Sure thing, currently using 4.19 because it’s stable
Kernel: 4.19.141-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
root=UUID=a67a769e-d470-496c-9e3c-1b31b17912d0 rw quiet
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80R9 v: Lenovo ideapad 100S-14IBR
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 100S-14IBR
serial: <filter>
Mobo: LENOVO model: Aristotle 14 v: SDK0J91182 WIN serial: <filter>
UEFI: Lenovo v: E4CN34WW date: 08/02/2016
ID-1: BAT1 charge: 11.6 Wh condition: 11.6/33.1 Wh (35%) volts: 8.5/7.6
model: Intel SR 1 Harris Beach type: Li-ion serial: <filter> status: Full
cycles: 217
Topology: Dual Core model: Intel Celeron N3060 bits: 64 type: MCP
arch: Airmont family: 6 model-id: 4C (76) stepping: 4 microcode: 411
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 6400
Speed: 2480 MHz min/max: 480/2480 MHz Core speeds (MHz): 1: 2348 2: 2464
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b1
Device-2: Chicony Lenovo EasyCamera type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 04f2:b5a1 serial: <filter>
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 20.1.6
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:2284
Sound Server: ALSA v: k4.19.141-2-MANJARO
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: 1040
bus ID: 03:00.0 chip ID: 8086:08b4
Local Storage: total: 58.25 GiB used: 38.00 GiB (65.2%)
ID-1: /dev/mmcblk0 vendor: SK Hynix model: HCG8e size: 58.25 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 0x7
scheme: GPT
ID-1: / raw size: 57.75 GiB size: 56.59 GiB (98.00%)
used: 38.00 GiB (67.1%) fs: ext4 dev: /dev/mmcblk0p2
ID-1: swap-1 type: file size: 4.00 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: file size: 256.0 MiB used: 35.8 MiB (14.0%)
priority: 50 file: /var/lib/systemd-swap/swapfc/1
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 191 Uptime: 22h 28m Memory: 3.70 GiB used: 1.47 GiB (39.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1620
lib: 500 flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal
inxi: 3.1.05
