Kernel panic after uninstall amd-ucode
Hello, I have uninstalled amd-ucode and have a kernel panic, then I tried to fix this way:
  1. Use Manjaro Live USB to get a terminal
  2. Then, this commands:
sudo -i
mount -t ext4 /dev/sda4 /mnt/
mount -t ext4 /dev/sda4 /mnt/home
mount -t ext4 /dev/sda4 /mnt/var/log
mount -t ext4 /dev/sda4 /mnt/var/cache
mount -t vfat  /dev/sda1 /mnt/boot/efi
mount --bind /dev /mnt/dev
mount -t proc proc /mnt/proc
mount -t sysfs sysfs /mnt/sys
mount -t efivarfs efivarfs /mnt/sys/firmware/efi/efivars
chroot /mnt /bin/bash
But when I tried:
pacman -Syu amd-ucode
Failed to synchronize to all databases, and when:
pacman-mirrors -f && sudo pacman -Syyu
shows me the error that, Internet connection appears to be down, but it is up and working.
Then I tried to download the package and install it locally but:
pacman -U /home/manjaro/Downloads/amd-ucode-20260110-1-any.pkg.tar.zst
loading packages…
error: ‘/home/manjaro/Downloads/amd-ucode-20260110-1-any.pkg.tar.zst’: could not find
or read package
Now, I don’t know how to fix the problem.
First boot a rescue ISO or a live ISO - follow the guide to mount and chroot
[root tip] [recovery] Basic Manjaro Linux Rescue and Recovery
Then install the package
Problem resolved. Thank you very, very much.
