I’ll start by saying this- Sway on the PBP is an absolute pleasure. Haven’t used a tiling WM before, but this seemed to make my PBP a lot more enjoyable to use. It was even working well connecting to QEMU sessions running on my desktop. But for whatever reason I seem to be getting kernel panic more often than I would running Plasma. I noticed a few socket errors on login, and some DRM errors while the session was running. Aside from that, I can’t tell what’s causing it.
As a workaround, I’d like to try to run Sway in addition to Plasma. Is there a way to install the Manjaro Sway, instead of just the vanilla sway from the repo?
