
[ 2.190059] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.190282] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.190326] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.270735] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.54 Tue Feb 8 04:42:21 UTC 2022
[ 2.780727] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 2.862799] ATPX version 1, functions 0x00000001
[ 2.862935] ATPX Hybrid Graphics
[ 2.875460] amdgpu 0000:05:00.0: amdgpu: PSP runtime database doesn't exist
[ 2.900735] systemd-journald[347]: File /var/log/journal/c6e1796e43264e11ac943f1cba220b84/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 3.754306] amdgpu: SRAT table not found
[ 6.461197] ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 8.083501] kauditd_printk_skb: 249 callbacks suppressed
[ 13.416254] kauditd_printk_skb: 223 callbacks suppressed
[ 23.634617] kauditd_printk_skb: 19 callbacks suppressed
I’m relatively new to the world of free software, but have a strong intent to stay : ) Please, give me some guidance how to troubleshoot this issue.
