Hi,
I was trying to install the latest linux kernel on an Oracle Cloud VM.Standard.A1.Flex (Ampere A1, aarch64) instance but it doesn’t seem to work at all. Right now I’m using the old linux515 package (which still works).
I have a self built kernel which came from before I directly switched from Arch Linux ARM to Manjaro which still works where I have been doing the kernel installations (without much success).
Is there a way I can make the latest linux kernel work?
Linux 5.15 goes EOL later this year and I don’t want to be caught in its wake, nor do I want to have to compile the latest kernel source each time a new release happens (otherwise, I would’ve kept Arch Linux ARM instead).
Any help would be appreciated, thanks!
